thinkgeo.mapsuite.portablecore.geocodeformatter
ThinkGeo.MapSuite.Core.GeoCodeFormatter
This class formats a GeoObjectModel into program code.
GeoCodeFormatter()
  • Creates an instance of GeoCodeFormatter.
Save(GeoObjectModel,Stream)
  • Creates code for a GeoObjectModel and save the code into a Stream.
  • model
    • Description:The GeoObjectModel to generate code for.
  • stream
    • Type:Stream
    • Description:The Stream to save code into.
SaveCore(GeoObjectModel,Stream)
  • model
  • stream
    • Type:Stream
thinkgeo.mapsuite.portablecore.geocodeformatter.txt · Last modified: 2017/03/16 21:59 (external edit)
