<!– Class –> (This class is not finally released, it is possible to be removed in the next public release)
*System.Object ThinkGeo.MapSuite.Core.Feature *ThinkGeo.MapSuite.Core.LinkFeature
*LinkFeature | |||
*LinkFeature | Feature |
*CloneDeepCore | IEnumerable<String> | Feature(overriden) | |
*Finalize | Object | ||
*GetBoundingBoxCore | Feature | ||
*GetGeoJsonCore | Feature | ||
*GetShapeCore | Feature | ||
*GetWellKnownBinaryCore | RingOrder, WkbByteOrder | Feature | |
*GetWellKnownTextCore | RingOrder | Feature | |
*GetWellKnownTypeCore | Feature | ||
*MemberwiseClone | Object |
*CanMakeValid | Boolean | Feature | |
*ColumnValues | Dictionary<String,String> | Feature | |
*Id | String | Feature | |
*LinkColumnValues | Dictionary<String,Object> | ||
*Tag | Object | Feature |
| Feature<!– ThinkGeo.MapSuite.Core.Feature –> |
| distance | Double<!– System.Double –> | |
| featureUnit | GeographyUnit<!– ThinkGeo.MapSuite.Core.GeographyUnit –> | |
| distanceUnit | DistanceUnit<!– ThinkGeo.MapSuite.Core.DistanceUnit –> |
<!– ThinkGeo.MapSuite.Core.Feature –> Go Back
| quadrantSegments | Int32<!– System.Int32 –> | |
| bufferCapType | BufferCapType<!– ThinkGeo.MapSuite.Core.BufferCapType –> | |
| returningColumnNamesType | ReturningColumnsType<!– ThinkGeo.MapSuite.Core.ReturningColumnsType –> |
| returningColumnNames | IEnumerable<String><!– System.Collections.Generic.IEnumerable{System.String} –> |
| targetFeature | Feature<!– ThinkGeo.MapSuite.Core.Feature –> |
<!– static –>
| geoJson | String<!– System.String –> |
<!– static –>
| wellKnownText | String<!– System.String –> |
<!– static –>
| wellKnownBinary | Byte[]<!– System.Bytethinkgeo.mapsuite.core.linkfeature –> |
| RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> |
| BaseShape<!– ThinkGeo.MapSuite.Core.BaseShape –> |
| outerRingOrder | RingOrder<!– ThinkGeo.MapSuite.Core.RingOrder –> | |
| byteOrder | WkbByteOrder<!– ThinkGeo.MapSuite.Core.WkbByteOrder –> |
| WellKnownType<!– ThinkGeo.MapSuite.Core.WellKnownType –> |
<!– static –>
| targetFeatures | IEnumerable<Feature><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.Core.Feature} –> |
<!– ThinkGeo.MapSuite.Core.Feature(overriden) –> Go Back
| Dictionary<String,String><!– System.Collections.Generic.Dictionary{System.String,System.String} –> |
| Dictionary<String,Object><!– System.Collections.Generic.Dictionary{System.String,System.Object} –> |
<!– ThinkGeo.MapSuite.Core.LinkFeature –> Go Back
NOTOC Note: * – not public released, might be removed in the next release. MapSuiteCore ThinkGeo.MapSuite.Core UpdateDocumentation
