<!– Class –> Provides data for the VertexAdding. event.
*System.Object System.EventArgs *ThinkGeo.MapSuite.iOSEdition.VertexAddingTrackInteractiveOverlayEventArgs
![]() | This is the default constructor of this parameter. | ||
![]() | Vertex, Feature, Boolean | This is the commonly used constructor. |
![]() | Object | Object | |
![]() | Object | ||
![]() | Object | ||
![]() | Object |
![]() | Object | ||
![]() | Object |
![]() | Vertex | This property gets or sets the feature to be used to add vertex on when tracking shape. | |
![]() | Feature | This property gets or sets the Feature to be used to add vertex to. | |
![]() | Boolean | This property gets or sets the action to be canceled or not. |
Name | Type | Description |
addingVertex | Vertex<!– ThinkGeo.MapSuite.Core.Vertex –> | This parameter specified the vertex is going to be added. |
affectedFeature | Feature<!– ThinkGeo.MapSuite.Core.Feature –> | This parameter specified the feature to be used to add vertex on when tracking shape. |
cancel | Boolean<!– System.Boolean –> | This parameter specified the cancel property. |
Return Type | Description |
Int32<!– System.Int32 –> |
Type<!– System.Type –> |
String<!– System.String –> |
Void<!– System.Void –> |
Return Type |
<!– ThinkGeo.MapSuite.iOSEdition.VertexAddingTrackInteractiveOverlayEventArgs –> Go Back
Return Type |
Return Type |
