<!– Class –> This class represents a Layer backed by a Shape File.
*System.Object ThinkGeo.MapSuite.Core.Layer *ThinkGeo.MapSuite.Core.FeatureLayer ThinkGeo.MapSuite.Core.ShapeFileFeatureLayer
ShapeFileFeatureLayer | This is a constructor for the class. | ||
ShapeFileFeatureLayer | String | This is a constructor for the class. | |
ShapeFileFeatureLayer | String, ShapeFileReadWriteMode | This is a constructor for the class. | |
ShapeFileFeatureLayer | String, String | This is a constructor for the class. | |
ShapeFileFeatureLayer | String, String, ShapeFileReadWriteMode | This is a constructor for the class. | |
ShapeFileFeatureLayer | String, String, ShapeFileReadWriteMode, Encoding | This is a constructor for the class. |
![]() BuildIndexFile | String, String, Projection, String, String, BuildIndexMode, Encoding | This method builds a spatial index only for those features that satisfy a regular expression, based on a passed-in projection. | |
![]() BuildIndexFile | String, String, Projection, String, String, BuildIndexMode | This method builds a spatial index only for those features that satisfy a regular expression, based on a passed-in projection. | |
![]() BuildIndexFile | String, String, String, String, BuildIndexMode | This method builds a spatial index only for those features that satisfy a regular expression. | |
![]() BuildIndexFile | String | This method builds a spatial index for the layer. | |
![]() BuildIndexFile | String, String, BuildIndexMode | This method build a spatial index for the shape file which increases accessspeed. | |
![]() BuildIndexFile | String, BuildIndexMode | This method builds a spatial index for the layer. | |
![]() BuildIndexFile | IEnumerable<Feature>, String | This method builds a spatial index for the specified group of features. | |
![]() BuildIndexFile | IEnumerable<Feature>, String, Projection | This method builds a spatial index for the specified group of features and target projection. | |
![]() BuildIndexFile | IEnumerable<Feature>, String, BuildIndexMode | This method builds a spatial index for the specified group of features. | |
![]() BuildIndexFile | IEnumerable<Feature>, String, Projection, BuildIndexMode | This method builds a spatial index for the specified group of features. | |
![]() BuildRecordIdColumn | String, String, BuildRecordIdMode | Static API used to build RecordId. The Id will start from 0. | |
![]() BuildRecordIdColumn | String, String, BuildRecordIdMode, Int32, Encoding | Static API used to build RecordId from the specified starting Id number. | |
![]() BuildRecordIdColumn | String, String, BuildRecordIdMode, Int32 | Static API used to build RecordId from the specified starting Id number. | |
CloneDeep | Layer | Create a copy of Layer using the deep clone process. | |
![]() CloneShapeFileStructure | String, String | Clone the structure from the source ShapeFile to the target ShapeFile. After cloning the structure, the target ShapeFile will have the same type and the same DBF columns as the source ShapeFile, but without any records in it. | |
![]() CloneShapeFileStructure | String, String, OverwriteMode | Clone the structure from the source ShapeFile to the target ShapeFile. After cloning the structure, the target ShapeFile will have the same type and the same DBF columns as the source ShapeFile, but without any records in it. | |
![]() CloneShapeFileStructure | String, String, OverwriteMode, Encoding | Clone the structure from the source ShapeFile to the target ShapeFile. After cloning the structure, the target ShapeFile will have the same type and the same DBF columns as the source ShapeFile, but without any records in it. | |
Close | Layer | This method closes the Layer and releases any resources it was using. | |
![]() CreateShapeFile | ShapeFileType, String, IEnumerable<DbfColumn>, Encoding, OverwriteMode | Static API to create a new Shape File. | |
![]() CreateShapeFile | ShapeFileType, String, IEnumerable<DbfColumn>, Encoding | Static API to create a new Shape File. | |
![]() CreateShapeFile | ShapeFileType, String, IEnumerable<DbfColumn> | Static API to create a new Shape File. | |
Draw | GeoCanvas, Collection<SimpleCandidate> | Layer | This method draws the Layer. |
GetBoundingBox | Layer | This method returns the bounding box of the Layer. | |
GetShapeFileType | Get the Shape File type for the Shape File FeatureSource. | ||
![]() GetValidColumnNames | IEnumerable<String> | ||
![]() GetValidColumnNames | IEnumerable<String>, Encoding | ||
![]() GetValidColumns | IEnumerable<DbfColumn> | ||
![]() GetValidColumns | IEnumerable<DbfColumn>, Encoding | ||
![]() LoadLayer | Stream | Layer | |
![]() LoadLayer | Uri | Layer | |
Open | Layer | This method opens the Layer so that it is initialized and ready to use. | |
![]() Rebuild | String, ShapeFileSortingMode, Int32 | ||
![]() Rebuild | String | This method rebuilds the SHP, SHX, DBF, IDX and IDS files for the given shape file. | |
RequestDrawing | IEnumerable<RectangleShape> | Layer | |
RequestDrawing | Layer | ||
RequestDrawing | RectangleShape | Layer | |
RequestDrawing | IEnumerable<RectangleShape>, TimeSpan, RequestDrawingBufferTimeType | Layer | |
RequestDrawing | IEnumerable<RectangleShape>, TimeSpan | Layer | |
RequestDrawing | RectangleShape, TimeSpan, RequestDrawingBufferTimeType | Layer | |
RequestDrawing | RectangleShape, TimeSpan | Layer | |
RequestDrawing | TimeSpan, RequestDrawingBufferTimeType | Layer | |
RequestDrawing | TimeSpan | Layer | |
![]() SaveToProjection | String, String, Projection, OverwriteMode | This API provide a easy way to project features in a shape file into another projection and save it to shape file. | |
ToString | Object | ||
Validate | This method checks all features in a shapefile is supported by Mapsuite or not. |
DrawingMarginInPixel | Single | FeatureLayer | |
DrawingQuality | DrawingQuality | FeatureLayer | This property gets and sets the general drawing quality for the FeatureLayer's canvas. |
EditTools | EditTools | FeatureLayer | This property gets the EditTools that allow you to easily edit InternalFeatures in the Feature Layer. |
Encoding | Encoding | This property gets and sets the encoding information for the DBF. | |
FeatureIdsToExclude | Collection<String> | FeatureLayer | A collection of strings representing record id of features not to get in the Layer. |
FeatureSource | FeatureSource | FeatureLayer | This property gets the FeatureSource for the FeatureLayer. |
GeometryValidationMode | GeometryValidationMode | FeatureLayer | |
HasBoundingBox | Boolean | Layer(overriden) | This property checks to see if a Layer has a BoundingBox or not. If it has no BoundingBox, it will throw an exception when you call the GetBoundingBox() and GetFullExtent() APIs. In ShapeFileFeatureLayer, we override this API and mark it as true. |
IndexPathFileName | String | This property returns the path and filename of the index file you want to represent. | |
MaxRecordsToDraw | Int32 | FeatureLayer | |
ProgressiveDrawingRecordsCount | Int32 | ||
QueryTools | QueryTools | FeatureLayer | This property gets the QueryTools that allow you to easily query Features from the Feature Layer. |
ReadWriteMode | ShapeFileReadWriteMode | ||
RequireIndex | Boolean | This property gets and sets whether an index is required when reading data. The default value is true. | |
ShapePathFileName | String | This property returns the path and filename of the Shape File you want to represent. | |
SimplificationAreaInPixel | Int32 | ||
UsingSpatialIndex | Boolean | This property gets whether the Shape File FeatureSource has an index or not. | |
WrappingExtent | RectangleShape | FeatureLayer | |
WrappingMode | WrappingMode | FeatureLayer | Thie property gets or sets whether allow wrap date line. |
ZoomLevelSet | ZoomLevelSet | FeatureLayer | This property gets and sets the ZoomLevelSet, which contains the specific zoom levels for the FeatureLayer. |
IsOpenCore | Boolean | Layer(overriden) |
DrawingAttribution | DrawingAttributionLayerEventArgs | Layer | |
DrawingException | DrawingExceptionLayerEventArgs | Layer | |
DrawingFeatures | DrawingFeaturesEventArgs | FeatureLayer | This event is raised when features are about to be drawn in the layer. |
DrawingProgressChanged | DrawingProgressChangedEventArgs | Layer | |
DrawingWrappingFeatures | DrawingWrappingFeaturesFeatureLayerEventArgs | FeatureLayer | |
DrawnAttribution | DrawnAttributionLayerEventArgs | Layer | |
DrawnException | DrawnExceptionLayerEventArgs | Layer | |
RequestedDrawing | RequestedDrawingLayerEventArgs | Layer | |
RequestingDrawing | RequestingDrawingLayerEventArgs | Layer | |
StreamLoading | StreamLoadingEventArgs | This event allows you to pass in your own stream to represent the files. |
This is the default constructor. If you use this constructor, then you should set the required methods manually.
This constructor allows you to provide a path and filename to a shape file.
| shapePathFilename | String<!– System.String –> | This parameter is the Shape File path and filename. |
This constructor allows you to provide a path and filename to a Shape File and the read/write mode for the files.
| readWriteMode | ShapeFileReadWriteMode<!– ThinkGeo.MapSuite.Core.ShapeFileReadWriteMode –> | This parameter specifies whether the file will be opened in read-only or read/write mode. |
This constructor allows you to provide a path and filename to a Shape File and its spatial index file.
| indexPathFilename | String<!– System.String –> | This parameter is the index file path and filename. |
This constructor allows you to provide a path and filename to a Shape File, its index file, and to specify the read/write mode for the files.
This constructor allows you to provide a path and filename to a Shape File, the index file, and to specify the read/write mode and the encoding for the files.
| encoding | Encoding<!– System.Text.Encoding –> | This parameter specifies the encoding of the data. |
<!– static –> This method builds a spatial index only for those features that satisfy a regular expression, based on a passed-in projection.
This overload allows you to pass in a Shape File and only build an index for those features that satisfy the regularExpression parameter.
This overload allows you to pass in a Shape File and specify the index filename to use.
| shapePathFilename | String<!– System.String –> | This parameter specifies the Shape File for which to build the index. |
| indexPathFilename | String<!– System.String –> | This parameter determines the target index path filename. |
| projection | Projection<!– ThinkGeo.MapSuite.Core.Projection –> | This parameter determines the projection that will be used to build the index against those features that satisfy the regular expression. |
| columnName | String<!– System.String –> | This parameter determines the column name whose values will be tested against the regular expression. |
| regularExpression | String<!– System.String –> | This parameter represents the regular expression to test against each feature for inclusion in the index. |
| buildIndexMode | BuildIndexMode<!– ThinkGeo.MapSuite.Core.BuildIndexMode –> | This parameter determines whether an index file will be rebuilt if it already exists. |
| encoding | Encoding<!– System.Text.Encoding –> | This parameter specifies the encoding information used in the source DBF file. |
<!– ThinkGeo.MapSuite.Core.ShapeFileFeatureLayer –> Go Back
<!– static –> This method builds a spatial index only for those features that satisfy a regular expression.
<!– static –> This method builds a spatial index for the layer.
This overload allows you to pass in the Shape filename.
This overload allows you to pass in the Shape File.
| pathFilename | String<!– System.String –> | The path and filename to the Shape File. |
<!– static –> This method build a spatial index for the shape file which increases accessspeed.
This overload builds an index file with the same name as the shape file with only the extension being different. You can also specify if you want to rebuild an existing index file.
| shapePathFilename | String<!– System.String –> | This parameter is the shape file name and path that you want to build an index for. |
| indexPathFilename | String<!– System.String –> | This parameter specifies the index file name. |
| buildIndexMode | BuildIndexMode<!– ThinkGeo.MapSuite.Core.BuildIndexMode –> | This parameter determines what will happen if there is an existing index file. |
This overload allows you to pass in the Shape File and determines if we rebuild an index file that already exists.
| pathFilename | String<!– System.String –> | This parameter is the matching pattern that defines which Shape Files to include. |
| rebuildExistingIndexMode | BuildIndexMode<!– ThinkGeo.MapSuite.Core.BuildIndexMode –> | This parameter determines whether an index file will be rebuilt if it already exists. |
<!– static –> This method builds a spatial index for the specified group of features.
This overload allows you to pass in a group of features and specify the index filename to use.
| features | IEnumerable<Feature><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.Core.Feature} –> | This parameter specifies the features for which to build the index. |
| indexPathFilename | String<!– System.String –> | This parameter specifies the target index path and filename. |
<!– static –> This method builds a spatial index for the specified group of features and target projection.
This overload allows you to pass in a group of features and specify a target projection and the index filename to use.
| projection | Projection<!– ThinkGeo.MapSuite.Core.Projection –> | This parameter specifies the projection to build index against those features. |
This overload allows you to pass in a group of features and specify the index filename to use. You can also pass in a Shape File and specify whether to rebuild an index file if it already exists.
This overload allows you to pass in a group of features and specify a target projection and the index filename to use. You can also pass in a Shape File and specify whether to rebuild an index file if it already exists.
| projection | Projection<!– ThinkGeo.MapSuite.Core.Projection –> | This parameter determines the Projection to build index against those features. |
<!– static –> Static API used to build RecordId. The Id will start from 0.
| shapeFilename | String<!– System.String –> | The name of the target ShapeFile on which to base the newly built RecordId. |
| fieldname | String<!– System.String –> | The field name for the RecordId. |
| rebuildNeeded | BuildRecordIdMode<!– ThinkGeo.MapSuite.Core.BuildRecordIdMode –> | The RecordId build mode. |
<!– static –> Static API used to build RecordId from the specified starting Id number.
| startNumber | Int32<!– System.Int32 –> | The starting Id number of the RecordId. |
| encoding | Encoding<!– System.Text.Encoding –> | This parameter specifies the encoding information in the DBF. |
<!– static –> Clone the structure from the source ShapeFile to the target ShapeFile. After cloning the structure, the target ShapeFile will have the same type and the same DBF columns as the source ShapeFile, but without any records in it.
| sourceShapePathFilename | String<!– System.String –> | The source Shape File to be cloned. |
| targetShapePathFilename | String<!– System.String –> | The target Shape File, which will have the same structure as the source Shape File after cloning operation is complete. |
An exception will be thown when the target ShapeFile does not exist and the overwrite mode is set to DoNotOverwrite.
| overwriteMode | OverwriteMode<!– ThinkGeo.MapSuite.Core.OverwriteMode –> | This parameter specifies the overwrite mode when the target ShapeFile already exists. |
| encoding | Encoding<!– System.Text.Encoding –> | This parameter specifies the encoding information in the source Shape File. |
<!– static –> Static API to create a new Shape File.
An exception will be thown when the target Shape File does not exist while the overwrite mode is set to DoNotOverwrite.
| shapeType | ShapeFileType<!– ThinkGeo.MapSuite.Core.ShapeFileType –> | This parameter specifies the the Shape File type for the target Shape File. |
| pathFilename | String<!– System.String –> | This parameter specifies the Shape filename for the target Shape File. |
| databaseColumns | IEnumerable<DbfColumn><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.Core.DbfColumn} –> | This parameter specifies the DBF column information for the target Shape File. |
| encoding | Encoding<!– System.Text.Encoding –> | This parameter specifies the DBF encoding infromation for the target Shape File. |
| overwriteMode | OverwriteMode<!– ThinkGeo.MapSuite.Core.OverwriteMode –> | This parameter specifies the override mode when the target Shape File exists. |
| ShapeFileType<!– ThinkGeo.MapSuite.Core.ShapeFileType –> | The ShapeFileType for the ShapeFile FeatureSource. |
<!– static –>
| columnNames | IEnumerable<String><!– System.Collections.Generic.IEnumerable{System.String} –> |
<!– static –>
| columnNames | IEnumerable<String><!– System.Collections.Generic.IEnumerable{System.String} –> | |
<!– static –>
| Collection<DbfColumn><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.Core.DbfColumn} –> |
| columns | IEnumerable<DbfColumn><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.Core.DbfColumn} –> |
<!– static –>
| columns | IEnumerable<DbfColumn><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.Core.DbfColumn} –> | |
<!– static –>
<!– static –>
<!– static –>
| shapePathFilename | String<!– System.String –> | |
| sortingMode | ShapeFileSortingMode<!– ThinkGeo.MapSuite.Core.ShapeFileSortingMode –> | |
| sridForSorting | Int32<!– System.Int32 –> |
<!– static –> This method rebuilds the SHP, SHX, DBF, IDX and IDS files for the given shape file.
This method rebuilds the SHP, SHX, DBF, IDX and IDS files for the given shape file. When we do editing we have optimized the updates so that we do not need to rebuild the entire shape file. This leads to the shape file being out of order which may cause it not to open in other tools. One optimization is if you update a record instead of rebuilding a new shape file we mark the old record as null and add the edited record at the end of the shape file. This greatly increases the speed of committing shape file changes but will over time unorder the shape file. In addition we do a delete the DBF file will simply mark the record deleted and not compact the space. Rebuilding the shape file will correctly order the SPX and SHX along with compacting the DBF file and rebuild any index with the same any of the shape file if it exists.
Note that if you have build custom index files where the name of the index differs from that of the shape file you will need to rebuild those manually using the BuildIndex methods.
| shapePathFilename | String<!– System.String –> | This parameter is the shape file you want to rebuild. |
| extentsToRefresh | IEnumerable<RectangleShape><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.Core.RectangleShape} –> |
| extentToRefresh | RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> |
<!– static –> This API provide a easy way to project features in a shape file into another projection and save it to shape file.
| sourceShapeFile | String<!– System.String –> | This parameter specifies the source shape file to be projected. |
| targetShapeFile | String<!– System.String –> | This parameter specifies the target shape file to be saved for the projected features. |
| projection | Projection<!– ThinkGeo.MapSuite.Core.Projection –> | This parameter is the projection to project the source shape file to target shape file. The source Shape file should be in the FromProjection of the Projection prameter, and the targetShapeFile will be in the ToProjection of the Projection. |
| overwriteMode | OverwriteMode<!– ThinkGeo.MapSuite.Core.OverwriteMode –> | This parameter specifies the override mode when the target shape file exists. |
| Dictionary<String,String><!– System.Collections.Generic.Dictionary{System.String,System.String} –> | A dictionary which contains all the unsupported features. The key is the Indexs which failed to pass the check, the value contains the reason for its failure. |
This method raises the DrawingFeatures event.
<list type=“bullet”> <item>You can call this method from a derived class to enable it to raise the event. This may be useful if you plan to extend the FeatureLayer and you need access to the event.
This event is meant to allow you to add or remove the features to be drawn.</item> </list>
| e | DrawingFeaturesEventArgs<!– ThinkGeo.MapSuite.Core.DrawingFeaturesEventArgs –> | This parameter represents the event arguments for the event. |
<!– ThinkGeo.MapSuite.Core.FeatureLayer –> Go Back
| e | DrawingWrappingFeaturesFeatureLayerEventArgs<!– ThinkGeo.MapSuite.Core.DrawingWrappingFeaturesFeatureLayerEventArgs –> |
This method sets up the EditTools and QueryTools objects.
This method is the concrete wrapper for the abstract method SetupToolsCore. The SetupTools method allows you to create the QueryTool, EditTools and other tools you may need on your object. We created this method so that if you want to extend one of the tool classes, you can override the SetupToolsCore and create any class you want.
This method is the concrete wrapper for the abstract method SetupTools. The SetupTools method allows you to create the QueryTool, EditTools and other tools you may need on your object. We created this method so that if you want to extend one of the tool classes, you can override the SetupToolsCore and create any class you want.
The DrawingQuality enumeration allows you to control, in a macro sense, the drawing quality that will be used in the GeoCanvas. Each GeoCanvas, which is responsible for drawing of the features, may have its own specialized drawing quality properties. What the DrawingQuality enumeration does is define some general guidelines for each GeoCanvas. For example, if you set the DrawingQuality to HighSpeed, then inside of the GdiPlusGeoCanvas there is a profile for HighSpeed. This profile sets specific properties, such as the smoothing mode and composing drawing mode of the GdiPlusGeoCanvas. As each GeoCanvas may have different drawing quality properties, this offers a general way to control drawing quality and speed.
If you need complete control over how a specific GeoCanvas will draw, then you can set the DrawingQuality to Custom. This will tell the specific GeoCanvas to use the properties on its own object instead of one of the pre-defined profiles. If one of the profiles – such as HighSpeed or HighQuality – is set, then the specific GeoCanvas ignores its own properties for drawing quality.
| DrawingQuality<!– ThinkGeo.MapSuite.Core.DrawingQuality –> |
The EditTools are supplied as an easily accessible wrapper for the editing methods of the FeatureSource.
| EditTools<!– ThinkGeo.MapSuite.Core.EditTools –> |
The FeatureSource is the provider of data to the FeatureLayer. There are different FeatureSource classes to match the various ways that feature data is stored. It is important that, when you inherit from the FeatureLayer, in the constructor you set the FeatureSource you want to use.
| FeatureSource<!– ThinkGeo.MapSuite.Core.FeatureSource –> |
| GeometryValidationMode<!– ThinkGeo.MapSuite.Core.GeometryValidationMode –> |
This property gets the QueryTools that allow you to easily query Features from the Feature Layer. The QueryTools are supplied as an easily accessible wrapper for the query methods of the FeatureSource.
| QueryTools<!– ThinkGeo.MapSuite.Core.QueryTools –> |
| WrappingMode<!– ThinkGeo.MapSuite.Core.WrappingMode –> |
The ZoomLevelSet is a class that contains all of the ZoomLevels for the FeatureLayer. Each ZoomLevel contains the styles that are used to determine how to draw the InternalFeatures.
| ZoomLevelSet<!– ThinkGeo.MapSuite.Core.ZoomLevelSet –> |
| Event Arguments |
| Event Arguments |
This event is raised when features are about to be drawn in the layer. In the event arguments, there is a collection of features to be drawn. You can easily add or remove items from this collection so that extra items will draw or not draw.
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
If you choose you can pass in your own stream to represent the file. The stream can come from a variety of places such as isolated storage, a compressed file, and encrypted stream. When the Image is finished with the stream it will dispose of it so be sure to keep this in mind when passing the stream in. If you do not pass in a alternate stream the class will attempt to load the file from the file system using the PathFileName property.
| Event Arguments |
| StreamLoadingEventArgs<!– ThinkGeo.MapSuite.Core.StreamLoadingEventArgs –> |
