<!– Class –> Represents the coordinates of the mouse pointer, displayed in the lower right corner of the map.
The <strong>MouseCoordinateMapTool</strong> control represents the coordinates where the mouse pointer currently is. The default coordinate string is in the format “longitude, latitude”. You can also choose to display coordinates in DMS (degrees, minutes, seconds).
*System.Object ThinkGeo.MapSuite.MvcEdition.MapTool *ThinkGeo.MapSuite.MvcEdition.MouseCoordinateMapTool
MouseCoordinateMapTool | Initialize an instance of MouseCoordinateMapTool class. |
Enabled | Boolean | MapTool | Gets or sets a value that turns the feature on and off. |
MouseCoordinateType | MouseCoordinateType | Gets or sets the format that the mouse coordinates will display in. |
Load this object from a json string.
| jsonString | String<!– System.String –> | a json string |
<!– ThinkGeo.MapSuite.MvcEdition.MapTool –> Go Back
Returns a JSON string that represents the map control object.
This method returns a JSON string that instructs the client Javascript to create a specific client object.
| String<!– System.String –> | A JSON string that represents the map control. |
The MouseCoordinateType property gives you two options for displaying the mouse pointer coordinates. One is in the format “longitude, latitude” and the other is in DMS format (33° 22' 15). === Return Value === ^ Return Type ^ | MouseCoordinateType<!– ThinkGeo.MapSuite.MvcEdition.MouseCoordinateType –> | <!– ThinkGeo.MapSuite.MvcEdition.MouseCoordinateMapTool –> Go Back ===== Protected Properties ===== ===== Public Events ===== NOTOC MvcEdition ThinkGeo.MapSuite.MvcEdition UpdateDocumentation
