<!– Class –> This class represents the Overlay used to display a Google Map.
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay</a>
*System.Object ThinkGeo.MapSuite.DesktopEdition.Overlay *ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay
![]() | This is the constructor of the class. | ||
![]() | String, String, String | This is the constructor the for the class. | |
![]() | String, String, String, WebProxy | This is the constructor the for the class. |
![]() | Releases the unmanaged resources. | ||
![]() | GeoCanvas | Overlay | This method draws the Overlay. |
![]() | GeoCanvas | Overlay | This method will be used to draw preview tiles to the canvas. |
![]() | Object | Object | |
![]() | Object | ||
![]() | This method gets a string that represents the picture format from Google Maps. | ||
![]() | Object | ||
![]() | GeoCanvas, RectangleShape | Overlay | |
![]() | IEnumerable<RectangleShape>, TimeSpan, RequestDrawingBufferTimeType | Overlay | |
![]() | IEnumerable<RectangleShape>, TimeSpan | Overlay | |
![]() | TimeSpan, RequestDrawingBufferTimeType | Overlay | |
![]() | TimeSpan | Overlay | |
![]() | IEnumerable<RectangleShape> | Overlay | |
![]() | RectangleShape | Overlay | |
![]() | Overlay | ||
![]() | RectangleShape, TimeSpan, RequestDrawingBufferTimeType | Overlay | |
![]() | RectangleShape, TimeSpan | Overlay | |
![]() | Object |
![]() | GeoCanvas | Overlay | |
![]() | GeoCanvas | Overlay(overriden) | This method draws the GoogleMapsOverlay. |
![]() | GeoCanvas, Exception | Overlay | This method will draw on the canvas when an exception occurs during the drawing process. |
![]() | GeoCanvas, Exception | Overlay | This method is the Core method of DrawException, which can be overridden if you want to change its logic. This method will draw on the canvas when an exception occurs during drawing process. |
![]() | GeoCanvas | Overlay | This is the core method of DrawPreview which is intended to be overridden by its concrete sub class. |
![]() | Object | ||
![]() | Object | ||
![]() | DrawingOverlayEventArgs | Overlay | This event will be fired before Overlay is drawn. |
![]() | DrawingAttributionOverlayEventArgs | Overlay | |
![]() | DrawnOverlayEventArgs | Overlay | This event will be fired after Overlay is drawn. |
![]() | DrawnAttributionOverlayEventArgs | Overlay | |
![]() | RequestedDrawingOverlayEventArgs | Overlay | |
![]() | RequestingDrawingOverlayEventArgs | Overlay | |
![]() | SendingWebRequestEventArgs | ||
![]() | SentWebRequestEventArgs | ||
![]() | String | Overlay | |
![]() | String | Gets or sets a value to access the special features of Google Maps API Premier, you must provide a client ID when accessing any of the Premier API libraries or services. When registering for Google Maps API Premier, you will receive this client ID from Google Enterprise Support. All client IDs begin with a gme- prefix. | |
![]() | DrawingExceptionMode | Overlay | This property gets and sets the DrawingExceptionMode used when an exception occurs during drawing. |
![]() | TimeSpan | Overlay | This property gets the last drawing time for the Overlay. |
![]() | Boolean | Overlay | Gets or sets a value that indicates whether the overlay is a base overlay. The default value is false. |
![]() | Boolean | Overlay | This property can be overridden by its base class. If it is not overridden, its default return value will be false. If this property is empty, we can skip drawing to achieve better performance. |
![]() | Boolean | Overlay | Gets or sets a value that indicates whether the overlay is visible on the map. |
![]() | OverlayLock | Overlay | This property gets the OverlayLock object. |
![]() | GoogleMapsMapType | This property gets or sets the map types available from Google Maps. | |
![]() | Double | ||
![]() | String | Overlay | Gets or sets the name of the overlay, which can be used to represent a specific overlay. |
![]() | BitmapTileCache | Overlay | This property gets or sets the preview tile cache system. In order for this system to work, you must be in multi-threaded mode and have the tile cache set. |
![]() | String | Gets or sets a value that is unique to your client ID, please keep your key secure. | |
![]() | BitmapTileCache | ||
![]() | Projection | ||
![]() | BitmapTileCache | Overlay(overriden) | |
![]() | TimeSpan | ||
![]() | GoogleMapsTileMode | ||
![]() | Int32 | Gets or sets a value represents the request timeout from the GoogleMaps server. | |
![]() | WebProxy | This property gets or sets the proxy used for requesting a Web Response. |
![]() | DrawingOverlayEventArgs | Overlay | This event will be fired before the Overlay is drawn. |
![]() | DrawnOverlayEventArgs | Overlay | This event will be fired after the Overlay is drawn. |
If you use this constructor, you have to set the properties manually before use, otherwise it will use their default values.
Name | Type | Description |
This constructor initializes a new layer and assgin a license key.
cacheDirectory | String<!– System.String –> | The cacheDirectory for the GoogleMapsOverlay. |
clientId | String<!– System.String –> | The clientId for the GoogleMapsOverlay. |
privateKey | String<!– System.String –> | The privateKey for the GoogleMapsOverlay. |
webProxy | WebProxy<!– System.Net.WebProxy –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#Dispose.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#Dispose.28.29</a>
Return Type | Description |
Void<!– System.Void –> |
<!– ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay –> Go Back
This method is the concrete wrapper for the abstract method DrawCore. This method draws the representation of the overlay based on the extent you provided.As this is a concrete public method that wraps a Core method, we reserve the right to add events and other logic to pre- or post-process data returned by the Core version of the method. In this way, we leave our framework open on our end, but also allow you the developer to extend our logic to suit your needs. If you have questions about this, please contact our support team as we would be happy to work with you on extending our framework.
canvas | GeoCanvas<!– ThinkGeo.MapSuite.Core.GeoCanvas –> | This parameter is the canvas object to draw on. |
<!– ThinkGeo.MapSuite.DesktopEdition.Overlay –> Go Back
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#DrawPreview.28GeoCanvas.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#DrawPreview.28GeoCanvas.29</a>
TilesExistingType<!– ThinkGeo.MapSuite.DesktopEdition.TilesExistingType –> | The tile existing type, which indicates whether any tiles exist. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#Equals.28Object.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#Equals.28Object.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#GetHashCode.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#GetHashCode.28.29</a>
Int32<!– System.Int32 –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#GetPictureFormatString.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#GetPictureFormatString.28.29</a>
String<!– System.String –> | Returns a string representing the picture format from GoogleMaps. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#GetType.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#GetType.28.29</a>
Type<!– System.Type –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#Refresh.28GeoCanvas.2C_RectangleShape.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#Refresh.28GeoCanvas.2C_RectangleShape.29</a>
canvas | GeoCanvas<!– ThinkGeo.MapSuite.Core.GeoCanvas –> | |
extent | RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> |
extentsToRefresh | IEnumerable<RectangleShape><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.Core.RectangleShape} –> | |
bufferTime | TimeSpan<!– System.TimeSpan –> | |
bufferTimeType | RequestDrawingBufferTimeType<!– ThinkGeo.MapSuite.Core.RequestDrawingBufferTimeType –> |
extentToRefresh | RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> |
extentToRefresh | RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#ToString.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#ToString.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#DrawAttributionCore.28GeoCanvas.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#DrawAttributionCore.28GeoCanvas.29</a>
This method draws the representation of the overlay based on the extent you provided.When implementing this abstract method, consider each feature and its column data values. You can use the full power of the GeoCanvas to do the drawing. If you need column data for a feature, be sure to override the GetRequiredColumnNamesCore and add the columns you need to the collection. In many of the styles, we add properties that allow the user to specify which field they need; then, in the GetRequiredColumnNamesCore, we read that property and add it to the collection.
canvas | GeoCanvas<!– ThinkGeo.MapSuite.Core.GeoCanvas –> | This parameter is the canvas object or a GeoImage to draw on. |
<!– ThinkGeo.MapSuite.DesktopEdition.Overlay(overriden) –> Go Back
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#DrawException.28GeoCanvas.2C_Exception.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#DrawException.28GeoCanvas.2C_Exception.29</a>
e | Exception<!– System.Exception –> | This parameter is the exception that is occurring. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#DrawExceptionCore.28GeoCanvas.2C_Exception.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#DrawExceptionCore.28GeoCanvas.2C_Exception.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#DrawPreviewCore.28GeoCanvas.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#DrawPreviewCore.28GeoCanvas.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#Finalize.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#Finalize.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#MemberwiseClone.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#MemberwiseClone.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#OnDrawing.28DrawingOverlayEventArgs.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#OnDrawing.28DrawingOverlayEventArgs.29</a>
e | DrawingOverlayEventArgs<!– ThinkGeo.MapSuite.DesktopEdition.DrawingOverlayEventArgs –> | The OverlayDrawingEventArgs passed for the event raised. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#OnDrawingAttribution.28DrawingAttributionOverlayEventArgs.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#OnDrawingAttribution.28DrawingAttributionOverlayEventArgs.29</a>
args | DrawingAttributionOverlayEventArgs<!– ThinkGeo.MapSuite.DesktopEdition.DrawingAttributionOverlayEventArgs –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#OnDrawn.28DrawnOverlayEventArgs.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#OnDrawn.28DrawnOverlayEventArgs.29</a>
e | DrawnOverlayEventArgs<!– ThinkGeo.MapSuite.DesktopEdition.DrawnOverlayEventArgs –> | The OverlayDrawnEventArgs passed for the event raised. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#OnDrawnAttribution.28DrawnAttributionOverlayEventArgs.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#OnDrawnAttribution.28DrawnAttributionOverlayEventArgs.29</a>
args | DrawnAttributionOverlayEventArgs<!– ThinkGeo.MapSuite.DesktopEdition.DrawnAttributionOverlayEventArgs –> |
eventArgs | RequestedDrawingOverlayEventArgs<!– ThinkGeo.MapSuite.DesktopEdition.RequestedDrawingOverlayEventArgs –> |
eventArgs | RequestingDrawingOverlayEventArgs<!– ThinkGeo.MapSuite.DesktopEdition.RequestingDrawingOverlayEventArgs –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#OnSendingWebRequest.28SendingWebRequestEventArgs.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#OnSendingWebRequest.28SendingWebRequestEventArgs.29</a>
e | SendingWebRequestEventArgs<!– ThinkGeo.MapSuite.Core.SendingWebRequestEventArgs –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#OnSentWebRequest.28SentWebRequestEventArgs.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#OnSentWebRequest.28SentWebRequestEventArgs.29</a>
e | SentWebRequestEventArgs<!– ThinkGeo.MapSuite.Core.SentWebRequestEventArgs –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#RefreshCore.28GeoCanvas.2C_RectangleShape.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#RefreshCore.28GeoCanvas.2C_RectangleShape.29</a>
Return Type |
Return Type |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#ClientId” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#ClientId</a>
Return Type |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#DrawingExceptionMode” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#DrawingExceptionMode</a>
Return Type |
DrawingExceptionMode<!– ThinkGeo.MapSuite.Core.DrawingExceptionMode –> |
We track the drawing time for the Overlay and report it back in this method. This is useful to determine the speed of various Overlays.
Return Type |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#IsBase” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#IsBase</a>
Return Type |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#IsEmpty” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#IsEmpty</a>
Return Type |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#IsVisible” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#IsVisible</a>
Return Type |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#Lock” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#Lock</a>
Return Type |
OverlayLock<!– ThinkGeo.MapSuite.DesktopEdition.OverlayLock –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#MapType” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#MapType</a>
Return Type |
GoogleMapsMapType<!– ThinkGeo.MapSuite.Core.GoogleMapsMapType –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#MaxCacheSizeInMegabytes” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#MaxCacheSizeInMegabytes</a>
Return Type |
Double<!– System.Double –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#Name” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#Name</a>
Return Type |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#PreviewTileCache” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#PreviewTileCache</a>
Return Type |
BitmapTileCache<!– ThinkGeo.MapSuite.Core.BitmapTileCache –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#PrivateKey” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#PrivateKey</a>
Return Type |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#ProjectedTileCache” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#ProjectedTileCache</a>
Return Type |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#ProjectionFromSphericalMercator” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#ProjectionFromSphericalMercator</a>
Return Type |
Projection<!– ThinkGeo.MapSuite.Core.Projection –> |
Return Type |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#TileExpiration” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#TileExpiration</a>
Return Type |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#TileMode” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#TileMode</a>
Return Type |
GoogleMapsTileMode<!– ThinkGeo.MapSuite.Core.GoogleMapsTileMode –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#TimeoutInSeconds” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#TimeoutInSeconds</a>
Return Type |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#GoogleMapsOverlay.28String.2C_String.2C_String.2C_WebProxy.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.GoogleMapsOverlay#GoogleMapsOverlay.28String.2C_String.2C_String.2C_WebProxy.29</a>
Return Type |
Event Arguments |
Event Arguments |
Event Arguments |
Event Arguments |
Event Arguments |
Event Arguments |
Event Arguments |
Event Arguments |
NOTOC DesktopEdition ThinkGeo.MapSuite.DesktopEdition UpdateDocumentation
