thinkgeo.mapsuite.portablecore.geoobjectnode
ThinkGeo.MapSuite.Core.GeoObjectNode
This class represent the model of an object.
    • ThinkGeo.MapSuite.Core.GeoObjectNode
GeoObjectNode()
  • Creates an instance of GeoObjectNode.
GeoObjectNode(String)
  • Creates an instance of GeoObjectNode with a name.
  • name
    • Description:The name of this node.
  • Returns a string that contains the name, children count and attribute count of this node.
  • Description:The string that contains the name, children count and attribute count of this node.
SetAttribute(String,String)
  • attributeName
  • attributeValue
GetAttribute(String)
  • attributeName
RemoveAttribute(String)
  • attributeName
  • Gets or sets the Name of the node.
Parent
  • Gets or sets the Parent of the node.
Children
  • Gets the Children of the node.
Attributes
  • Gets the Attribute of the node.
Value
  • Gets or sets the Value of the node.
IsDefaultValue
  • Gets or sets the IsDefaultValue of the node.
IsNonGenericSequence
LastChild
FirstChild
thinkgeo.mapsuite.portablecore.geoobjectnode.txt · Last modified: 2017/03/16 21:59 (external edit)
