This class encapsulates both two-color gradients and custom multicolor gradients.
All linear gradients are defined along a line specified either by the width of a rectangle or by two points.
By default, a two-color linear gradient is an even horizontal linear blend from the starting color to the ending color along the specified line.
![]() | GeoColor, GeoColor, GeoLinearGradientDirection | Create an instance of GeoLinearGradientBrush by passing a gradient start color and gradient end color followed by the gradient direction enum. | |
![]() | GeoColor, GeoColor, Single | Create an instance of GeoLinearGradientBrush by passing a gradient start color and gradient end color followed by the gradient direction angle. |
![]() | Create a new instance of the GeoLinearGradientBrush with default settings. |
![]() | GeoBrush | Create a copy of GeoBrush using the deep clone process. The default implementation uses serialization. | |
![]() | Object | ||
![]() | Object |
![]() | Single | Gets or sets the Direction angle of the GeoLinearGradientBrush. | |
![]() | GeoColor | Gets or sets the ending GeoColor of the gradient. | |
![]() | Int64 | GeoBrush | The id of the GeoBrush. This is always used as a key when in the cached brushes. |
![]() | GeoColor | Gets or sets the starting GeoColor of the gradient. | |
![]() | GeoWrapMode | Gets or sets a GeoWrapMode enumeration that indicates the wrap mode for the GeoLinearGradientBrush. |
Name | Type | Description |
startColor | GeoColor | This parameter specifies the starting GeoColor of the GeoLinearGradientBrush. |
endColor | GeoColor | This parameter specifies the endding GeoColor of the GeoLinearGradientBrush. |
direction | GeoLinearGradientDirection | This parameter specifies the GeoLinearGradientDirection enumeration of the GeoLinearGradientBrush. |
directionAngle | Single | This parameter specifies the direction angle value of the GeoLinearGradientBrush. |
Return Type | Description |
GeoBrush | A cloned GeoBrush. |
<!– ThinkGeo.MapSuite.Core.GeoBrush –> Go Back
Boolean |
obj | Object |
Int32 |
Type |
String |
Void |
Object |
Return Type |
Single |
Return Type |
Int64 |
Return Type |
GeoWrapMode |
