<!– Class –> This projection allows you to rotate the map image base don an angle.
This can be usefully when you are working with directional maps such as driving maps where you want the upper center of the map to be in line with the direction of the vehicle heading.
![]() | This is a constructor for the class. | ||
![]() | Double | This is a constructor for the class. | |
![]() | GeographyUnit | ||
![]() | Double, GeographyUnit |
![]() | Projection | Create a copy of Projection using the deep clone process. | |
![]() | Projection | This method closes the projection and gets it ready for serialization if necessary. | |
![]() | IEnumerable<Vertex> | Projection | This method returns projected vertices based on the coordinates passed in. |
![]() | RectangleShape | Projection | This method returns a projected rectangle based on the rectangle passed in. |
![]() | BaseShape | Projection | This method returns a projected BaseShape based on the baseShape passed in. |
![]() | Double, Double | Projection | This method returns a projected vertex based on the coordinates passed in. |
![]() | Feature | Projection | This method returns a projected Feature based on the Feature passed in. |
![]() | GeoImage, RectangleShape, RectangleShape | Projection | |
![]() | GeoImage, RectangleShape | Projection | |
![]() | Double, Double | Projection | This method returns a de-projected vertex based on the coordinates passed in. |
![]() | BaseShape | Projection | This method returns a de-projected BaseShape based on the BaseShape passed in. |
![]() | Feature | Projection | This method returns a de-projected Feature based on the Feature passed in. |
![]() | IEnumerable<Vertex> | Projection | This method returns de-projected vertices based on the coordinates passed in. |
![]() | RectangleShape | Projection | This method returns a de-projected rectangle based on the rectangle passed in. |
![]() | Object | Object | |
![]() | Projection | ||
![]() | Object | ||
![]() | Object | ||
![]() | RectangleShape | This method returns an adjusted extend based on the angle of rotation. | |
![]() | Projection | This method opens the projection and gets it ready to use. | |
![]() | Object |
![]() | Projection | Create a copy of GeoCanvas using the deep clone process. The default implementation uses serialization. | |
![]() | Double[], Double[] | Projection(overriden) | This method returns a projected vertices based on the coordinates passed in. |
![]() | Double[], Double[] | Projection(overriden) | This method returns a de-projected vertices based on the coordinates passed in. |
![]() | Object | ||
![]() | Projection(overriden) | ||
![]() | Object | ||
![]() | Double | This property sets the angle of rotation. | |
![]() | Boolean | Projection | |
![]() | Boolean | Projection | This property gets the state of the projection (whether it is opened or closed). |
![]() | PointShape | ||
![]() | Boolean | Projection | This property indicates whether this projection should be used. |
This is the default constructor and will set the angle to 0 whick is north being up.
Name | Type | Description |
This constructor allows you to pass in an angle to change the rotation of the map.
angle | Double<!– System.Double –> | This parameter is the angle you want to map to rotate to. |
sourceUnit | GeographyUnit<!– ThinkGeo.MapSuite.Core.GeographyUnit –> |
angle | Double<!– System.Double –> | |
Return Type | Description |
Projection<!– ThinkGeo.MapSuite.Core.Projection –> | A cloned Projection. |
<!– ThinkGeo.MapSuite.Core.Projection –> Go Back
Void<!– System.Void –> |
This method returns a projected vertex based on the coordinates passed in. You will need to override this method for the Projection class. Typically, you can call the projection utility library that has interfaces for dozens of different types of projections.
Vertex[]<!– ThinkGeo.MapSuite.Core.Vertexthinkgeo.mapsuite.core.rotationprojection –> | This method returns projected vertices based on the coordinates passed in. |
vertices | IEnumerable<Vertex><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.Core.Vertex} –> | This parameter is the vertices that will be projected. |
RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | This method returns a projected rectangle based on the rectangle passed in. |
rectangleShape | RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | This parameter represents the rectangle you want to project. |
This method returns a projected baseShape based on the BaseShape passed in.
BaseShape<!– ThinkGeo.MapSuite.Core.BaseShape –> | This method returns a projected baseShape for the passed-in BaseShape. |
baseShape | BaseShape<!– ThinkGeo.MapSuite.Core.BaseShape –> | This parameter is the baseShape (in decimalDegreesValue) to be projected. |
Vertex<!– ThinkGeo.MapSuite.Core.Vertex –> | This method returns a projected vertex based on the coordinates passed in. |
x | Double<!– System.Double –> | This parameter is the X decimalDegreesValue of the point that will be projected. |
y | Double<!– System.Double –> | This parameter is the Y decimalDegreesValue of the point that will be projected. |
Feature<!– ThinkGeo.MapSuite.Core.Feature –> | This method returns a projected Feature for the passed-in Feature. |
feature | Feature<!– ThinkGeo.MapSuite.Core.Feature –> | This parameter is the Feature that contains a BaseShape in decimalDegreesValue to be projected. |
RasterProjectionResult<!– ThinkGeo.MapSuite.Core.RasterProjectionResult –> |
image | GeoImage<!– ThinkGeo.MapSuite.Core.GeoImage –> | |
imageExtent | RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | |
targetExtent | RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> |
Vertex<!– ThinkGeo.MapSuite.Core.Vertex –> | This method returns a de-projected vertex based on the coordinates passed in. |
x | Double<!– System.Double –> | This parameter is the X decimalDegreesValue of the point that will be de-projected. |
y | Double<!– System.Double –> | This parameter is the Y decimalDegreesValue of the point that will be de-projected. |
BaseShape<!– ThinkGeo.MapSuite.Core.BaseShape –> | This method returns a de-projected BaseShape for the passed in BaseShape. |
baseShape | BaseShape<!– ThinkGeo.MapSuite.Core.BaseShape –> | This parameter is the baseShape (in decimalDegreesValue) to be de-projected. |
Feature<!– ThinkGeo.MapSuite.Core.Feature –> | This method returns a de-projected Feature for the passed-in Feature. |
feature | Feature<!– ThinkGeo.MapSuite.Core.Feature –> | This parameter is the Feature that contains a BaseShape in decimalDegreesValue to be de-projected. |
This method returns a de-projected vertex based on the coordinates passed in. The de-projection is important because, inside of the FeatureSource, you will in many cases go to and from various projections.
Vertex[]<!– ThinkGeo.MapSuite.Core.Vertexthinkgeo.mapsuite.core.rotationprojection –> | This method returns de-projected vertices based on the coordinates passed in. |
vertices | IEnumerable<Vertex><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.Core.Vertex} –> | This parameter is the vertices that will be de-projected. |
RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | This method returns a de-projected rectangle based on the rectangle passed in. |
rectangleShape | RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | This parameter represents the rectangle you want to de-project. |
Int32<!– System.Int32 –> |
Type<!– System.Type –> |
This method returns an adjusted extend based on the angle of rotation. It is important that you update your current extent every time you adjust the angle of the projection. This will ensure the rotaion is performed properly.
RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | This method returns an adjusted extend based on the angle of rotation. |
worldExtent | RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | This parameter is the world extent before the rotation. |
<!– ThinkGeo.MapSuite.Core.RotationProjection –> Go Back
String<!– System.String –> |
Projection<!– ThinkGeo.MapSuite.Core.Projection –> | A cloned GeoCanvas. |
As this is the core version of the Close method, it is intended to be overridden in an inherited version of the class. When overriding, you will be responsible freeing any state you have maintained and getting the class ready for serialization if necessary. Note that the object may be opened again, so you want to make sure you can open and close the object multiple times without any ill effects.
This method returns a projected vertex based on the coordinates passed in. You will need to override this method for the Projection class. Typically you can call the projection utility library that has interfaces for dozens of different types of projections.
Vertex[]<!– ThinkGeo.MapSuite.Core.Vertexthinkgeo.mapsuite.core.rotationprojection –> | This method returns a projected vertices based on the coordinates passed in. |
x | Double[]<!– System.Doublethinkgeo.mapsuite.core.rotationprojection –> | This parameter is the X values of the points that will be projected. |
y | Double[]<!– System.Doublethinkgeo.mapsuite.core.rotationprojection –> | This parameter is the Y values of the points that will be projected. |
<!– ThinkGeo.MapSuite.Core.Projection(overriden) –> Go Back
This method returns a de-projected vertex based on the coordinates passed in. You will need to override this method for the Projection class. Typically you can call the projection utility library that has interfaces for dozens of different types of projections. The de-projection is important because inside of the FeatureSource you will in many cases to to and from various projections.
Vertex[]<!– ThinkGeo.MapSuite.Core.Vertexthinkgeo.mapsuite.core.rotationprojection –> | This method returns a de-projected vertices based on the coordinates passed in. |
x | Double[]<!– System.Doublethinkgeo.mapsuite.core.rotationprojection –> | This parameter is the X values of the points that will be de-projected. |
y | Double[]<!– System.Doublethinkgeo.mapsuite.core.rotationprojection –> | This parameter is the Y values of the points that will be de-projected. |
As this is the core version of the Open method, it is intended to be overridden in an inherited version of the class. When overriding, you will be responsible for getting the projection classes' state ready for doing projections.
Return Type |
Return Type |
This method will reflect whether the projection is opened or closed. It is set in the concrete methods Open and Close, so if you inherit from this class and override OpenCore or CloseCore, you will not need to be concerned with setting this property.
Return Type |
Return Type |
PointShape<!– ThinkGeo.MapSuite.Core.PointShape –> |
Return Type |
Return Type |
