This class represents a canvas that is used to draw geographic shapes with GDI+.
GetStreamFromGeoImage(GeoImage)
This method returns a stream that represents the GeoImage in TIFF format.
This method allows you to get the stream out of a GeoImage. The stream is a memory stream and the bytes are in TIFF format. Once you have the stream, you can then save it to whatever format you need.
DrawWorldImageWithoutScaling(Bitmap,Double,Double,DrawingLevel)
Draws an unscaled image on the GeoCanvas.
Drawing an image unscaled is faster than using the API that scales it.
DrawWorldImageWithoutScaling(Bitmap,Double,Double,DrawingLevel,Single,Single,Single)
DrawScreenImageWithoutScaling(Bitmap,Single,Single,DrawingLevel,Single,Single,Single)
DrawArea(AreaBaseShape,GeoPen,DrawingLevel)
DrawArea(Feature,GeoBrush,DrawingLevel)
DrawArea(AreaBaseShape,GeoBrush,DrawingLevel)
DrawArea(Feature,GeoPen,GeoBrush,DrawingLevel)
DrawArea(AreaBaseShape,GeoPen,GeoBrush,DrawingLevel)
DrawArea(Feature,GeoPen,GeoBrush,DrawingLevel,Single,Single,PenBrushDrawingOrder)
DrawArea(AreaBaseShape,GeoPen,GeoBrush,DrawingLevel,Single,Single,PenBrushDrawingOrder)
DrawArea(IEnumerable<ScreenPointF[]>,GeoPen,GeoBrush,DrawingLevel,Single,Single,PenBrushDrawingOrder)
DrawLine(Feature,GeoPen,DrawingLevel)
DrawLine(LineBaseShape,GeoPen,DrawingLevel)
DrawLine(Feature,GeoPen,DrawingLevel,Single,Single)
DrawLine(LineBaseShape,GeoPen,DrawingLevel,Single,Single)
DrawLine(IEnumerable<ScreenPointF>,GeoPen,DrawingLevel,Single,Single)
DrawEllipse(Feature,Single,Single,GeoPen,DrawingLevel)
DrawEllipse(PointBaseShape,Single,Single,GeoPen,DrawingLevel)
DrawEllipse(Feature,Single,Single,GeoBrush,DrawingLevel)
DrawEllipse(PointBaseShape,Single,Single,GeoBrush,DrawingLevel)
DrawEllipse(Feature,Single,Single,GeoPen,GeoBrush,DrawingLevel)
DrawEllipse(PointBaseShape,Single,Single,GeoPen,GeoBrush,DrawingLevel)
DrawEllipse(Feature,Single,Single,GeoPen,GeoBrush,DrawingLevel,Single,Single,PenBrushDrawingOrder)
DrawEllipse(PointBaseShape,Single,Single,GeoPen,GeoBrush,DrawingLevel,Single,Single,PenBrushDrawingOrder)
DrawEllipse(ScreenPointF,Single,Single,GeoPen,GeoBrush,DrawingLevel,Single,Single,PenBrushDrawingOrder)
DrawWorldImageWithoutScaling(GeoImage,Double,Double,DrawingLevel)
DrawWorldImageWithoutScaling(GeoImage,Double,Double,DrawingLevel,Single,Single,Single)
DrawScreenImageWithoutScaling(GeoImage,Single,Single,DrawingLevel,Single,Single,Single)
DrawWorldImage(GeoImage,Double,Double,Single,Single,DrawingLevel)
DrawWorldImage(GeoImage,Double,Double,Double,DrawingLevel,Single,Single,Single)
DrawWorldImage(GeoImage,Double,Double,Single,Single,DrawingLevel,Single,Single,Single)
DrawScreenImage(GeoImage,Single,Single,Single,Single,DrawingLevel,Single,Single,Single)
DrawTextWithScreenCoordinate(String,GeoFont,GeoBrush,Single,Single,DrawingLevel)
DrawTextWithScreenCoordinate(String,GeoFont,GeoBrush,GeoPen,Single,Single,DrawingLevel)
DrawTextWithWorldCoordinate(String,GeoFont,GeoBrush,Double,Double,DrawingLevel)
DrawTextWithWorldCoordinate(String,GeoFont,GeoBrush,GeoPen,Double,Double,DrawingLevel)
DrawText(String,GeoFont,GeoBrush,IEnumerable<ScreenPointF>,DrawingLevel)
DrawText(String,GeoFont,GeoBrush,GeoPen,IEnumerable<ScreenPointF>,DrawingLevel,Single,Single,Single)
BeginDrawing(Object,RectangleShape,GeographyUnit)
FillBackground(GeoImage,GeoBrush)
This method fills the specified GeoImage with the specified GeoBrush.
This method allows you to fill a GeoImage with the specific fill style of the GeoBrush you pass in. It is useful for setting backgrounds.
ConvertGeoImageToMemoryStream(GeoImage)
This method converts a GeoImage to a memory stream.
This method is used to get a TIFF memory stream from a GeoImage using the canvas-specific methods. If you need to get a format other than TIFF, you can use the other overload which allows you to specify the output format.
ConvertGeoImageToMemoryStream(GeoImage,ImageFormat)
This method allows you to save the GeoImage to any format you specify. This allows you to convert it to a PNG, or a variety of other formats, and then save it to disk.
This method returns a GeoImage based on the height and width you provide.
You can use this static member to easily create a GeoCanvas.
DrawAreaCore(IEnumerable<ScreenPointF[]>,GeoPen,GeoBrush,DrawingLevel,Single,Single,PenBrushDrawingOrder)
This method draws the area on the GeoCanvas.
This method is used to draw on the GeoCanvas. It provides you with a number of overloads that allow you to control how things are drawn. Specify the GeoBrush to fill in an area. Specify the GeoPen to outline an area using that GeoPen. You can also call an overload that will allow you to specify both a GeoPen and a GeoBrush.The DrawingLevel allows you to specify the level you will draw on when you are drawing multiple areas. This is very useful when you want to draw a drop shadow, for example. In that case, you could draw the black backdrop on the lowest level with an offset, then draw the normal shape on a higher level without an offset.
DrawLineCore(IEnumerable<ScreenPointF>,GeoPen,DrawingLevel,Single,Single)
Draws a LineShape on the GeoCanvas.
This method is used to draw a line on the GeoCanvas using the specified GeoPen.The DrawingLevel allows you to specify the level you will draw on when drawing multiple lines. This is very useful when you want to draw a road, for example. You can draw the black background on the lowest level, then draw a slightly thinner white line on a higher level. This will result in a great effect for a road.
DrawEllipseCore(ScreenPointF,Single,Single,GeoPen,GeoBrush,DrawingLevel,Single,Single,PenBrushDrawingOrder)
Draws the point on the GeoCanvas.
This method is used to draw a point on the GeoCanvas. It provides you with a number of overloads that allow you to control how it is drawn. Specify the GeoBrush to fill in the area of the point. Specify the GeoPen to outline the point using that GeoPen. You can also call a overload that will allow you to specify both a GeoPen and a GeoBrush.The DrawingLevel allows you to specify the level you will draw on when drawing many points.
DrawScreenImageWithoutScalingCore(GeoImage,Single,Single,DrawingLevel,Single,Single,Single)
DrawScreenImageCore(GeoImage,Single,Single,Single,Single,DrawingLevel,Single,Single,Single)
Draws a scaled image on the GeoCanvas.
Drawing an image scaled is slower than using the API that draws it unscaled.
DrawTextCore(String,GeoFont,GeoBrush,GeoPen,IEnumerable<ScreenPointF>,DrawingLevel,Single,Single,Single)
This method allows you to draw text at the specified location, using the specified brush and font parameters.
This method is used to draw text on the GeoCanvas.The DrawingLevel allows you to specify the level you will draw on when drawing multiple text items. This is very useful when you want to draw a drop shadow, for example. You can draw the black backdrop on the lowest level with an offset, then draw the normal text on a higher level without an offset.
MeasureTextCore(String,GeoFont)
This method returns the rectangle that contains the specified text, when that text is drawn with the specified font.
This method is typically used for labeling, to determine whether labels overlap.
BeginDrawingCore(Object,RectangleShape,GeographyUnit)
This method begins the act of drawing on the GeoCanvas.
This is the first method that needs to be called before any drawing takes place. Calling this method will set the IsDrawing property to true. When you finish drawing, you must call EndDrawing to commit the changes to the image.
This method ends drawing and commits the drawing on the GeoCanvas.
This method should be called when you are finished drawing. It will commit the image changes to the image you passed in on BeginDrawing. It will also set IsDrawing to false. After you call this method it will put the GeoCanvas into an invalid state, so if you then call any drawing methods it will raise an exception.
It is faster to provide a native image object to the canvas for drawing. In some cases, you may not know what the native image type is. For example, for GDI+ it is a bitmap class, but in GDI it may be a handled to an HBitmap. If you are not sure how to create the native image object, you should first create a GeoImage and then call this method and it will pass back the native image object. You can then use it to get excellent drawing performance on the GeoCanvas.
This method returns a GeoImage from a native image object.
This method will allows you to convert your native image object to a GeoImage. Many times, when you work with a GeoCanvas, you may not know the format of the native image. Using this method you can always convert it back to a GeoImage, which is a stream of a TIFF.
This method gets the canvas width of the specified native image object.
This method gets the canvas height of the specified native image object.
This property is used for GDI+ drawing. The excerpt below is from the GDI+ documentation: Compositing is done during rendering when the source pixels are combined with the destination pixels to produce the resultant pixels. The quality of compositing directly relates to the visual quality of the output and is inversely proportional to the render time. The higher the quality, the slower the render time. This is because the higher the quality level, the more surrounding pixels need to be taken into account during the composite. The linear quality setting (AssumeLinear) compromises by providing better quality than the default quality at a slightly lower speed.
This property returns or sets the rendering quality for this GeoCanvas.
This property is used for GDI+ drawing. The excerpt below is from the GDI+ documentation: The smoothing mode specifies whether lines, curves, and the edges of filled areas use smoothing (also called antialiasing). One exception is that path gradient brushes do not obey the smoothing mode. Areas filled using a PathGradientBrush are rendered the same way (aliased) regardless of the SmoothingMode property.
This property indicates whether a GdiPlusGeoCanvas has the KeyColor or not. If it has no KeyColor, it will throw an exception when you get or set the value of KeyColors property.
The default value is true.
This property returns or sets the rendering mode for text associated with this GeoCanvas.
This property is used for GDI+ drawing. The excerpt below is from the GDI+ documentation: The text rendering hint specifies whether text renders with antialiasing.
Gets or sets the interpolation mode associated with this System.Drawing.Graphics.
