<!– Class –> Provides data for the VertexRemoving. event.
*System.Object System.EventArgs *ThinkGeo.MapSuite.iOSEdition.VertexRemovingEditInteractiveOverlayEventArgs
VertexRemovingEditInteractiveOverlayEventArgs | This is the default constructor of this parameter. | ||
VertexRemovingEditInteractiveOverlayEventArgs | Boolean, Feature, Vertex | This is the commonly used constructor. |
AffectedVertexFeature | Feature | This property gets or sets the Feature to be used to remove vertex. | |
Cancel | Boolean | This property gets or sets the action to be canceled or not. | |
RemovingVertex | Vertex | This property gets or sets the vertex to be removed. |
| cancel | Boolean<!– System.Boolean –> | This parameter specified the cancel property. |
| affectedVertexFeature | Feature<!– ThinkGeo.MapSuite.Core.Feature –> | This parameter specified the affectedVertex feature property. |
| removingVertex | Vertex<!– ThinkGeo.MapSuite.Core.Vertex –> | This parameter specified the target vertex to be removed. |
<!– ThinkGeo.MapSuite.iOSEdition.VertexRemovingEditInteractiveOverlayEventArgs –> Go Back
