thinkgeo.mapsuite.portablecore.heatlayer
ThinkGeo.MapSuite.Core.HeatLayer
      • ThinkGeo.MapSuite.Core.HeatLayer
HeatLayer()
  • This is the default constructor of the class.
HeatLayer(FeatureSource)
  • None
  • featureSource
    • Description:This parameter is the FeatureSource that use to be drawn.
GetThreadSafetyLevel()
CloneDeep()
  • Type:Layer
Open()
Close()
GetBoundingBox()
RequestDrawing()
RequestDrawing(TimeSpan)
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
OpenCore()
  • This method opens the Layer so that it is initialized and ready to use.
  • This abstract method is called from the concrete public method Open. The open method plays an important role, as it is responsible for initializing the Layer. Most methods on the Layer will throw an exception if the state of the Layer is not opened. When the map draws each layer, the layer will be opened as one of its first steps; then, after it is finished drawing with that layer, it will close it. In this way, we are sure to release all resources used by the Layer. When implementing the abstract method, consider opening the FeatureSource or RasterSource. You will get a chance to close these in the Close method of the Layer.
  • Description:None
CloseCore()
  • This method closes the Layer and releases any resources it was using.
  • This abstract method is called from the concrete public method Close. The close method plays an important role in the life cycle of the Layer. It may be called after drawing to release any memory and other resources that were allocated since the Open method was called. If you override this method, it is recommended that you take the following things into account: This method may be called multiple times, so we suggest you write the method so that that a call to a closed Layer is ignored and does not generate an error. We also suggest that in the Close you free all resources that have been opened. Remember that the object will not be destroyed, but will be re-opened possibly in the near future.
  • Description:None
  • This method draws the Layer.
  • This method is the concrete wrapper for the abstract method DrawCore. This method draws the representation of the layer based on the extent you provided. When implementing this abstract method, consider each feature and its column data values. You can use the full power of the GeoCanvas to do the drawing. If you need column data for a feature, be sure to override the GetRequiredColumnNamesCore and add the columns you need to the collection. In many of the styles, we add properties that allow the user to specify which field they need; then, in the GetRequiredColumnNamesCore, we read that property and add it to the collection.
  • Description:None
  • canvas
    • Type:GeoCanvas
    • Description:This parameter is the canvas object or a GeoImage to draw on.
  • labelsInAllLayers
    • Description:This parameter represents the labels used for collision detection and duplication checking.
GetThreadSafetyLevelCore()
CloneDeepCore()
  • Type:Layer
GetBoundingBoxCore()
  • e
    • Type:Exception
  • e
    • Type:Exception
  • attribution
FeatureSource
  • This property gets the FeatureSource for the HeatLayer.
  • The FeatureSource is the provider of data to the HeatLayer. There are different FeatureSource classes to match the various ways that feature data is stored. It is important that, when you inherit from the HeatLayer, in the constructor you set the FeatureSource you want to use.
HeatStyle
  • Gets or sets the style of HeatLayer.
  • If this property is not set, it will use the default HeatStyle.
UpperScale
  • Specifies the upper threshold of the layer.
  • The HeatLayer only displays when the currentScale is less than or equal to UpperScale and greater than or equal to LowerScale, otherwise it won't show anything.
LowerScale
  • Specifies the lower threshold of the layer.
IsOpen
HasBoundingBox
DrawingTime
  • Type:TimeSpan
IsVisible
Transparency
  • Type:Single
IsNegative
IsGrayscale
DrawingExceptionMode
Attribution
RequestDrawingInterval
  • Type:TimeSpan
IsOpenCore
DrawingException
DrawnException
DrawingAttribution
DrawnAttribution
RequestedDrawing
RequestingDrawing
thinkgeo.mapsuite.portablecore.heatlayer.txt · Last modified: 2017/03/16 21:59 (external edit)
