<!– Class –>
![]() | CogoCurveParameterType, Double, CogoCurveParameterType, Double, CogoCurveDirection, CogoCurveDirectionType, Double |
![]() | Object | Object | |
![]() | PointShape, PointShape | CogoCall | |
![]() | CogoDirectionType, AngleUnit | CogoCall | This method is the concrete method which always calls the associated core method. This is used to give us, the framework designer, flexability when user override the core method. |
![]() | Object | ||
![]() | Object | ||
![]() | String, CogoDirectionType, AngleUnit | CogoCall | This method is the concrete method which always calls the associated core method. This is used to give us, the framework designer, flexability when user override the core method. |
![]() | Object |
![]() | Object | ||
![]() | PointShape, PointShape | CogoCall(overriden) | |
![]() | CogoDirectionType, AngleUnit | CogoCall(overriden) | |
![]() | String, CogoDirectionType, AngleUnit | CogoCall(overriden) | |
![]() | Object |
![]() | CogoCurveDirection | ||
![]() | Double | ||
![]() | CogoCurveDirectionType | ||
![]() | Double | ||
![]() | CogoCurveParameterType | ||
![]() | Boolean | CogoCall | This porperty denotes if this call is the point of begining. This is the point from which we will begin the polygon |
![]() | Double | ||
Name | Type | Description |
firstParameterType | CogoCurveParameterType<!– ThinkGeo.MapSuite.Core.CogoCurveParameterType –> | |
firstParameter | Double<!– System.Double –> | |
secondParameterType | CogoCurveParameterType<!– ThinkGeo.MapSuite.Core.CogoCurveParameterType –> | |
secondParameter | Double<!– System.Double –> | |
curveDirection | CogoCurveDirection<!– ThinkGeo.MapSuite.Core.CogoCurveDirection –> | |
curveDirectionType | CogoCurveDirectionType<!– ThinkGeo.MapSuite.Core.CogoCurveDirectionType –> | |
curveDirectionAngle | Double<!– System.Double –> |
Return Type | Description |
LineShape<!– ThinkGeo.MapSuite.Core.LineShape –> |
startPoint | PointShape<!– ThinkGeo.MapSuite.Core.PointShape –> | |
backsightPoint | PointShape<!– ThinkGeo.MapSuite.Core.PointShape –> |
<!– ThinkGeo.MapSuite.Core.CogoCall –> Go Back
String<!– System.String –> |
returningDirectionType | CogoDirectionType<!– ThinkGeo.MapSuite.Core.CogoDirectionType –> | |
returningAngleUnit | AngleUnit<!– ThinkGeo.MapSuite.Core.AngleUnit –> |
Int32<!– System.Int32 –> |
Type<!– System.Type –> |
Void<!– System.Void –> |
traverseString | String<!– System.String –> | |
directionType | CogoDirectionType<!– ThinkGeo.MapSuite.Core.CogoDirectionType –> | |
angleUnit | AngleUnit<!– ThinkGeo.MapSuite.Core.AngleUnit –> |
<!– ThinkGeo.MapSuite.Core.CogoCall(overriden) –> Go Back
Return Type |
<!– ThinkGeo.MapSuite.Core.NonTangentCurveCogoCall –> Go Back
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
