thinkgeo.mapsuite.iosedition.vertexmovingeditinteractiveoverlayeventargs
ThinkGeo.MapSuite.iOSEdition.VertexMovingEditInteractiveOverlayEventArgs
<!– Class –> Provides data for the VertexMoving. event.
Public MethodVertexMovingEditInteractiveOverlayEventArgs This is the default constructor of this parameter.
Public MethodVertexMovingEditInteractiveOverlayEventArgs Boolean, Feature, Vertex This is the commonly used constructor.
Public MethodVertexMovingEditInteractiveOverlayEventArgs Boolean, Feature, Vertex, PointShape Initializes a new instance of the class.
Public MethodGetType Object
Public MethodToString Object
Public PropertyAffectedVertexFeature Feature This property gets or sets the Feature to be used to move vertex.
Public PropertyCancel Boolean This property gets or sets the action to be canceled or not.
Public PropertyMovingVertex Vertex This property gets or sets the vertex to be moved.
Public PropertyTargetVertex PointShape Gets or sets the target vertex.
VertexMovingEditInteractiveOverlayEventArgs()
Name Type Description
Go Back
VertexMovingEditInteractiveOverlayEventArgs(Boolean, Feature, Vertex)
cancel Boolean<!– System.Boolean –> This parameter specified the cancel property.
affectedVertexFeature Feature<!– ThinkGeo.MapSuite.Core.Feature –> This parameter specified the affectedVertex feature property.
movingVertex Vertex<!– ThinkGeo.MapSuite.Core.Vertex –> This parameter specified the target vertex to be moved.
Go Back
VertexMovingEditInteractiveOverlayEventArgs(Boolean, Feature, Vertex, PointShape)
cancel Boolean<!– System.Boolean –> if set to true cancel.
affectedVertexFeature Feature<!– ThinkGeo.MapSuite.Core.Feature –> The affected vertex feature.
movingVertex Vertex<!– ThinkGeo.MapSuite.Core.Vertex –> The moving vertex.
targetVertex PointShape<!– ThinkGeo.MapSuite.Core.PointShape –> The target vertex.
Go Back
Return Type Description
Int32<!– System.Int32 –>
Type<!– System.Type –>
String<!– System.String –>
Void<!– System.Void –>
Return Type
<!– ThinkGeo.MapSuite.iOSEdition.VertexMovingEditInteractiveOverlayEventArgs –> Go Back
Cancel
Return Type
MovingVertex
Return Type
TargetVertex
Return Type
thinkgeo.mapsuite.iosedition.vertexmovingeditinteractiveoverlayeventargs.1440040131.txt.gz · Last modified: 2015/09/21 08:35 (external edit)
