thinkgeo.mapsuite.core.mssql2008featurelayer
ThinkGeo.MapSuite.Core.MsSql2008FeatureLayer
This class represents a layer backed by Microsoft SQL 2008.
      • ThinkGeo.MapSuite.Core.FeatureLayer
        • ThinkGeo.MapSuite.Core.MsSql2008FeatureLayer
MsSql2008FeatureLayer()
MsSql2008FeatureLayer(String,String,String)
  • connectionString
    • Description:This parameter represents the connection string that will be used to connect to the server.
  • tableName
    • Description:This parameter represents the table name being accessed.
  • featureIdColumn
    • Description:This parameter represents the name of the column that holds the unique feature Id.
MsSql2008FeatureLayer(String,String,String,DatabaseConnectionMode)
  • connectionString
  • tableName
  • featureIdColumn
MsSql2008FeatureLayer(String,String,String,Int32)
  • connectionString
  • tableName
  • featureIdColumn
  • srid
    • Description:Specify what kind srid data to be used.
MsSql2008FeatureLayer(String,String,String,Int32,String)
  • connectionString
  • tableName
  • featureIdColumn
  • srid
  • schemaName
MsSql2008FeatureLayer(String,String,String,Int32,DatabaseConnectionMode)
  • connectionString
  • tableName
  • featureIdColumn
  • srid
MsSql2008FeatureLayer(String,String,String,Int32,String,DatabaseConnectionMode)
  • connectionString
  • tableName
  • featureIdColumn
  • srid
  • schemaName
Validate()
Check if all geometry are valid for spatial query.
  • Description:If all geometry are valid, the count of the returning dictionary is 0.
BuildIndex(BuildIndexMode)
Build Spatial index
MakeAllGeometriesValid()
To make the geometry type data valid, and update the table.
This function will check whether the geometry is valid for spatial query, if it is not, then the function will make it valid and save it back to the table. For example: Here's a invalid LineString LINESTRING(0 2,1 1,1 0,1 1,2 2)) which is overlaps itself, it's invalid. After use this function, it will be MULTILINESTRING1)
GetFirstGeometryType()
Get The shape type from the first record.
  • Description:The shape type of the first record.
ExecuteNonQuery(String)
This method executes a query that does not return a SQL result.
This methods executes a query that has no results.
  • Description:None
  • sqlStatement
    • Description:This parameter represents the SQL statement that will be executed.
RequestDrawing()
RequestDrawing(TimeSpan)
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
GetThreadSafetyLevel()
CloneDeep()
  • Type:Layer
Open()
Close()
GetBoundingBox()
CreateTable(String,String,SpatialDataType)
This method creates a Sql Spatial Data table in MsSql2008 server.
  • connectionString
    • Description:Represents the connection string to the database
  • tableName
    • Description:Represents the name for the table
  • spatialDataType
    • Description:Represents the Spatial Data Type for the Spatial Data column
CreateTable(String,String,SpatialDataType,IEnumerable<FeatureSourceColumn>)
  • connectionString
  • tableName
  • spatialDataType
  • columns
    • Type:IEnumerable<FeatureSourceColumn>
    • Description:Represnts information for creating columns besides Spatial Data Column
CreateTable(String,String,SpatialDataType,IEnumerable<FeatureSourceColumn>,OverwriteMode)
  • connectionString
  • tableName
  • spatialDataType
  • columns
  • overwriteMode
    • Description:Indicates whether need to overwrite the datatable if there's already an exsited one
1BU=(IEnumerable<String>)
  • returningColumnNames
    • Type:IEnumerable<String>
1xU=(GeoCanvas,Dictionary<String,Collection<Feature»,Collection<SimpleCandidate>,ZoomLevel,RectangleShape)
  • featuresForFilters
  • currentZoomLevel
SetupTools()
SetupToolsCore()
OpenCore()
CloseCore()
GetBoundingBoxCore()
GetThreadSafetyLevelCore()
CloneDeepCore()
  • Type:Layer
  • e
    • Type:Exception
  • e
    • Type:Exception
  • attribution
CommandTimeout
This property gets and sets the amount of time that can elapse before the command will timeout and abort.
You can use this to set a time limit for the query before it times out.
ConnectionString
This property gets and sets the connection string that will be used to connect to the server.
TableName
This property gets or sets the table name that the database will use.
WhereClause
HasBoundingBox
This property checks to see if a Layer has a BoundingBox or not. If it has no BoundingBox, it will throw an exception when you call the GetBoundingBox() and GetFullExtent() APIs. In MsSql2008FeatureLayer, we override this API and mark it as true.
Srid
SchemaName
SpatialIndexName
FeatureIdColumn
This property gets or sets the name of the column that holds the unique feature Id.
CustomGeometryColumnName
WrappingExtent
WrappingMode
EditTools
FeatureIdsToExclude
  • Type:Collection<String>
QueryTools
MaxRecordsToDraw
FeatureSource
DrawingQuality
ZoomLevelSet
DrawingMarginPercentage
DrawingMarginInPixel
  • Type:Single
GeometryValidationMode
RequestDrawingInterval
  • Type:TimeSpan
IsOpen
DrawingTime
  • Type:TimeSpan
Attribution
IsVisible
Transparency
  • Type:Single
BlueTranslation
  • Type:Single
RedTranslation
  • Type:Single
GreenTranslation
  • Type:Single
KeyColors
IsNegative
IsGrayscale
DrawingExceptionMode
yhU=
  • Type:Int64
zRU=
  • Type:Int64
0BU=
  • Type:TimeSpan
0xU=
  • Type:TimeSpan
IsOpenCore
DrawingFeatures N/A
DrawingWrappingFeatures N/A
RequestedDrawing N/A
RequestingDrawing N/A
DrawingProgressChanged N/A
DrawingException N/A
DrawnException N/A
DrawingAttribution N/A
DrawnAttribution N/A
1) 0 2,1 1,2 2),(1 1,1 0
thinkgeo.mapsuite.core.mssql2008featurelayer.1442555241.txt.gz · Last modified: 2015/09/18 05:47 by admin
