thinkgeo.mapsuite.core.geobrush
ThinkGeo.MapSuite.Core.GeoBrush
GeoBrush
  • Parameters:N/A
  • DeclaringType:N/A
  • Summary:This is the constructor for the GeoBrush
CloneDeep
  • Parameters:N/A
  • DeclaringType:N/A
  • Summary:Create a copy of GeoBrush using the deep clone process.
Equals
  • Parameters:Object
  • DeclaringType:Object
  • Summary:N/A
GetHashCode
  • Parameters:N/A
  • Summary:N/A
GetType
  • Parameters:N/A
  • Summary:N/A
ToString
  • Parameters:N/A
  • Summary:N/A
CloneDeepCore
  • Parameters:N/A
  • DeclaringType:N/A
  • Summary:Create a copy of GeoBrush using the deep clone process. The default implementation uses serialization.
Finalize
  • Parameters:N/A
  • Summary:N/A
MemberwiseClone
  • Parameters:N/A
  • Summary:N/A
Id
  • Return:Int64
  • Summary:The id of the GeoBrush. This is always used as a key when in the cached brushes.
GeoBrush()
CloneDeep()
  • Return Type:GeoBrush
  • Description:A cloned GeoBrush.
  • Return Type:Boolean
obj
Go Back
  • Return Type:Int32
  • Return Type:Type
  • Return Type:String
CloneDeepCore()
  • Return Type:Void
  • Return Type:Object
Id
Return Type:Int64
Go Back
thinkgeo.mapsuite.core.geobrush.1442485759.txt.gz · Last modified: 2015/09/17 10:29 by admin
