<!– Class –> This class creates models for objects and recreates objects from models.
*System.Object **ThinkGeo.MapSuite.PortableCore.GeoObjectModeler
![]() | Creates an instance of GeoObjectModeler. |
![]() | Object, GeoObjectModelerMemberTypes, BindingFlags, GeoObjectModelerDefaultValueMode | Creates model for an object. | |
![]() | GeoObjectModel | Creates an object from a model. | |
![]() | Object | Object | |
![]() | Object | ||
![]() | Object | ||
![]() | Object |
![]() | String, Object, Type, Object, GeoObjectNode | Creates a node for a member. | |
![]() | String, Type, Object, GeoObjectNode | Creates an object from a node. | |
![]() | Object | ||
![]() | Type, GeoObjectModelerMemberTypes | Gets members of a type. | |
![]() | Object | ||
![]() | CreatedMemberNodeGeoObjectModelerEventArgs | ||
![]() | CreatedMemberObjectGeoObjectModelerEventArgs | ||
![]() | CreatingMemberNodeGeoObjectModelerEventArgs | ||
![]() | CreatingMemberObjectGeoObjectModelerEventArgs |
![]() | CreatedMemberNodeGeoObjectModelerEventArgs | This event happens when the modeler has created a node for a member(field or property). | |
![]() | CreatedMemberObjectGeoObjectModelerEventArgs | This event happens when the modeler has created an object from a node. | |
![]() | CreatingMemberNodeGeoObjectModelerEventArgs | This event happens when the modeler is creating a node for a member(field or property). | |
![]() | CreatingMemberObjectGeoObjectModelerEventArgs | This event happens when the modeler is recreating an object from a node. |
Name | Type | Description |
Return Type | Description |
GeoObjectModel<!– ThinkGeo.MapSuite.PortableCore.GeoObjectModel –> | The model that represent the object. |
objectToModel | Object<!– System.Object –> | The object to model. |
memberTypes | GeoObjectModelerMemberTypes<!– ThinkGeo.MapSuite.PortableCore.GeoObjectModelerMemberTypes –> | The member types. |
bindingFlags | BindingFlags<!– System.Reflection.BindingFlags –> | The binding flags. |
defaultValueMode | GeoObjectModelerDefaultValueMode<!– ThinkGeo.MapSuite.PortableCore.GeoObjectModelerDefaultValueMode –> | The default value mode. |
<!– ThinkGeo.MapSuite.PortableCore.GeoObjectModeler –> Go Back
Object<!– System.Object –> | The object recreated from the model. |
model | GeoObjectModel<!– ThinkGeo.MapSuite.PortableCore.GeoObjectModel –> | The model. |
Int32<!– System.Int32 –> |
Type<!– System.Type –> |
String<!– System.String –> |
Void<!– System.Void –> |
memberName | String<!– System.String –> | The member name. |
memberValue | Object<!– System.Object –> | The member value. |
memberType | Type<!– System.Type –> | The member type. |
memberOwner | Object<!– System.Object –> | The member's owner(parent) object. |
baseMemberNode | GeoObjectNode<!– ThinkGeo.MapSuite.PortableCore.GeoObjectNode –> | The base(parent) member node. |
memberNode | GeoObjectNode<!– ThinkGeo.MapSuite.PortableCore.GeoObjectNode –> | The member node. |
Collection<MemberInfo><!– System.Collections.ObjectModel.Collection{System.Reflection.MemberInfo} –> | The members of a type. |
type | Type<!– System.Type –> | The type. |
e | CreatedMemberNodeGeoObjectModelerEventArgs<!– ThinkGeo.MapSuite.PortableCore.CreatedMemberNodeGeoObjectModelerEventArgs –> |
e | CreatedMemberObjectGeoObjectModelerEventArgs<!– ThinkGeo.MapSuite.PortableCore.CreatedMemberObjectGeoObjectModelerEventArgs –> |
e | CreatingMemberNodeGeoObjectModelerEventArgs<!– ThinkGeo.MapSuite.PortableCore.CreatingMemberNodeGeoObjectModelerEventArgs –> |
e | CreatingMemberObjectGeoObjectModelerEventArgs<!– ThinkGeo.MapSuite.PortableCore.CreatingMemberObjectGeoObjectModelerEventArgs –> |
Event Arguments |
Event Arguments |
Event Arguments |
Event Arguments |
