thinkgeo.mapsuite.windowsphonecore.extenthelper
Table of Contents
ThinkGeo.MapSuite.WindowsPhoneCore.ExtentHelper
<!– Class –> This static class exposes a number of helpful methods when dealing with extents.
Public MethodStatic MemberCenterAt RectangleShape, Double, Double, Double, Double This method returns an adjusted extent centered on a point.
Public MethodStatic MemberCenterAt RectangleShape, PointShape, Double, Double This is a static function that allows you to pass in a world rectangle, a world point to center on, and a height and width in screen units. The function will center the rectangle based on the point, then adjust the rectangle's ratio based on the height and width in screen coordinates.
Public MethodStatic MemberCenterAt RectangleShape, Feature, Double, Double This is a static function that allows you to pass in a world rectangle, a world point to center on, and a height and width in screen units. The function will center the rectangle based on the point, then adjust the rectangle's ratio based on the height and width in screen coordinates.
Public MethodStatic MemberGetBoundingBoxOfItems IEnumerable<Feature> This API gets the BoundingBox of a group of Features.
Public MethodStatic MemberGetBoundingBoxOfItems IEnumerable<BaseShape> This API gets the BoundingBox of a group of BaseShapes.
Public MethodStatic MemberGetDrawingExtent RectangleShape, Double, Double This method returns an adjusted extent based on the ratio of the screen width and height.
Public MethodStatic MemberGetScale RectangleShape, Double, GeographyUnit, Single This method returns the current scale.
Public MethodStatic MemberGetScreenDistanceBetweenTwoWorldPoints RectangleShape, Feature, Feature, Double, Double This method returns the number of pixels between two features.
Public MethodStatic MemberGetScreenDistanceBetweenTwoWorldPoints RectangleShape, PointShape, PointShape, Double, Double This method returns the number of pixels between two world points.
Public MethodGetType Object
Public MethodStatic MemberGetWorldDistanceBetweenTwoScreenPoints RectangleShape, Double, Double, Double, Double, Double, Double, GeographyUnit, DistanceUnit This method returns the distance in world units between two screen points.
Public MethodStatic MemberGetWorldDistanceBetweenTwoScreenPoints RectangleShape, Point, Point, Double, Double, GeographyUnit, DistanceUnit This method returns the distance in world units between two screen points.
Public MethodStatic MemberPan RectangleShape, PanDirection, Int32 This method returns a panned extent.
Public MethodStatic MemberPan RectangleShape, Double, Int32 This method returns a panned extent.
Public MethodStatic MemberSnapToZoomLevel RectangleShape, GeographyUnit, Double, Double, ZoomLevelSet This method returns an extent that is snapped to a zoom level in the provided zoom level set.
Public MethodStatic MemberToScreenCoordinate RectangleShape, PointShape, Double, Double This method returns screen coordinates from world coordinates.
Public MethodStatic MemberToScreenCoordinate RectangleShape, Feature, Double, Double This method returns screen coordinates from world coordinates.
Public MethodStatic MemberToScreenCoordinate RectangleShape, Double, Double, Double, Double This method returns screen coordinates from world coordinates.
Public MethodToString Object
Public MethodStatic MemberToWorldCoordinate RectangleShape, Double, Double, Double, Double This method returns world coordinates from screen coordinates.
Public MethodStatic MemberToWorldCoordinate RectangleShape, Point, Double, Double This method returns world coordinates from screen coordinates.
Public MethodStatic MemberZoomIn RectangleShape, Int32 This method returns a new extent that is zoomed in by the percentage provided.
Public MethodStatic MemberZoomIntoCenter RectangleShape, Int32, Double, Double, Double, Double This method returns an extent that is centered and zoomed in.
Public MethodStatic MemberZoomIntoCenter RectangleShape, Int32, PointShape, Double, Double This method returns an extent that is centered and zoomed in.
Public MethodStatic MemberZoomIntoCenter RectangleShape, Int32, Feature, Double, Double This method returns an extent that is centered and zoomed.
Public MethodStatic MemberZoomIntoOffsetPoint RectangleShape, Double, Double, Point, Int32 This method returns an extent that is keeping the offsetScreenPoint constant and zoomed.
Public MethodStatic MemberZoomOut RectangleShape, Int32 This method returns a new extent that is zoomed out by the percentage provided.
Public MethodStatic MemberZoomOutToCenter RectangleShape, Int32, Feature, Double, Double This method returns an extent that is centered and zoomed out.
Public MethodStatic MemberZoomOutToCenter RectangleShape, Int32, PointShape, Double, Double This method returns an extent that is centered and zoomed out.
Public MethodStatic MemberZoomOutToCenter RectangleShape, Int32, Double, Double, Double, Double This method returns an extent that is centered and zoomed out.
Public MethodStatic MemberZoomOutToOffsetPoint RectangleShape, Double, Double, Point, Int32 This method returns an extent that is keeping the offsetScreenPoint constant and zoomed.
Public MethodStatic MemberZoomToScale Double, RectangleShape, GeographyUnit, Double, Double This method returns a extent that has been zoomed into a certain scale.
Public MethodStatic MemberZoomToScale Double, RectangleShape, GeographyUnit, Double, Double, Point This method returns a extent that has been zoomed into a certain scale.
CenterAt(RectangleShape, Double, Double, Double, Double)
<!– static –> This method returns an adjusted extent centered on a point.
Overloads
This overload allows you to pass in a screen point as the center.
Return Type Description
RectangleShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.RectangleShape –> This method returns an adjusted extent centered on a point.
Name Type Description
worldExtent RectangleShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.RectangleShape –> This parameter is the current extent you want to center.
screenX Double<!– System.Double –> This parameter is the X coordinate on the screen to center on.
screenY Double<!– System.Double –> This parameter is the Y coordinate on the screen to center on.
screenWidth Double<!– System.Double –> This parameter is the width of the screen.
screenHeight Double<!– System.Double –> This parameter is the height of the screen.
<!– ThinkGeo.MapSuite.WindowsPhoneCore.ExtentHelper –> Go Back
CenterAt(RectangleShape, PointShape, Double, Double)
<!– static –> This is a static function that allows you to pass in a world rectangle, a world point to center on, and a height and width in screen units. The function will center the rectangle based on the point, then adjust the rectangle's ratio based on the height and width in screen coordinates.
Overloads
This overload allows you to pass in a world point as the center.
worldPoint PointShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.PointShape –> This parameter is the world point you want to center on.
CenterAt(RectangleShape, Feature, Double, Double)
Overloads
centerFeature Feature<!– ThinkGeo.MapSuite.WindowsPhoneCore.Feature –>
Boolean<!– System.Boolean –>
GetBoundingBoxOfItems(IEnumerable<Feature>)
<!– static –> This API gets the BoundingBox of a group of Features.
RectangleShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.RectangleShape –> The BoundingBox that contains all the features you passed in.
features IEnumerable<Feature><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.WindowsPhoneCore.Feature} –> The target group of Features to get the BoundingBox for.
GetBoundingBoxOfItems(IEnumerable<BaseShape>)
<!– static –> This API gets the BoundingBox of a group of BaseShapes.
RectangleShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.RectangleShape –> The BoundingBox that contains all of the shapes you passed in.
shapes IEnumerable<BaseShape><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.WindowsPhoneCore.BaseShape} –> The target group of BaseShapes to get the BoundingBox for.
GetDrawingExtent(RectangleShape, Double, Double)
<!– static –> This method returns an adjusted extent based on the ratio of the screen width and height.
This function is used because the extent to draw must be the rame ratio as the screen width and height. If they are not, then the image drawn will be stretched or compressed. We always adjust the extent upwards to ensure that no matter how we adjust it, the original extent will fit within the new extent. This ensures that everything you wanted to see in the first extent is visible and maybe a bit more.
RectangleShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.RectangleShape –> This method returns an adjusted extent based on the ratio of the screen width and height.
worldExtent RectangleShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.RectangleShape –> This parameter is the world extent you want to adjust for drawing.
Int32<!– System.Int32 –>
GetScale(RectangleShape, Double, GeographyUnit, Single)
<!– static –> This method returns the current scale.
Double<!– System.Double –> This method returns the current scale.
worldExtent RectangleShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.RectangleShape –> This parameter is the world extent you want to find the scale for.
screenWidth Double<!– System.Double –> This parameter is the screen width.
worldExtentUnit GeographyUnit<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeographyUnit –> This parameter is the unit of the world extent.
dpi Single<!– System.Single –>
GetScale(RectangleShape, Double, GeographyUnit)
<!– static –>
GetScreenDistanceBetweenTwoWorldPoints(RectangleShape, Feature, Feature, Double, Double)
<!– static –> This method returns the number of pixels between two features.
Double<!– System.Double –> This method returns the number of pixels between two features.
worldExtent RectangleShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.RectangleShape –> This parameter is the world extent.
worldPointFeature1 Feature<!– ThinkGeo.MapSuite.WindowsPhoneCore.Feature –> This parameter is the first feature – the one you want to measure from.
worldPointFeature2 Feature<!– ThinkGeo.MapSuite.WindowsPhoneCore.Feature –> This parameter is the second feature – the one you want to measure to.
GetScreenDistanceBetweenTwoWorldPoints(RectangleShape, PointShape, PointShape, Double, Double)
<!– static –> This method returns the number of pixels between two world points.
Double<!– System.Double –> This method returns the number of pixels between two world points.
worldPoint1 PointShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.PointShape –> This parameter is the first point – the one you want to measure from.
worldPoint2 PointShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.PointShape –> This parameter is the second point – the one you want to measure to.
Type<!– System.Type –>
GetWorldDistanceBetweenTwoScreenPoints(RectangleShape, Double, Double, Double, Double, Double, Double, GeographyUnit, DistanceUnit)
<!– static –> This method returns the distance in world units between two screen points.
Overloads
This overload allows you to pass in the X & Y for each point.
screenPoint1X Double<!– System.Double –> This parameter is the X of the point you want to measure from.
screenPoint1Y Double<!– System.Double –> This parameter is the Y of the point you want to measure from.
screenPoint2X Double<!– System.Double –> This parameter is the X of the point you want to measure to.
screenPoint2Y Double<!– System.Double –> This parameter is the Y of the point you want to measure to.
worldExtentUnit GeographyUnit<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeographyUnit –> This is the geographic unit of the world extent you passed in.
distanceUnit DistanceUnit<!– ThinkGeo.MapSuite.WindowsPhoneCore.DistanceUnit –> This is the geographic unit you want the result to show in.
GetWorldDistanceBetweenTwoScreenPoints(RectangleShape, Point, Point, Double, Double, GeographyUnit, DistanceUnit)
Overloads
This overload allows you to pass in Point as the points.
Double<!– System.Double –> This method returns the distance in world units between two screen points.
screenPoint1 Point<!– System.Windows.Point –> This is the screen point you want to measure from.
screenPoint2 Point<!– System.Windows.Point –> This is the screen point you want to measure to.
worldExtentUnit GeographyUnit<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeographyUnit –> This is the geographic unit of the world extent rectangle.
Pan(RectangleShape, PanDirection, Int32)
<!– static –> This method returns a panned extent.
Overloads
This overload allows you to pass in a direction and a percentage by which you want to pan.
RectangleShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.RectangleShape –> This method returns a panned extent.
worldExtent RectangleShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.RectangleShape –> This parameter is the world extent you want to pan.
direction PanDirection<!– ThinkGeo.MapSuite.WindowsPhoneCore.PanDirection –> This parameter is the direction in which you want to pan.
percentage Int32<!– System.Int32 –> This parameter is the percentage by which you want to pan.
Pan(RectangleShape, Double, Int32)
Overloads
This overload allows you to pass in an angle and a percentage by which you want to pan.
degree Double<!– System.Double –> This parameter is the degree you want to pan.
SnapToZoomLevel(RectangleShape, GeographyUnit, Double, Double, ZoomLevelSet)
<!– static –> This method returns an extent that is snapped to a zoom level in the provided zoom level set.
RectangleShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.RectangleShape –> This method returns an extent that is snapped to a zoom level in the provided zoom level set.
worldExtent RectangleShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.RectangleShape –> This parameter is the world extent you want snapped.
worldExtentUnit GeographyUnit<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeographyUnit –> This parameter is the geographic unit of the world extent parameter.
screenHeight Double<!– System.Double –> This parameter is the screen height.
zoomLevelSet ZoomLevelSet<!– ThinkGeo.MapSuite.WindowsPhoneCore.ZoomLevelSet –> This parameter is the set of zoom levels you want to snap to.
ToScreenCoordinate(RectangleShape, PointShape, Double, Double)
<!– static –> This method returns screen coordinates from world coordinates.
Point<!– System.Windows.Point –> This method returns screen coordinates from world coordinates.
worldPoint PointShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.PointShape –> This parameter is the world point you want converted to a screen point.
ToScreenCoordinate(RectangleShape, Feature, Double, Double)
worldPointFeature Feature<!– ThinkGeo.MapSuite.WindowsPhoneCore.Feature –> This parameter is the feature you want converted to a screen point.
ToScreenCoordinate(RectangleShape, Double, Double, Double, Double)
Overloads
This overload allows you to pass in world X & Y coordinates.
worldX Double<!– System.Double –> This parameter is the world X you want converted to screen points.
worldY Double<!– System.Double –> This parameter is the world Y you want converted to screen points.
String<!– System.String –>
ToWorldCoordinate(RectangleShape, Double, Double, Double, Double)
<!– static –> This method returns world coordinates from screen coordinates.
PointShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.PointShape –> This method returns world coordinates from screen coordinates.
screenX Double<!– System.Double –> This parameter is the X of the point you want converted to world coordinates.
screenY Double<!– System.Double –> This parameter is the Y of the point you want converted to world coordinates.
ToWorldCoordinate(RectangleShape, Point, Double, Double)
screenPoint Point<!– System.Windows.Point –> This parameter is the screen point you want converted to a world point.
ZoomIn(RectangleShape, Int32)
<!– static –> This method returns a new extent that is zoomed in by the percentage provided.
RectangleShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.RectangleShape –> This method returns a new extent that is zoomed in by the percentage provided.
worldExtent RectangleShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.RectangleShape –> This parameter is the world extent you want to zoom to.
percentage Int32<!– System.Int32 –> This parameter is the percentage by which you want to zoom in.
ZoomIntoCenter(RectangleShape, Int32, Double, Double, Double, Double)
<!– static –> This method returns an extent that is centered and zoomed in.
Overloads
This overload allows you to pass in the height and width in screen coordinates, as well as a screen X & Y.
The resulting rectangle will already be adjusted for the ratio of the screen. You do not need to call GetDrawingExtent afterwards.
RectangleShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.RectangleShape –> This method returns an extent that is centered and zoomed in.
worldExtent RectangleShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.RectangleShape –> This parameter is the world extent you want to center and zoom to.
screenX Double<!– System.Double –> This parameter is the screen X you want to center on.
screenY Double<!– System.Double –> This parameter is the screen Y you want to center on.
ZoomIntoCenter(RectangleShape, Int32, PointShape, Double, Double)
Overloads
This overload allows you to pass in the height and width in screen coordinates, as well as a world point.
worldExtent RectangleShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.RectangleShape –> This parameter is the world extent that you want centered and zoomed to.
worldPoint PointShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.PointShape –> This parameter is the world point you want the extent to be centered on.
screenWidth Double<!– System.Double –> This parameter is the width in screen coordinates.
screenHeight Double<!– System.Double –> This parameter is the height in screen coordinates.
ZoomIntoCenter(RectangleShape, Int32, Feature, Double, Double)
<!– static –> This method returns an extent that is centered and zoomed.
Overloads
This overload allows you to pass in the height and width in screen coordinatesm as well as a feature.
centerFeature Feature<!– ThinkGeo.MapSuite.WindowsPhoneCore.Feature –> This parameter is the feature you want the extent to be centered on.
ZoomIntoOffsetPoint(RectangleShape, Double, Double, Point, Int32)
<!– static –> This method returns an extent that is keeping the offsetScreenPoint constant and zoomed.
The resulting rectangle will already be adjusted for the ratio of the screen. You do not need to afterward call GetDrawingExtent.
RectangleShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.RectangleShape –> This method returns an extent that is keeping the offsetScreenPoint constant and zoomed.
worldExtent RectangleShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.RectangleShape –> This parameter is the world extent that you want centered and zoomed.
offsetScreenPoint Point<!– System.Windows.Point –> This parameter is the screen point you want to keep it constant.
percentage Int32<!– System.Int32 –> This parameter is the percentage you want to zoom.
ZoomOut(RectangleShape, Int32)
<!– static –> This method returns a new extent that is zoomed out by the percentage provided.
RectangleShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.RectangleShape –> This method returns a new extent that is zoomed out by the percentage provided.
worldExtent RectangleShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.RectangleShape –> This parameter is the world extent you want to zoom out to.
percentage Int32<!– System.Int32 –> This parameter is the percentage by which you want to zoom out.
ZoomOutToCenter(RectangleShape, Int32, Feature, Double, Double)
<!– static –> This method returns an extent that is centered and zoomed out.
Overloads
This overload allows you to pass in the height and width in screen coordinates, as well as a feature.
RectangleShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.RectangleShape –> This method returns an extent that is centered and zoomed out.
worldExtent RectangleShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.RectangleShape –> This parameter is the world extent you want to center and zoom out to.
ZoomOutToCenter(RectangleShape, Int32, PointShape, Double, Double)
Overloads
ZoomOutToCenter(RectangleShape, Int32, Double, Double, Double, Double)
Overloads
The resulting rectangle will already be adjusted for the ratio of the screen. You do not need to call GetDrawingExtent afterward.
ZoomOutToOffsetPoint(RectangleShape, Double, Double, Point, Int32)
ZoomToScale(Double, RectangleShape, GeographyUnit, Double, Double)
<!– static –> This method returns a extent that has been zoomed into a certain scale.
RectangleShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.RectangleShape –> This method returns a extent that has been zoomed into a certain scale.
targetScale Double<!– System.Double –> This parameter is the scale you want to zoom into.
worldExtent RectangleShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.RectangleShape –> This parameter is the world extent you want zoomed into the scale.
ZoomToScale(Double, RectangleShape, GeographyUnit, Double, Double, Point)
offsetScreenPoint Point<!– System.Windows.Point –> This parameter is the offsetScreenPoint.
Void<!– System.Void –>
thinkgeo.mapsuite.windowsphonecore.extenthelper.txt · Last modified: 2017/03/16 21:59 (external edit)
