thinkgeo.mapsuite.core.nativeimagetilecache
ThinkGeo.MapSuite.Core.NativeImageTileCache
This is the base class for NativeTileCache system which inherits from TileCache class.
ClearCache
  • Parameters:N/A
  • DeclaringType:TileCache
  • Summary:N/A
DeleteTile
DeleteTiles
Equals
  • Parameters:Object
  • DeclaringType:Object
  • Summary:N/A
GetHashCode
  • Parameters:N/A
  • Summary:N/A
GetTile
  • Parameters:RectangleShape
  • DeclaringType:N/A
  • Summary:This method returns the NativeImageTile corresponding to the tile bounding box passed in.
GetTile
  • Parameters:Int64,Int64
  • DeclaringType:N/A
  • Summary:This method returns the NativeImageTile corresponding to passed in row and column.
GetTiles
  • DeclaringType:N/A
  • Summary:This method returns all the NativeImageTiles within the passed in world extent.
GetType
  • Parameters:N/A
  • Summary:N/A
SaveTile
SaveTiles
SaveTiles
ToString
  • Parameters:N/A
  • Summary:N/A
ClearCacheCore
  • Parameters:N/A
  • Summary:N/A
DeleteTileCore
Finalize
  • Parameters:N/A
  • Summary:N/A
GetTileCore
  • DeclaringType:N/A
  • Summary:This abstract method returns the NativeImageTile corresponding to passed in row and column. Each concrete TileCache need to implement this logic to get tile from a row and column.
MemberwiseClone
  • Parameters:N/A
  • Summary:N/A
SaveTileCore
CacheId
  • Return:String
  • Summary:N/A
ImageFormat
JpegQuality
  • Return:Int16
  • Summary:N/A
LoadingTileImage
  • Return:Bitmap
  • Summary:N/A
NoDataTileImage
  • Return:Bitmap
  • Summary:N/A
TileAccessMode
TileMatrix
NativeImageTileCache(String,TileImageFormat,TileMatrix)
This is the constructor of the class.
cacheId
  • Description:This is the cache identifier which marks its difference with other TileCache. imageFormat * Type:TileImageFormat * Description:This is the imageFormate showing what kind of image we are trying to save.
tileMatrix
  • Description:This is the tile matrix system which is used for caculating tiles. Go Back ===== Public Methods ===== === ClearCache() === N/A ==== Remarks ==== N/A Return Value * Return Type:Void * Description:N/A ==== Parameters ==== Go Back === DeleteTile(Tile) === N/A ==== Remarks ==== N/A Return Value * Return Type:Void * Description:N/A ==== Parameters ==== tile * Type:Tile * Description:N/A Go Back === DeleteTiles(RectangleShape) === N/A ==== Remarks ==== N/A Return Value * Return Type:Void * Description:N/A ==== Parameters ==== worldExtent * Type:RectangleShape * Description:N/A Go Back === Equals(Object) === N/A ==== Remarks ==== N/A Return Value * Return Type:Boolean * Description:N/A ==== Parameters ==== obj * Type:Object * Description:N/A Go Back === GetHashCode() === N/A ==== Remarks ==== N/A Return Value * Return Type:Int32 * Description:N/A ==== Parameters ==== Go Back === GetTile(RectangleShape) === This method returns the NativeImageTile corresponding to the tile bounding box passed in. ==== Remarks ==== N/A Return Value * Return Type:NativeImageTile * Description:Returns the NativeImageTile corresponding to the passed in boundingBox. ==== Parameters ==== tileBoundingBox * Type:RectangleShape * Description:The target boundingBox for the tile to fetch. Go Back === GetTile(Int64,Int64) === This method returns the NativeImageTile corresponding to passed in row and column. ==== Remarks ==== N/A Return Value * Return Type:NativeImageTile * Description:Returns the NativeImageTile corresponding to the passed in row and column. ==== Parameters ==== row * Type:Int64 * Description:The target row for the tile to fetch. column * Type:Int64 * Description:The target column for the tile to fetch. Go Back === GetTiles(RectangleShape) === This method returns all the NativeImageTiles within the passed in world extent. ==== Remarks ==== N/A Return Value * Return Type:Collection<NativeImageTile> * Description:Returns a collection of NativeImageTiles within the passed in worldExtent. ==== Parameters ==== extent * Type:RectangleShape * Description:The target worldExtent will be used to fetch all the NativeImageTiles from. Go Back === GetType() === N/A ==== Remarks ==== N/A Return Value * Return Type:Type * Description:N/A ==== Parameters ==== Go Back === SaveTile(Tile) === N/A ==== Remarks ==== N/A Return Value * Return Type:Void * Description:N/A ==== Parameters ==== tile * Type:Tile * Description:N/A Go Back === SaveTiles(Bitmap,RectangleShape,Boolean) === N/A ==== Remarks ==== N/A Return Value * Return Type:Void * Description:N/A ==== Parameters ==== bitmap * Type:Bitmap * Description:N/A bitmapExtent * Type:RectangleShape * Description:N/A saveContainedCellsOnly * Type:Boolean * Description:N/A Go Back === SaveTiles(Bitmap,RectangleShape) === N/A ==== Remarks ==== N/A Return Value * Return Type:Void * Description:N/A ==== Parameters ==== bitmap * Type:Bitmap * Description:N/A bitmapExtent * Type:RectangleShape * Description:N/A Go Back === ToString() === N/A ==== Remarks ==== N/A Return Value * Return Type:String * Description:N/A ==== Parameters ==== Go Back ===== Protected Methods ===== === ClearCacheCore() === N/A ==== Remarks ==== N/A Return Value * Return Type:Void * Description:N/A ==== Parameters ==== Go Back === DeleteTileCore(Tile) === N/A ==== Remarks ==== N/A Return Value * Return Type:Void * Description:N/A ==== Parameters ==== tile * Type:Tile * Description:N/A Go Back === Finalize() === N/A ==== Remarks ==== N/A Return Value * Return Type:Void * Description:N/A ==== Parameters ==== Go Back === GetTileCore(Int64,Int64) === This abstract method returns the NativeImageTile corresponding to passed in row and column. Each concrete TileCache need to implement this logic to get tile from a row and column. ==== Remarks ==== N/A Return Value * Return Type:NativeImageTile * Description:Returns the NativeImageTile corresponding to the passed in row and column. ==== Parameters ==== row * Type:Int64 * Description:The target row for the tile to fetch. column * Type:Int64 * Description:The target column for the tile to fetch. Go Back === MemberwiseClone() === N/A ==== Remarks ==== N/A Return Value * Return Type:Object * Description:N/A ==== Parameters ==== Go Back === SaveTileCore(Tile) === N/A ==== Remarks ==== N/A Return Value * Return Type:Void * Description:N/A ==== Parameters ==== tile * Type:Tile * Description:N/A Go Back ===== Public Properties ===== === CacheId === N/A ==== Remarks ==== N/A ==== Return Value ==== Return Type:String Go Back === ImageFormat === N/A ==== Remarks ==== N/A ==== Return Value ==== Return Type:TileImageFormat Go Back === JpegQuality === N/A ==== Remarks ==== N/A ==== Return Value ==== Return Type:Int16 Go Back === LoadingTileImage === N/A ==== Remarks ==== N/A ==== Return Value ==== Return Type:Bitmap Go Back === NoDataTileImage === N/A ==== Remarks ==== N/A ==== Return Value ==== Return Type:Bitmap Go Back === TileAccessMode === N/A ==== Remarks ==== N/A ==== Return Value ==== Return Type:TileAccessMode Go Back === TileMatrix === N/A ==== Remarks ==== N/A ==== Return Value ==== Return Type**:TileMatrix
Go Back
thinkgeo.mapsuite.core.nativeimagetilecache.1442486165.txt.gz · Last modified: 2015/09/17 10:36 by admin
