thinkgeo.mapsuite.core.tiledwmslayer
ThinkGeo.MapSuite.Core.TiledWmsLayer
      • ThinkGeo.MapSuite.Core.TiledWmsLayer
TiledWmsLayer()
This is the constructor the for the class. If you use this constructor, then you need to set the required properties manually.
TiledWmsLayer(IEnumerable<Uri>)
  • serverUris
    • Type:IEnumerable<Uri>
TiledWmsLayer(IEnumerable<Uri>,GeoWebProxy)
  • serverUris
TiledWmsLayer(IEnumerable<Uri>,String,String)
  • serverUris
  • clientId
  • privateKey
TiledWmsLayer(IEnumerable<Uri>,GeoWebProxy,String,String)
  • serverUris
  • clientId
  • privateKey
ClearCache()
This method clears the tile cache of client.
GetServerLayerNames()
This method returns the names of all layers at the server side.
None.
  • Type:Collection<String>
  • Description:This method returns the names of all layers at the server side.
GetServerStyleNames()
This method returns the names of all styles at the server side.
None.
  • Description:This method returns the names of all styles at the server side.
GetServerOutputFormats()
This method returns the output format at the server side.
None.
  • Description:This method returns the output format at the server side.
GetServerCrss()
This method returns the projected or geographic coordinate reference systems to be used.
GetServerExceptionFormats()
This method returns the exception format at the server side.
None.
  • Description:The exception format at the server side.
GetServiceVersion()
This API gets the WMS server version of the service.
  • Description:Returns a string reflecting the version of the service in WMS.
GetServerFeatureInfoFormats()
This API gets the WMS server FeatureInfo formats of the service.
  • Description:This API returns the FeatureInfo formats supported on the server-side.
GetServerCapabilitiesXml()
This API gets the GetCapabilites document of the service.
  • Description:This API returns the GetCapabilites document of the service.
GetRequestUris(RectangleShape,Int32,Int32)
Get the request URLs from the client to the WMS servers.
  • Type:Collection<Uri>
  • Description:The request URLs from the client to the WMS servers.
  • requestExtent
    • Description:The world extent requested by the client to get the map.
  • canvasWidth
    • Description:The returning map width, as well as the drawing canvas width.
  • canvasHeight
    • Description:The returning map height, as well as the drawing canvas height.
GetFeatureInfo(ScreenPointF)
GetFeatureInfo(ScreenPointF,String)
  • infoFormat
GetFeatureInfo(ScreenPointF,Int32)
  • maxFeatures
GetFeatureInfo(ScreenPointF,String,Int32)
  • infoFormat
  • maxFeatures
GetThreadSafetyLevel()
CloneDeep()
  • Type:Layer
Open()
Close()
GetBoundingBox()
RequestDrawing()
RequestDrawing(TimeSpan)
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
GetThreadSafetyLevelCore()
OnSendingWebRequest(SendingWebRequestEventArgs)
OnSentWebRequest(SentWebRequestEventArgs)
OpenCore()
  • Description:None
GetRequestUrisCore(RectangleShape,Int32,Int32)
  • requestExtent
  • canvasWidth
  • canvasHeight
CloseCore()
This method closes the Layer and releases any resources it was using.
This abstract method is called from the concrete public method Close. The close method plays an important role in the life cycle of the Layer. It may be called after drawing to release any memory and other resources that were allocated since the Open method was called. If you override this method, it is recommended that you take the following things into account: This method may be called multiple times, so we suggest you write the method so that that a call to a closed Layer is ignored and does not generate an error. We also suggest that in the Close you free all resources that have been opened. Remember that the object will not be destroyed, but will be re-opened possibly in the near future.
  • Description:None
This method draws the Layer.
This method is the concrete wrapper for the abstract method DrawCore. This method draws the representation of the layer based on the extent you provided. When implementing this abstract method, consider each feature and its column data values. You can use the full power of the GeoCanvas to do the drawing. If you need column data for a feature, be sure to override the GetRequiredColumnNamesCore and add the columns you need to the collection. In many of the styles, we add properties that allow the user to specify which field they need; then, in the GetRequiredColumnNamesCore, we read that property and add it to the collection.
  • Description:None
  • canvas
    • Type:GeoCanvas
    • Description:This parameter is the canvas object or a GeoImage to draw on.
  • labelsInAllLayers
    • Description:This parameter represents the labels used for collision detection and duplication checking.
  • canvas
    • Type:GeoCanvas
    • Description:The target canvas to draw the layer.
  • e
    • Type:Exception
    • Description:The exception thrown when layer.Draw().
GetFeatureInfoCore(ScreenPointF,String,Int32)
  • infoFormat
  • maxFeatures
CloneDeepCore()
  • Type:Layer
GetBoundingBoxCore()
  • e
    • Type:Exception
  • attribution
CCY=(Double,Double)
  • 5mA=
  • 52A=
wxs=(RectangleShape,RectangleShape)
Credentials
This property gets or sets the base authentication interface for retrieving credentials for Web Client authentication.
  • Type:ICredentials
ClientId
Gets or sets a value that is your Client Id.
PrivateKey
Gets or sets a value that is unique to your client ID, please keep your key secure.
ZoomLevelSet
AxisOrder
CapabilitesCacheTimeout
  • Type:TimeSpan
CapabilitiesCacheTimeout
  • Type:TimeSpan
ServerUri
Gets or sets a server uri of Tiled WMS Server.
  • Type:Uri
ServerUris
WebProxy
This property gets or sets the proxy used for requesting a Web Response.
TileWidth
Gets or sets the width of the tile requested
TileHight
Gets or sets the height of the tile requested
OutputFormat
This property gets or sets the desired output format for the map requested from the WMS.
When requesting a map, a client may specify the output format in which to show the map. Format are specified as MIME types such as “image/gif” or “image/png”.
Crs
This property gets or sets the projected or geographic coordinate reference system to be used.
TileCache
Gets or sets a BitmapTileCache represents which tile cache will be used.
ImageSource
UpperScale
Gets or sets a value represents upper threshold for scale.
Is the current scale is beyond this value, the map will not render.
LowerScale
Gets or sets a value represents lower threshold for scale.
Is the current scale is less than this value, the map will not render.
ActiveLayerNames
This property represents the available layers that can be requested from the client and shown on the map.
When requesting a map, a client may specify the layers to be shown on the map.
ActiveStyleNames
This property represents the available styles that can be requested from the client and shown on the map.
When requesting a map, a client may specify the styles to be shown on the map.
TimeoutInSeconds
This property specifies the timeout of the web request in seconds. The default timeout value is 20 seconds.
Exceptions
This property indicates the format in which the client wishes to be notified of service exceptions.
Upon receiving a request that is invalid according to the OGC standard, the server shall issue a service exception report. The service report is meant to describe to the client application or its human user the reason(s) that the request is invalid.
This property specifies a dictionary used to update the request sent from the client to the WMS server.
HasBoundingBox
This property indicates whether a Layer has a BoundingBox or not. If it has no BoundingBox, it will throw an exception when you call the GetBoundingBox() and GetFullExtent() APIs.
The value of TileWmsLayer is false.
IsOpen
DrawingTime
  • Type:TimeSpan
IsVisible
Transparency
  • Type:Single
IsNegative
IsGrayscale
DrawingExceptionMode
Attribution
RequestDrawingInterval
  • Type:TimeSpan
IsOpenCore
This property returns true if the Layer is open and false if it is not.
Various methods on the Layer require that it be in an open state. If one of those methods is called when the state is not open, then the method will throw an exception. To enter the open state, you must call the Layer Open method. The method will raise an exception if the current Layer is already open.
SendingWebRequest N/A
Event Arguments:SendingWebRequestEventArgs
SentWebRequest N/A
Event Arguments:SentWebRequestEventArgs
DrawingException N/A
DrawingProgressChanged N/A
DrawnException N/A
DrawingAttribution N/A
DrawnAttribution N/A
RequestedDrawing N/A
RequestingDrawing N/A
thinkgeo.mapsuite.core.tiledwmslayer.1442797885.txt.gz · Last modified: 2015/09/21 01:11 by admin
