thinkgeo.mapsuite.portablecore.geolineargradientbrush
ThinkGeo.MapSuite.Core.GeoLinearGradientBrush
    • ThinkGeo.MapSuite.Core.GeoBrush
      • ThinkGeo.MapSuite.Core.GeoLinearGradientBrush
GeoLinearGradientBrush(GeoColor,GeoColor,GeoLinearGradientDirection)
  • Create an instance of GeoLinearGradientBrush by passing a gradient start color and gradient end color followed by the gradient direction enum.
  • startColor
    • Type:GeoColor
    • Description:This parameter specifies the starting GeoColor of the GeoLinearGradientBrush.
  • endColor
    • Type:GeoColor
    • Description:This parameter specifies the endding GeoColor of the GeoLinearGradientBrush.
  • direction
    • Description:This parameter specifies the GeoLinearGradientDirection enumeration of the GeoLinearGradientBrush.
GeoLinearGradientBrush(GeoColor,GeoColor,Single)
  • Create an instance of GeoLinearGradientBrush by passing a gradient start color and gradient end color followed by the gradient direction angle.
  • startColor
    • Type:GeoColor
  • endColor
    • Type:GeoColor
  • directionAngle
    • Type:Single
    • Description:This parameter specifies the direction angle value of the GeoLinearGradientBrush.
GeoLinearGradientBrush()
  • Create a new instance of the GeoLinearGradientBrush with default settings.
CloneDeep()
CloneDeepCore()
StartColor
  • Gets or sets the starting GeoColor of the gradient.
EndColor
  • Gets or sets the ending GeoColor of the gradient.
DirectionAngle
  • Gets or sets the Direction angle of the GeoLinearGradientBrush.
  • Type:Single
WrapMode
  • Gets or sets a GeoWrapMode enumeration that indicates the wrap mode for the GeoLinearGradientBrush.
Id
  • Type:Int64
thinkgeo.mapsuite.portablecore.geolineargradientbrush.txt · Last modified: 2017/03/16 21:59 (external edit)
