thinkgeo.mapsuite.core.geobrush
ThinkGeo.MapSuite.Core.GeoBrush
<!– Class –> Defines objects used to fill the interiors of AreaBaseShapes, such as MultiPolygonShape, PolygonShape, EllipseShape, and other AreaBaseShapes.
This is an abstract base class and cannot be instantiated. To create a GeoBrush object, use classes derived from GeoBrush, such as GeoSolidBrush.
Protected MethodGeoBrush This is the constructor for the GeoBrush
Public MethodCloneDeep Create a copy of GeoBrush using the deep clone process.
Public MethodGetType Object
Public MethodToString Object
Protected MethodCloneDeepCore Create a copy of GeoBrush using the deep clone process. The default implementation uses serialization.
Public PropertyId Int64 The id of the GeoBrush. This is always used as a key when in the cached brushes.
GeoBrush()
Name Type Description
Go Back
CloneDeep()
Return Type Description
GeoBrush<!– ThinkGeo.MapSuite.Core.GeoBrush –> A cloned GeoBrush.
<!– ThinkGeo.MapSuite.Core.GeoBrush –> Go Back
Boolean<!– System.Boolean –>
Int32<!– System.Int32 –>
Type<!– System.Type –>
String<!– System.String –>
CloneDeepCore()
Void<!– System.Void –>
Id
Return Type
Int64<!– System.Int64 –>
thinkgeo.mapsuite.core.geobrush.1440040128.txt.gz · Last modified: 2015/09/17 09:00 (external edit)
