<!– Class –> This class allows you to draw features differently based on regular expression matching.
RegexStyle:
The RegexStyle allows you to use complex regular expression matching to determine how your features are drawn. A regular expression is a matching syntax that allows you to match a string based on very complex criteria. For example, let's say you have a layer that has a column in the data that contains school names. Most school names include the type of school they are. For instance, you may have “Lincoln Middle School” or “Bush High School.” There are variations to these names though, containing words such as “Elementary” or “Prep.” With a regular expression, you can create matching criteria that will allow you to match on many variations of the names. It is especially useful for fuzzy matches where your data is not clearly categorized. Another classic example is for matching or validating email addresses, where matching rules can become complex.
In the RegexStyle, you specify the matching criteria string and also the style you want to use to draw the feature if the criteria matches. It is a simple yet powerful style for dealing with complex rule sets and imprecise data.
*System.Object ThinkGeo.MapSuite.Core.Style *ThinkGeo.MapSuite.Core.RegexStyle
![]() | This is a constructor for the class. | ||
![]() | String, Collection<RegexItem> | This is a constructor for the class. | |
![]() | String, Collection<RegexItem>, RegexMatching | This is a constructor for the class. |
![]() | Style | Create a copy of style using the deep clone process. | |
![]() | IEnumerable<Feature>, GeoCanvas, Collection<SimpleCandidate>, Collection<SimpleCandidate> | Style | This method draws the features on the canvas you provided. |
![]() | IEnumerable<BaseShape>, GeoCanvas, Collection<SimpleCandidate>, Collection<SimpleCandidate> | Style | This method draws the shapes on the canvas you provided. |
![]() | GeoCanvas | Style | |
![]() | GeoCanvas, DrawingRectangleF | Style | This method draws a sample feature on the canvas you provided. |
![]() | Object | Object | |
![]() | Object | ||
![]() | Style | This method returns the column data for each feature that is required for the style to properly draw. | |
![]() | Object | ||
![]() ![]() | Uri | Style | |
![]() ![]() | Stream | Style | |
![]() | String | Style | |
![]() | Object |
![]() | Style | Create a copy of style using the deep clone process. The default implementation method uses serialization. | |
![]() | IEnumerable<Feature>, GeoCanvas, Collection<SimpleCandidate>, Collection<SimpleCandidate> | Style(overriden) | This method draws the features on the canvas you provided. |
![]() | Object | ||
![]() | Style(overriden) | This method returns the column data for each feature that is required for the style to properly draw. | |
![]() | Object |
![]() | String | This property gets and sets the column name whose value will be tested against the regular expression. | |
![]() | Collection<String> | Style | |
![]() | Boolean | Style | This property gets and sets the active status of the style. |
![]() | String | Style | This property gets and set the name of the style. |
![]() | Collection<RegexItem> | This property gets the collection of RegexItems. Each item can have its own regular expression to match. | |
![]() | RegexMatching | This property gets and sets the regular expression matching rule. The rule determines whether we match the entire string or just any portion of it. | |
![]() | Collection<String> | Style | This property gets the collection of fields that are required for the style. |
This is the default constructor for the class. If you use this constructor, you need to set the various properties manually.
Name | Type | Description |
This constructor allows you specify the columnName and regexItems for the class. You can also set the various properties manually.
columnName | String<!– System.String –> | This parameter is the columnName you want to use in the style. |
regexItems | Collection<RegexItem><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.Core.RegexItem} –> | This parameter specifies the regexItems in the style. |
This constructor allows you specify the columnName, regexItems and regexMatching rule for the class. You can also set the various properties manually.
regexMatching | RegexMatching<!– ThinkGeo.MapSuite.Core.RegexMatching –> | This parameter specifies the regexMatching rule for the style. |
Return Type | Description |
Style<!– ThinkGeo.MapSuite.Core.Style –> | A cloned style. |
<!– ThinkGeo.MapSuite.Core.Style –> Go Back
Void<!– System.Void –> |
features | IEnumerable<Feature><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.Core.Feature} –> | This parameter represents the features you want to draw on the canvas. |
canvas | GeoCanvas<!– ThinkGeo.MapSuite.Core.GeoCanvas –> | This parameter represents the canvas you want to draw the features on. |
labelsInThisLayer | Collection<SimpleCandidate><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.Core.SimpleCandidate} –> | The labels will be drawn in the current layer only. |
labelsInAllLayers | Collection<SimpleCandidate><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.Core.SimpleCandidate} –> | The labels will be drawn in all layers. |
shapes | IEnumerable<BaseShape><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.Core.BaseShape} –> | This parameter represents the shapes you want to draw on the canvas. |
canvas | GeoCanvas<!– ThinkGeo.MapSuite.Core.GeoCanvas –> | This parameter represents the canvas you want to draw the shapes on. |
This method is the concrete wrapper for the abstract method DrawSampleCore. In this method we draw a sample style on the canvas you provided. This is typically used to display a legend or other sample area.
drawingExtent | DrawingRectangleF<!– ThinkGeo.MapSuite.Core.DrawingRectangleF –> |
Int32<!– System.Int32 –> |
Collection<String><!– System.Collections.ObjectModel.Collection{System.String} –> | This method returns a collection of column names that the style needs. |
Type<!– System.Type –> |
<!– static –>
styleUri | Uri<!– System.Uri –> |
<!– static –>
styleStream | Stream<!– System.IO.Stream –> |
filePathName | String<!– System.String –> |
stream | Stream<!– System.IO.Stream –> |
This overridden method is called from the concrete public method Draw. In this method, we take the features you passed in and draw them on the canvas you provided. Each style based on its properties may draw each feature differently.
When overriding this method, consider each feature and its column data values. You can use the full power of the GeoCanvas to do the drawing. If you need column data for a feature, be sure to override the GetRequiredColumnNamesCore and add the columns you need to the collection. In many of the styles, we add properties to allow the user to specify which field they need; then, in the GetRequiredColumnNamesCore, we read that property and add it to the collection.
<!– ThinkGeo.MapSuite.Core.Style(overriden) –> Go Back
This virtual method is called from the concrete public method Draw. In this method, we draw a sample style on the canvas you provided. This is typically used to display a legend or other sample area.
When implementing this virtual method, consider the canvas size and draw the sample image appropriately. You should keep in mind that the sample typically shows up on a legend.
This abstract method is called from the concrete public method GetRequiredFieldNames. In this method, we return the column names that are required for the style to draw the feature properly. For example, if you have a style that colors areas blue when a certain column value is over 100, then you need to be sure you include that column name. This will ensure that the column data is returned to you in the feature when it is ready to draw.
Collection<String><!– System.Collections.ObjectModel.Collection{System.String} –> | This method returns a collection of the column names that it needs. |
This is the column we use for matching.
Return Type |
<!– ThinkGeo.MapSuite.Core.RegexStyle –> Go Back
Return Type |
Return Type |
Return Type |
You will want to add RegexItems to this collection. Each item can have its own style and matching string.
Return Type |
This is used to determine how much of a string needs to match a regular expression in order to declare it a match for that expression. Sometimes, you only need one part of the string to match in order for the expression to be considered a match; other times you may want the entire string to match.
Return Type |
Return Type |
Return Type |
