<!– Class –> This class specifies the InterativeResult when dealing with the Interative method in InterativeOverlay.
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.InteractiveResult” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.InteractiveResult</a>
*System.Object **ThinkGeo.MapSuite.DesktopEdition.InteractiveResult
InteractiveResult | This is the default constructor of this parameter. | ||
InteractiveResult | InteractiveOverlayDrawType, ProcessOtherOverlaysMode | This is the commonly used constructor. |
DrawThisOverlay | InteractiveOverlayDrawType | This property gets and sets the DrawThisOverlay type, which indicates whether to draw this overlay or not. | |
NewCurrentExtent | RectangleShape | This property gets and sets the new current extent if the interative action affects the extent. | |
ProcessOtherOverlaysMode | ProcessOtherOverlaysMode | This property gets and sets the DrawThisOverlay type, which indicates how to process other overlays. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.InteractiveResult#InteractiveResult.28InteractiveOverlayDrawType.2C_ProcessOtherOverlaysMode.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.InteractiveResult#InteractiveResult.28InteractiveOverlayDrawType.2C_ProcessOtherOverlaysMode.29</a>
| interactiveOverlayDrawType | InteractiveOverlayDrawType<!– ThinkGeo.MapSuite.DesktopEdition.InteractiveOverlayDrawType –> | This parameter specifies the interactiveOverlayDrawType used to construct the class. |
| processOtherOverlays | ProcessOtherOverlaysMode<!– ThinkGeo.MapSuite.DesktopEdition.ProcessOtherOverlaysMode –> | This parameter specifies the processOtherOverlays used to construct the class. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.InteractiveResult#Equals.28Object.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.InteractiveResult#Equals.28Object.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.InteractiveResult#GetHashCode.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.InteractiveResult#GetHashCode.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.InteractiveResult#GetType.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.InteractiveResult#GetType.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.InteractiveResult#ToString.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.InteractiveResult#ToString.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.InteractiveResult#Finalize.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.InteractiveResult#Finalize.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.InteractiveResult#MemberwiseClone.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.InteractiveResult#MemberwiseClone.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.InteractiveResult#DrawThisOverlay” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.InteractiveResult#DrawThisOverlay</a>
<!– ThinkGeo.MapSuite.DesktopEdition.InteractiveResult –> Go Back
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.InteractiveResult#NewCurrentExtent” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.InteractiveResult#NewCurrentExtent</a>
| RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> |
