thinkgeo.mapsuite.core.geobrush
ThinkGeo.MapSuite.Core.GeoBrush
GeoBrush()
This is the constructor for the GeoBrush
CloneDeep()
Create a copy of GeoBrush using the deep clone process.
  • Type:GeoBrush
  • Description:A cloned GeoBrush.
CloneDeepCore()
Create a copy of GeoBrush using the deep clone process. The default implementation uses serialization.
  • Type:GeoBrush
Id
The id of the GeoBrush. This is always used as a key when in the cached brushes.
  • Type:Int64
thinkgeo.mapsuite.core.geobrush.1442554929.txt.gz · Last modified: 2015/09/18 05:42 by admin
