thinkgeo.mapsuite.portablecore.createdmembernodegeoobjectmodelereventargs
ThinkGeo.MapSuite.Core.CreatedMemberNodeGeoObjectModelerEventArgs
This class represents the parameters passed in through the CreatedMemberNode event.
      • ThinkGeo.MapSuite.Core.CreatedMemberNodeGeoObjectModelerEventArgs
CreatedMemberNodeGeoObjectModelerEventArgs()
  • Creates an instance of MemberNodeCreatedGeoObjectModelerEventArgs.
CreatedMemberNodeGeoObjectModelerEventArgs(String,Object,Type,Object,GeoObjectNode)
  • Creates an instance of MemberNodeCreatedGeoObjectModelerEventArgs with name, value, type, owner and node.
  • name
    • Description:The name of the member.
  • value
    • Description:The value of the member.
  • type
    • Description:The type of the member.
  • owner
    • Description:The owner of the member.
  • Gets or sets the name of the member.
Value
  • Gets or sets the value of the member.
Type
  • Gets or sets the type of the member.
Owner
  • Gets or sets the owner of the member.
Node
  • Gets or sets the node of the member.
thinkgeo.mapsuite.portablecore.createdmembernodegeoobjectmodelereventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
