thinkgeo.mapsuite.mvcedition.custompopup
ThinkGeo.MapSuite.MvcEdition.CustomPopup
<!– Class –> Represents a pop up window whose style and background can be customized.
The <strong>CustomPopup</strong> class provides you an easy way to create your customized popup. You can easily change the popup's color and border by specifying the <strong>BackgroundColor</strong>, <strong>BorderColor</strong> and <strong>BorderWidth</strong> properties. Or you can totally change the popup's appearance by putting a background image behind. With the <strong>BackgroundImageVirtualPath</strong> property, you can customize the popup in any shape you like.
Public MethodCustomPopup Initialize an instance of the CustomPopup class.
Public MethodCustomPopup String Initialize an instance of the CustomPopup class.
Public MethodCustomPopup String, PointShape Initialize an instance of the CustomPopup class.
Public MethodCustomPopup String, PointShape, String Initialize an instance of the CustomPopup class.
Public MethodCustomPopup String, PointShape, String, Int32, Int32 Initialize an instance of the CustomPopup class.
Public MethodCustomPopup String, PointShape, String, Int32, Int32, Boolean Initialize an instance of the CustomPopup class.
Public MethodCustomPopup String, PointShape, String, Int32, Int32, Boolean, Boolean Initialize an instance of the CustomPopup class.
Public MethodCustomPopup String, PointShape, String, Int32, Int32, Boolean, Boolean, Int32 Initialize an instance of the CustomPopup class.
Public MethodCloneShallow Popup Creates a shallow copy of the current popup object.
Public MethodFromJson String Popup
Public MethodGetType Object
Public MethodToJson Popup Returns a JSON string which contains the popup's information and is used to create the popup at the client side.
Public MethodToString Object
Public PropertyAutoPan Boolean Popup Gets or sets a value that indicates whether to pan the map to display the entire popup if the popup is not fully displayed.
Public PropertyAutoSize Boolean Popup Gets or sets a value that indicates whether the popup is automatically resized to fit its contents.
Public PropertyBackgroundColor GeoColor Gets or sets the color applied to the background of the popup object.
Public PropertyBackgroundImageVirtualPath String Gets or sets the virtual path of the background image. You can set any image as the popup's background.
Public PropertyBorderColor GeoColor Gets or sets the color applied to the border of the popup object.
Public PropertyBorderWidth Int32 Gets or sets the width of the popup's border.
Public PropertyContentHtml String Gets or sets the content HTML of the popup window.
Public PropertyHasCloseButton Boolean Popup Gets or sets a value that indicates whether the popup window has a close button in the upper right corner.
Public PropertyHeight Int32 Popup Gets or sets the height of the popup.
Public PropertyId String Popup Gets the identifier by which you can find the popup.
Public PropertyIsVisible Boolean Popup Gets or sets a value that indicates whether the popup is visible on the map.
Public PropertyOffsetXInPixels Int32 Popup Gets or sets the popup's pixel offset in X direction.
Public PropertyOffsetYInPixels Int32 Popup Gets or sets the popup's pixel offset in Y direction.
Public PropertyOpacity Single Popup Gets or sets the opacity level of the popup.
Public PropertyPosition PointShape Popup Gets or sets a point shape in world coordinates that represents the position of the popup.
Public PropertyWidth Int32 Popup Gets or sets the width of the popup.
Protected PropertyPopupType String Popup(overriden) Gets a string that represents the type of the Popup object.
CustomPopup()
Overloads
Name Type Description
Go Back
CustomPopup(String)
Overloads
id String<!– System.String –>
Go Back
CustomPopup(String, PointShape)
Overloads
position PointShape<!– ThinkGeo.MapSuite.Core.PointShape –>
Go Back
CustomPopup(String, PointShape, String)
Overloads
contentHtml String<!– System.String –>
Go Back
CustomPopup(String, PointShape, String, Int32, Int32)
Overloads
width Int32<!– System.Int32 –>
height Int32<!– System.Int32 –>
Go Back
CustomPopup(String, PointShape, String, Int32, Int32, Boolean)
Overloads
autoPan Boolean<!– System.Boolean –>
Go Back
CustomPopup(String, PointShape, String, Int32, Int32, Boolean, Boolean)
Overloads
hasCloseButton Boolean<!– System.Boolean –>
Go Back
CustomPopup(String, PointShape, String, Int32, Int32, Boolean, Boolean, Int32)
Overloads
borderWidth Int32<!– System.Int32 –>
Go Back
CloneShallow()
Return Type Description
Popup<!– ThinkGeo.MapSuite.MvcEdition.Popup –>
<!– ThinkGeo.MapSuite.MvcEdition.Popup –> Go Back
FromJson(String)
Void<!– System.Void –>
jsonString String<!– System.String –>
Type<!– System.Type –>
ToJson()
String<!– System.String –> A string that is used to create the popup at the client side.
AutoPan
Return Type
AutoSize
Return Type
BackgroundColor
Return Type
GeoColor<!– ThinkGeo.MapSuite.Core.GeoColor –>
<!– ThinkGeo.MapSuite.MvcEdition.CustomPopup –> Go Back
Return Type
BorderColor
Return Type
BorderWidth
Return Type
ContentHtml
Return Type
HasCloseButton
Return Type
Height
Return Type
Id
Return Type
IsVisible
Return Type
OffsetXInPixels
Return Type
OffsetYInPixels
Return Type
Opacity
The <strong>Opacity</strong> property enables you to specify a level of transparency for the popup. When this property is set to a value less than 100 percent (1.00), the entire popup (including its content) is made more transparent. The lower the value, the more transparent it is. Setting this property to a value of 0 percent (0.00) makes the popup completely invisible.
Return Type
Single<!– System.Single –>
Position
Return Type
Width
Return Type
PopupType
Return Type
<!– ThinkGeo.MapSuite.MvcEdition.Popup(overriden) –> Go Back
thinkgeo.mapsuite.mvcedition.custompopup.1440040131.txt.gz · Last modified: 2015/09/21 03:32 (external edit)
