thinkgeo.mapsuite.portablecore.creatingmemberobjectgeoobjectmodelereventargs
ThinkGeo.MapSuite.Core.CreatingMemberObjectGeoObjectModelerEventArgs
This class represents the parameters passed in through the CreatingMemberObject event.
      • ThinkGeo.MapSuite.Core.CreatingMemberObjectGeoObjectModelerEventArgs
CreatingMemberObjectGeoObjectModelerEventArgs()
  • Creates an instance of CreatingMemberObjectGeoObjectModelerEventArgs.
CreatingMemberObjectGeoObjectModelerEventArgs(String,Type,Object,GeoObjectNode)
  • Creates an instance of CreatingMemberObjectGeoObjectModelerEventArgs with name, type, owner and node.
  • name
    • Description:The name of the member.
  • type
  • owner
    • Description:The owner of the member.
  • Gets or sets the name of the member.
Type
  • Gets or sets the type of the member.
Owner
  • Gets or sets the owner of the member.
Node
  • Gets or sets the node of the member.
thinkgeo.mapsuite.portablecore.creatingmemberobjectgeoobjectmodelereventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
