thinkgeo.mapsuite.desktopedition.worldmapkitwmsdesktopoverlay
Table of Contents
ThinkGeo.MapSuite.DesktopEdition.WorldMapKitWmsDesktopOverlay
<!– Class –> This class is used in Desktop Edition to access the WorldMapKit Web Map Service (WMS).
Public MethodWorldMapKitWmsDesktopOverlay This is the constructor of the class.
Public MethodWorldMapKitWmsDesktopOverlay WorldMapKitLayerType
Public MethodWorldMapKitWmsDesktopOverlay String, String This is the constructor of the class.
Public MethodWorldMapKitWmsDesktopOverlay WorldMapKitLayerType, String, String
Public MethodWorldMapKitWmsDesktopOverlay WebProxy, String, String This is the constructor of the class.
Public MethodWorldMapKitWmsDesktopOverlay WorldMapKitLayerType, WebProxy, String, String
Public MethodClearCache This method will clear the cache for the Overlay.
Public MethodDraw GeoCanvas Overlay This method draws the Overlay.
Public MethodDrawPreview GeoCanvas Overlay This method will be used to draw preview tiles to the canvas.
Public MethodGetType Object
Public MethodRefresh GeoCanvas, RectangleShape Overlay
Public MethodRequestDrawing IEnumerable<RectangleShape>, TimeSpan, RequestDrawingBufferTimeType Overlay
Public MethodRequestDrawing RectangleShape, TimeSpan, RequestDrawingBufferTimeType Overlay
Public MethodRequestDrawing RectangleShape, TimeSpan Overlay
Public MethodRequestDrawing TimeSpan, RequestDrawingBufferTimeType Overlay
Public MethodRequestDrawing TimeSpan Overlay
Public MethodRequestDrawing IEnumerable<RectangleShape> Overlay
Public MethodRequestDrawing RectangleShape Overlay
Public MethodRequestDrawing IEnumerable<RectangleShape>, TimeSpan Overlay
Public MethodRequestDrawing Overlay
Public MethodToString Object
Protected MethodDrawAttributionCore GeoCanvas Overlay
Protected MethodDrawCore GeoCanvas Overlay(overriden) This method draws the WorldMapKitDesktopOverlay.
Protected MethodDrawException GeoCanvas, Exception Overlay This method will draw on the canvas when an exception occurs during the drawing process.
Protected MethodDrawExceptionCore GeoCanvas, Exception Overlay(overriden) This method will draw on the canvas when the layer.Draw throw exception and the DrawExceptionMode is set to DrawException instead of ThrowException.
Protected MethodDrawPreviewCore GeoCanvas Overlay(overriden) This method overrides its DrawPreviewCore virtual method in its base class Overlay.
Protected MethodOnDrawing DrawingOverlayEventArgs Overlay This event will be fired before Overlay is drawn.
Protected MethodOnDrawingAttribution DrawingAttributionOverlayEventArgs Overlay
Protected MethodOnDrawn DrawnOverlayEventArgs Overlay This event will be fired after Overlay is drawn.
Protected MethodOnDrawnAttribution DrawnAttributionOverlayEventArgs Overlay
Protected MethodOnRequestedDrawing RequestedDrawingOverlayEventArgs Overlay
Protected MethodOnRequestingDrawing RequestingDrawingOverlayEventArgs Overlay
Protected MethodOnSendingWebRequest SendingWebRequestEventArgs
Protected MethodOnSentWebRequest SentWebRequestEventArgs
Protected MethodRefreshCore GeoCanvas, RectangleShape Overlay
Public PropertyAttribution String Overlay
Public PropertyAutoRefreshInterval TimeSpan Overlay
Public PropertyClientId String Gets or sets a value that is your Client Id.
Public PropertyDrawingExceptionMode DrawingExceptionMode Overlay This property gets and sets the DrawingExceptionMode used when an exception occurs during drawing.
Public PropertyDrawingTime TimeSpan Overlay This property gets the last drawing time for the Overlay.
Public PropertyIsBase Boolean Overlay Gets or sets a value that indicates whether the overlay is a base overlay. The default value is false.
Public PropertyIsEmpty Boolean Overlay This property can be overridden by its base class. If it is not overridden, its default return value will be false. If this property is empty, we can skip drawing to achieve better performance.
Public PropertyIsVisible Boolean Overlay Gets or sets a value that indicates whether the overlay is visible on the map.
Public PropertyLayerType WorldMapKitLayerType
Public PropertyLock OverlayLock Overlay This property gets the OverlayLock object.
Public PropertyMapType WorldMapKitMapType
Public PropertyName String Overlay Gets or sets the name of the overlay, which can be used to represent a specific overlay.
Public PropertyPreviewTileCache BitmapTileCache Overlay This property gets or sets the preview tile cache system. In order for this system to work, you must be in multi-threaded mode and have the tile cache set.
Public PropertyPrivateKey String Gets or sets a value that is unique to your client ID, please keep your key secure.
Public PropertyProjection WorldMapKitProjection Gets or sets the Projection of the Overlay.
Public PropertyTileCache BitmapTileCache Overlay(overriden) Gets or sets the BitmapTileCache for the Overlay.
Public PropertyWebProxy WebProxy This property gets or sets the proxy used for requesting a Web Response.
WorldMapKitWmsDesktopOverlay()
If you use this constructor, you must set the properties manually before use, otherwise it will use their default values.
Name Type Description
Go Back
WorldMapKitWmsDesktopOverlay(WorldMapKitLayerType)
layerType WorldMapKitLayerType<!– ThinkGeo.MapSuite.Core.WorldMapKitLayerType –>
Go Back
WorldMapKitWmsDesktopOverlay(String, String)
clientId String<!– System.String –> The clientId for the WMS Server.
privateKey String<!– System.String –> The privateKey for the WMS Server.
Go Back
WorldMapKitWmsDesktopOverlay(WorldMapKitLayerType, String, String)
Go Back
WorldMapKitWmsDesktopOverlay(WebProxy, String, String)
webProxy WebProxy<!– System.Net.WebProxy –> Proxy to use for the WMS Server.
Go Back
WorldMapKitWmsDesktopOverlay(WorldMapKitLayerType, WebProxy, String, String)
Go Back
ClearCache()
Return Type Description
Void<!– System.Void –>
<!– ThinkGeo.MapSuite.DesktopEdition.WorldMapKitWmsDesktopOverlay –> Go Back
Draw(GeoCanvas)
This method is the concrete wrapper for the abstract method DrawCore. This method draws the representation of the overlay based on the extent you provided.As this is a concrete public method that wraps a Core method, we reserve the right to add events and other logic to pre- or post-process data returned by the Core version of the method. In this way, we leave our framework open on our end, but also allow you the developer to extend our logic to suit your needs. If you have questions about this, please contact our support team as we would be happy to work with you on extending our framework.
canvas GeoCanvas<!– ThinkGeo.MapSuite.Core.GeoCanvas –> This parameter is the canvas object to draw on.
<!– ThinkGeo.MapSuite.DesktopEdition.Overlay –> Go Back
DrawPreview(GeoCanvas)
TilesExistingType<!– ThinkGeo.MapSuite.DesktopEdition.TilesExistingType –> The tile existing type, which indicates whether any tiles exist.
Boolean<!– System.Boolean –>
Int32<!– System.Int32 –>
Type<!– System.Type –>
Refresh(GeoCanvas, RectangleShape)
extent RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –>
RequestDrawing(IEnumerable<RectangleShape>, TimeSpan, RequestDrawingBufferTimeType)
extentsToRefresh IEnumerable<RectangleShape><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.Core.RectangleShape} –>
bufferTime TimeSpan<!– System.TimeSpan –>
bufferTimeType RequestDrawingBufferTimeType<!– ThinkGeo.MapSuite.Core.RequestDrawingBufferTimeType –>
RequestDrawing(RectangleShape, TimeSpan, RequestDrawingBufferTimeType)
extentToRefresh RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –>
RequestDrawing(RectangleShape, TimeSpan)
RequestDrawing(TimeSpan, RequestDrawingBufferTimeType)
RequestDrawing(TimeSpan)
RequestDrawing(IEnumerable<RectangleShape>, TimeSpan)
RequestDrawing()
DrawAttributionCore(GeoCanvas)
DrawCore(GeoCanvas)
This method draws the representation of the overlay based on the extent you provided.When implementing this abstract method, consider each feature and its column data values. You can use the full power of the GeoCanvas to do the drawing. If you need column data for a feature, be sure to override the GetRequiredColumnNamesCore and add the columns you need to the collection. In many of the styles, we add properties that allow the user to specify which field they need; then, in the GetRequiredColumnNamesCore, we read that property and add it to the collection.
canvas GeoCanvas<!– ThinkGeo.MapSuite.Core.GeoCanvas –> This parameter is the canvas object or a GeoImage to draw on.
<!– ThinkGeo.MapSuite.DesktopEdition.Overlay(overriden) –> Go Back
DrawException(GeoCanvas, Exception)
e Exception<!– System.Exception –> This parameter is the exception that is occurring.
DrawExceptionCore(GeoCanvas, Exception)
canvas GeoCanvas<!– ThinkGeo.MapSuite.Core.GeoCanvas –> The target canvas to draw the layer.
e Exception<!– System.Exception –> The exception thrown when layer.Draw().
DrawPreviewCore(GeoCanvas)
OnDrawing(DrawingOverlayEventArgs)
e DrawingOverlayEventArgs<!– ThinkGeo.MapSuite.DesktopEdition.DrawingOverlayEventArgs –> The OverlayDrawingEventArgs passed for the event raised.
OnDrawingAttribution(DrawingAttributionOverlayEventArgs)
args DrawingAttributionOverlayEventArgs<!– ThinkGeo.MapSuite.DesktopEdition.DrawingAttributionOverlayEventArgs –>
OnDrawn(DrawnOverlayEventArgs)
e DrawnOverlayEventArgs<!– ThinkGeo.MapSuite.DesktopEdition.DrawnOverlayEventArgs –> The OverlayDrawnEventArgs passed for the event raised.
OnDrawnAttribution(DrawnAttributionOverlayEventArgs)
args DrawnAttributionOverlayEventArgs<!– ThinkGeo.MapSuite.DesktopEdition.DrawnAttributionOverlayEventArgs –>
OnRequestedDrawing(RequestedDrawingOverlayEventArgs)
eventArgs RequestedDrawingOverlayEventArgs<!– ThinkGeo.MapSuite.DesktopEdition.RequestedDrawingOverlayEventArgs –>
OnRequestingDrawing(RequestingDrawingOverlayEventArgs)
eventArgs RequestingDrawingOverlayEventArgs<!– ThinkGeo.MapSuite.DesktopEdition.RequestingDrawingOverlayEventArgs –>
OnSendingWebRequest(SendingWebRequestEventArgs)
e SendingWebRequestEventArgs<!– ThinkGeo.MapSuite.Core.SendingWebRequestEventArgs –>
OnSentWebRequest(SentWebRequestEventArgs)
e SentWebRequestEventArgs<!– ThinkGeo.MapSuite.Core.SentWebRequestEventArgs –>
RefreshCore(GeoCanvas, RectangleShape)
Attribution
Return Type
AutoRefreshInterval
Return Type
ClientId
Return Type
Return Type
DrawingExceptionMode<!– ThinkGeo.MapSuite.Core.DrawingExceptionMode –>
DrawingTime
We track the drawing time for the Overlay and report it back in this method. This is useful to determine the speed of various Overlays.
Return Type
IsBase
Return Type
IsEmpty
Return Type
IsVisible
Return Type
LayerType
Return Type
Lock
Return Type
OverlayLock<!– ThinkGeo.MapSuite.DesktopEdition.OverlayLock –>
MapType
Return Type
WorldMapKitMapType<!– ThinkGeo.MapSuite.Core.WorldMapKitMapType –>
Return Type
PreviewTileCache
Return Type
BitmapTileCache<!– ThinkGeo.MapSuite.Core.BitmapTileCache –>
PrivateKey
Return Type
Projection
Return Type
WorldMapKitProjection<!– ThinkGeo.MapSuite.Core.WorldMapKitProjection –>
TileCache
Return Type
WebProxy
Return Type
Drawing
This event will be fired before the Overlay is drawn.
Event Arguments
Event Arguments
DrawingAttribution
Event Arguments
Event Arguments
Drawn
This event will be fired after the Overlay is drawn.
Event Arguments
Event Arguments
DrawnAttribution
Event Arguments
Event Arguments
RequestedDrawing
Event Arguments
Event Arguments
RequestingDrawing
Event Arguments
Event Arguments
SendingWebRequest
Event Arguments
Event Arguments
SentWebRequest
Event Arguments
Event Arguments
NOTOC DesktopEdition ThinkGeo.MapSuite.DesktopEdition UpdateDocumentation
thinkgeo.mapsuite.desktopedition.worldmapkitwmsdesktopoverlay.1440040130.txt.gz · Last modified: 2015/09/18 03:05 (external edit)
