<!– Class –> This class represents an overlay to place popups on the map.
PopupOverlay | Initializes a new instance of the class. | ||
PopupOverlay | IEnumerable<Popup> | Initializes a new instance of the class. |
Close | Overlay | Closes this instance. | |
Dispose | Overlay | Disposes this instance. | |
Draw | MapArguments, OverlayRefreshType | Overlay | This method draws the overlay by the specified arguments. |
GetBoundingBox | Overlay | Gets the bounding box. | |
Initialize | MapArguments | Overlay | Initializes the specified map arguments. |
PostTransform | TransformArguments, MapArguments | Overlay | Posts the transform for the overlay. |
Refresh | Overlay | Refreshes this instance. | |
CloseCore | Overlay | Closes the core. | |
Dispose | Boolean | Overlay(overriden) | Releases unmanaged and - optionally - managed resources. |
DrawCore | MapArguments, OverlayRefreshType | Overlay(overriden) | This method draws the popups by the specified targetExtent. |
DrawException | GeoCanvas, Exception | Overlay | Draws the exception. |
DrawExceptionCore | GeoCanvas, Exception | Overlay | Draws the exception core. |
Finalize | Object(overriden) | ||
GetBoundingBoxCore | Overlay(overriden) | This method returns a bounding box to hold all popups. | |
InitializeCore | MapArguments | Overlay | Initializes the core. |
MemberwiseClone | Object | ||
OnDrawingException | DrawingExceptionOverlayEventArgs | Overlay | Handles the event. |
OnDrawnException | DrawnExceptionOverlayEventArgs | Overlay | Handles the event. |
PostTransformCore | TransformArguments, MapArguments | Overlay(overriden) | Posts the transform for the overlay. |
RefreshCore | Overlay | Refreshes the core. |
Attribution | String | Overlay | Gets or sets the attribution. |
DrawingExceptionMode | DrawingExceptionMode | Overlay | This property gets and sets the DrawingExceptionMode used when an exception occurs during drawing. |
DrawingQuality | DrawingQuality | Overlay | Gets or sets the drawing quality. |
IsEmpty | Boolean | Overlay | Gets a value indicating whether this instance is empty. |
IsVisible | Boolean | Overlay | Gets or sets a value indicating whether this instance is visible. |
MapArguments | MapArguments | Overlay | Gets or sets the map arguments. |
Name | String | Overlay | Gets or sets the name. |
Opacity | Double | Overlay | Gets or sets the opacity. |
OverlayView | UIView | Overlay | Gets or sets the overlay view. |
Popups | GeoCollection<Popup> | This property gets a collection of popup that are added into this overlay. |
DrawingException | DrawingExceptionOverlayEventArgs | Overlay | This event raises when exception. |
DrawnException | DrawnExceptionOverlayEventArgs | Overlay | This event raises when exception. |
| popups | IEnumerable<Popup><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.iOSEdition.Popup} –> | The popups. |
<!– ThinkGeo.MapSuite.iOSEdition.Overlay –> Go Back
| mapArguments | MapArguments<!– ThinkGeo.MapSuite.iOSEdition.MapArguments –> | This parameter indicates an mapArguments to draw the overlay. |
| refreshType | OverlayRefreshType<!– ThinkGeo.MapSuite.iOSEdition.OverlayRefreshType –> | This parameter indicates whether this overlay needs to be refresh or not. |
| RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | A RectangleShape value for the overlay. |
| mapArguments | MapArguments<!– ThinkGeo.MapSuite.iOSEdition.MapArguments –> | The map arguments. |
| transformInfo | TransformArguments<!– ThinkGeo.MapSuite.iOSEdition.TransformArguments –> | The transform information. |
Closes the core.
| isDisposing | Boolean<!– System.Boolean –> | true to release both managed and unmanaged resources; false to release only unmanaged resources. |
<!– ThinkGeo.MapSuite.iOSEdition.Overlay(overriden) –> Go Back
| mapArguments | MapArguments<!– ThinkGeo.MapSuite.iOSEdition.MapArguments –> | This parameter indicates an mapArguments to draw the popups. |
| geoCanvas | GeoCanvas<!– ThinkGeo.MapSuite.Core.GeoCanvas –> | The geo canvas. |
| exception | Exception<!– System.Exception –> | The exception. |
| ex | Exception<!– System.Exception –> | The ex. |
| RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | A RectangleShape value that to hold all popups. |
| mapArgument | MapArguments<!– ThinkGeo.MapSuite.iOSEdition.MapArguments –> | The map argument. |
Handles the event.
| args | DrawingExceptionOverlayEventArgs<!– ThinkGeo.MapSuite.iOSEdition.DrawingExceptionOverlayEventArgs –> | The instance containing the event data. |
Handles the event.
| args | DrawnExceptionOverlayEventArgs<!– ThinkGeo.MapSuite.iOSEdition.DrawnExceptionOverlayEventArgs –> | The instance containing the event data. |
Refreshes the core.
| DrawingQuality<!– ThinkGeo.MapSuite.Core.DrawingQuality –> |
| UIView<!– MonoTouch.UIKit.UIView –> |
| GeoCollection<Popup><!– ThinkGeo.MapSuite.Core.GeoCollection{ThinkGeo.MapSuite.iOSEdition.Popup} –> |
<!– ThinkGeo.MapSuite.iOSEdition.PopupOverlay –> Go Back
| Event Arguments |
| Event Arguments |
NOTOC iOSEdition ThinkGeo.MapSuite.iOSEdition UpdateDocumentation
