thinkgeo.mapsuite.mvcedition.layeroverlay
ThinkGeo.MapSuite.MvcEdition.LayerOverlay
Represents an Overlay that contains layers.
    • ThinkGeo.MapSuite.MvcEdition.Overlay
      • ThinkGeo.MapSuite.MvcEdition.LayerOverlay
LayerOverlay()
  • Initialize an instance of the LayerOverlay class.
LayerOverlay(String)
  • Initialize an instance of the LayerOverlay class with the overlay identifier specified.
  • id
    • Description:The identifier string used to retrieve the overlay for collection.
LayerOverlay(String,Boolean,TileType)
  • Initialize an instance of the LayerOverlay class with the overlay identifier, IsBaseOverlay boolean value and the value indicating whether to use tiling.
  • id
  • isBaseOverlay
    • Description:A boolean value that indicates whether this overlay is a base overlay.
  • tileType
    • Type:TileType
    • Description:The TileType that indicates whether this overlay uses tiling.
SetBaseEpsgProjection(String)
  • Sets the EPSG projection of the LayerOverlay when it is a base overlay.
  • epsgProjection
    • Description:A string that represents the projection of the LayerOverlay.
GetBaseEpsgProjection()
  • Returns an EPSG string that indicates the projection of the LayerOverlay.
  • Description:An EPSG string that indicates the projection of the LayerOverlay.
DataBindTo(String,String)
  • controllerName
  • actionName
GetBoundingBox()
  • Gets the smallest extent that includes all of the features of all layers in the LayerOverlay.
  • If you have several layers, with one justified up and to the right and another justified down and to the left, this method will combine all of the current extents to make one composite extent.
  • Description:The smallest extent that includes all of the features of all layers in the LayerOverlay.
Draw(GeoCanvas,Object,RectangleShape,GeographyUnit)
  • Draw all of the layers to the image object using the parameters specified.
  • canvas
    • Type:GeoCanvas
    • Description:The GeoCanvas object that the layers will draw on.
  • nativeImage
    • Description:The image object to which all of the layers will be drawn. Usually it is a bitmap.
  • canvasExtent
    • Description:The extent in which the features of the layers will be drawn.
  • mapUnit
    • Description:The geographic unit that the map will use to draw.
Redraw()
  • Redraw this overlay.
GenerateCacheImages(ZoomLevel,RectangleShape,GeographyUnit)
  • Generates images to the server cache by zoomLevel.
  • This method will generate images to the server cache if you enable the ServerCache on this LayerOverlay. You can use this method to fill your server cache to enhance the performance of your web site.
  • zoomLevel
    • Type:ZoomLevel
    • Description:The zoomlevel at which the images will be generated.
  • cacheExtent
    • Description:The extent of the region for which the cached images will be generated.
GenerateCacheImages(Double,RectangleShape,GeographyUnit)
  • Generates the images to the server cache by scale.
  • scale
    • Description:The scale that is used to calculate the coordinates of the images.
  • cacheExtent
    • Description:The extent of the region for which the cache images will be generated.
ToJson()
FromJson(String)
  • jsonString
DrawCore(GeoCanvas,Object,RectangleShape,GeographyUnit)
  • canvas
    • Type:GeoCanvas
  • nativeImage
  • canvasExtent
  • mapUnit
EhQ=(Page)
  • page
    • Type:Page
  • page
    • Type:Page
TileWidth
Gets or sets the width of each tile if the layer is in MultipleTile mode.
TileHeight
Gets or sets the height of each tile if the layer is in MultipleTile mode.
TransitionEffect
Gets or sets the transition effect to use when the map is zoomed.
TransitionEffectDelayInMilliseconds
TileType
Gets or sets whether or not the LayerOverlay uses tiling.
TileMargin
Gets or sets the number of extra rows and colums of tiles on each side that will surround the minimum grid tiles to cover the map. Used only when in MultipleTile mode.
ServerCache
Gets or sets the server cache in the overlay.
ClientCache
Gets or sets the ClientCache object that contains the configuration for the browser cache of this overlay.
WebImageFormat
Gets or sets the format of the image that is sent to the web browser.
JpegQuality
Gets or sets the quality of the JPEG image that is sent to the web browser. Valid values are between 1 - 100, inclusive.
The JpegQuality property determines the quality of the JPEG image that is sent to the browser if the WebImageFormat is Jpeg. Setting this property to a lower value will reduce the image filesize. The value must be between 1 - 100. The default is 100.
IsMultiThreadDisabled
Gets or sets whether the multi-thread is disabled or not.
Layers
Gets a GeoCollection that contains the layers that will draw on the image that is sent to the browser.
The Layers property holds all of the layers that are used by the Draw method. The Draw method loops through all layers to filter out features and draw with specified styles to the image that will be sent to the browser.
IsVisible
Gets or sets a value that indicates whether the overlay is visible on the map.
WrapDateline
Gets or sets a value that indicates whether the overlay wraps at the date line.
ActionTriggers
Opacity
  • Type:Single
IsVisibleInOverlaySwitcher
IsBaseOverlay
Id
OnClientAutoRefreshTick
AutoRefreshInterval
  • Type:TimeSpan
Attribution
OverlayType
Gets a string that indicates the overlay type.
ExtraParameter
Gets or sets extra parameters for current overlay.
Projection
Gets or sets projection of current overlay for requesting images.
TRU=
ERQ=
thinkgeo.mapsuite.mvcedition.layeroverlay.1442910886.txt.gz · Last modified: 2015/09/22 08:34 by admin
