thinkgeo.mapsuite.mvcedition.markervalueitem
ThinkGeo.MapSuite.MvcEdition.MarkerValueItem
<!– Class –> This class represents one value in a ValueMarkerStyle.
ValueMarkerStyle:
The ValueMarkerStyle allows you to match data in the FeatureSource with a value string. If the value matches, then we will use the style defined in that item to create the markers.
For example, you may have some data about cities, with each city categorized as either a high, medium or low pollution city. Based on the string values of “High”, “Medium” and “Low”, we can match on these. If a particular feature's data for the column matched “High”, then we would use the high MarkerValueItem's style to create that city's marker.
Public MethodMarkerValueItem Initialize a new instance of the MarkerValueItem class.
Public MethodMarkerValueItem String Initialize a new instance of the MarkerValueItem class using the value string specified.
Public MethodMarkerValueItem String, MarkerStyle Initialize a new instance of the MarkerValueItem class with the value string and custom marker style specified.
Public MethodGetType Object
Public MethodToString Object
Public PropertyCustomMarkerStyle MarkerStyle Gets or sets the style that could be any type of MarkerStyle.
Public PropertyDefaultMarkerStyle PointMarkerStyle Gets or sets the marker style that will be applied to the markers if the CustomMarkerStyle is not defined.
Public PropertyValue String Gets or sets the value that we will use to match with the feature data. If the value matches, we will use the style for this item.
MarkerValueItem()
Overloads
Name Type Description
Go Back
MarkerValueItem(String)
Overloads
value String<!– System.String –> The string to compare with the column value of features, which determines whether or not to use this value item to create the markers.
Go Back
MarkerValueItem(String, MarkerStyle)
Overloads
It is recommended that you do not use this constructor if it is not necessary. Instead, you can set the properties directly on the DefaultMarkerStyle.
customMarkerStyle MarkerStyle<!– ThinkGeo.MapSuite.MvcEdition.MarkerStyle –> The marker style that is applied to the markers with higher priority.
Go Back
Return Type Description
Boolean<!– System.Boolean –>
Int32<!– System.Int32 –>
Type<!– System.Type –>
Void<!– System.Void –>
CustomMarkerStyle
The <strong>CustomMarkerStyle</strong> could be any type of <strong>MarkerStyle</strong>. This style has a higher priority than the <strong>DefaultMarkerStyle</strong>. This means that if you defined both <strong>DefaultMarkerStyle</strong> and <strong>CustomMarkerStyle</strong>, the <strong>CustomMarkerStyle</strong> will be used.
Return Type
<!– ThinkGeo.MapSuite.MvcEdition.MarkerValueItem –> Go Back
DefaultMarkerStyle
Return Type
PointMarkerStyle<!– ThinkGeo.MapSuite.MvcEdition.PointMarkerStyle –>
Value
Return Type
thinkgeo.mapsuite.mvcedition.markervalueitem.1440040131.txt.gz · Last modified: 2015/09/21 03:34 (external edit)
