thinkgeo.mapsuite.core.fontpointstyle
ThinkGeo.MapSuite.Core.FontPointStyle
<!– Class –>
Public MethodFontPointStyle
Public MethodCloneDeep Style Create a copy of style using the deep clone process.
Public MethodDraw IEnumerable<Feature>, GeoCanvas, Collection<SimpleCandidate>, Collection<SimpleCandidate> Style This method draws the features on the canvas you provided.
Public MethodDraw IEnumerable<BaseShape>, GeoCanvas, Collection<SimpleCandidate>, Collection<SimpleCandidate> Style This method draws the shapes on the canvas you provided.
Public MethodDrawSample GeoCanvas, DrawingRectangleF Style This method draws a sample feature on the canvas you provided.
Public MethodDrawSample GeoCanvas Style
Public MethodGetRequiredColumnNames Style This method returns the column data for each feature that is required for the style to properly draw.
Public MethodGetType Object
Public MethodStatic MemberLoadStyle Uri Style
Public MethodStatic MemberLoadStyle Stream Style
Public MethodToString Object
Protected MethodCloneDeepCore Style Create a copy of style using the deep clone process. The default implementation method uses serialization.
Protected MethodDrawCore IEnumerable<Feature>, GeoCanvas, Collection<SimpleCandidate>, Collection<SimpleCandidate> Style(overriden)
Protected MethodDrawSampleCore GeoCanvas, DrawingRectangleF Style(overriden)
Protected MethodGetRequiredColumnNamesCore Style This method returns the column data for each feature that is required for the style to properly draw.
Public PropertyAdvanced PointStyleAdvanced PointBaseStyle
Public PropertyCharacterFont GeoFont PointStyle This property gets and sets the font that is used for the character if the PointType is Character.
Public PropertyCharacterIndex Int32 PointStyle This property gets and sets the index position of the character you want to use from the font you selected in the CharacterFont property.
Public PropertyCharacterSolidBrush GeoSolidBrush PointStyle This property gets and sets the SolidBrush used to color the font character for the point.
Public PropertyCustomPointStyles Collection<PointBaseStyle> PointStyle This property returns a collection of area styles allowing you to stack multiple area styles on top of each other.
Public PropertyDrawingLevel DrawingLevel PointBaseStyle
Public PropertyFilters Collection<String> Style
Public PropertyImage GeoImage PointStyle This property gets and sets the image used if the PointType property is Bitmap.
Public PropertyImageScale Double PointStyle This property gets and sets the scale of the image you want to draw.
Public PropertyIsActive Boolean Style This property gets and sets the active status of the style.
Public PropertyName String Style This property gets and set the name of the style.
Public PropertyPointType PointType PointStyle This property gets and sets the type of point you want to draw.
Public PropertyRequiredColumnNames Collection<String> Style This property gets the collection of fields that are required for the style.
Public PropertyRotationAngle Single PointBaseStyle This property gets and sets the angle of rotation for the drawing of the point.
Public PropertySymbolPen GeoPen PointBaseStyle This property gets and sets the SolidBrush used to draw the oultine of the Symbol.
Public PropertySymbolSize Single PointBaseStyle This property gets and sets the size of the symbol if the PointType is Symbol.
Public PropertySymbolSolidBrush GeoSolidBrush PointBaseStyle This property gets and sets the SolidBrush used to color the interior of the Symbol.
Public PropertySymbolType PointSymbolType PointStyle This property gets and sets the type of symbol you want to use if the PointType is Symbol.
Public PropertyXOffsetInPixel Single PointBaseStyle This property gets and sets the X pixel offset for drawing each feature.
Public PropertyYOffsetInPixel Single PointBaseStyle This property gets and sets the Y pixel offset for drawing each feature.
Protected PropertyFiltersCore Collection<String> Style
FontPointStyle()
Name Type Description
Go Back
CloneDeep()
Return Type Description
Style<!– ThinkGeo.MapSuite.Core.Style –> A cloned style.
<!– ThinkGeo.MapSuite.Core.Style –> Go Back
Draw(IEnumerable<Feature>, GeoCanvas, Collection<SimpleCandidate>, Collection<SimpleCandidate>)
Void<!– System.Void –>
features IEnumerable<Feature><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.Core.Feature} –> This parameter represents the features you want to draw on the canvas.
canvas GeoCanvas<!– ThinkGeo.MapSuite.Core.GeoCanvas –> This parameter represents the canvas you want to draw the features on.
labelsInThisLayer Collection<SimpleCandidate><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.Core.SimpleCandidate} –> The labels will be drawn in the current layer only.
labelsInAllLayers Collection<SimpleCandidate><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.Core.SimpleCandidate} –> The labels will be drawn in all layers.
Draw(IEnumerable<BaseShape>, GeoCanvas, Collection<SimpleCandidate>, Collection<SimpleCandidate>)
shapes IEnumerable<BaseShape><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.Core.BaseShape} –> This parameter represents the shapes you want to draw on the canvas.
canvas GeoCanvas<!– ThinkGeo.MapSuite.Core.GeoCanvas –> This parameter represents the canvas you want to draw the shapes on.
DrawSample(GeoCanvas, DrawingRectangleF)
This method is the concrete wrapper for the abstract method DrawSampleCore. In this method we draw a sample style on the canvas you provided. This is typically used to display a legend or other sample area.
drawingExtent DrawingRectangleF<!– ThinkGeo.MapSuite.Core.DrawingRectangleF –>
DrawSample(GeoCanvas)
Boolean<!– System.Boolean –>
Int32<!– System.Int32 –>
GetRequiredColumnNames()
Collection<String><!– System.Collections.ObjectModel.Collection{System.String} –> This method returns a collection of column names that the style needs.
Type<!– System.Type –>
LoadStyle(Uri)
<!– static –>
styleUri Uri<!– System.Uri –>
LoadStyle(Stream)
<!– static –>
styleStream Stream<!– System.IO.Stream –>
String<!– System.String –>
CloneDeepCore()
DrawCore(IEnumerable<Feature>, GeoCanvas, Collection<SimpleCandidate>, Collection<SimpleCandidate>)
<!– ThinkGeo.MapSuite.Core.Style(overriden) –> Go Back
DrawSampleCore(GeoCanvas, DrawingRectangleF)
GetRequiredColumnNamesCore()
This abstract method is called from the concrete public method GetRequiredFieldNames. In this method, we return the column names that are required for the style to draw the feature properly. For example, if you have a style that colors areas blue when a certain column value is over 100, then you need to be sure you include that column name. This will ensure that the column data is returned to you in the feature when it is ready to draw.
Advanced
Return Type
PointStyleAdvanced<!– ThinkGeo.MapSuite.Core.PointStyleAdvanced –>
<!– ThinkGeo.MapSuite.Core.PointBaseStyle –> Go Back
CharacterFont
This property allows you to set the font from which to select a character index if you choose the Character PointType.
Return Type
GeoFont<!– ThinkGeo.MapSuite.Core.GeoFont –>
<!– ThinkGeo.MapSuite.Core.PointStyle –> Go Back
CharacterIndex
You need to specify the index position of the character you want to use from the font you selected. For example, if you choose 1, then we will use the first character in the font you set in the CharacterFont property.
Return Type
CharacterSolidBrush
This brush is used to draw the character. It is only used if the PointType is Character. If you need a brush other than the SolidBrush, you should look in the advanced property of the class.
Return Type
GeoSolidBrush<!– ThinkGeo.MapSuite.Core.GeoSolidBrush –>
CustomPointStyles
Using this collection, you can stack multiple styles on top of each other. When we draw the feature, we will draw them in order that they exist in the collection. You can use these stacks to create drop shadow effects, multiple colored outlines, etc.
Return Type
Collection<PointBaseStyle><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.Core.PointBaseStyle} –>
DrawingLevel
Return Type
DrawingLevel<!– ThinkGeo.MapSuite.Core.DrawingLevel –>
Filters
Return Type
This property is where you can set the image for the points if the PointType is Bitmap. It uses a GeoImage, so you can either reference a file or supply a stream.
Return Type
GeoImage<!– ThinkGeo.MapSuite.Core.GeoImage –>
ImageScale
This property allows you to scale the image up and down depending on how large or small you want it. It can be changed dynamically, so you could change it at every scale level to resize the bitmap based on the current scale. A scale of 1 would be the original size, while a scale of 2 would double the size. A scale of .5 would reduce the size of the image by half, and so on.
Return Type
Double<!– System.Double –>
IsActive
Return Type
Return Type
PointType
When using the PointStyle you choose between a bitmap, a font or a predefined symbol to represent the point. Each of these options has corresponding properties on the point symbol. If you set the type to character, then you need to set the properties that start with “Character,” such as “CharacterFont.” The same is true for the symbol.
Return Type
PointType<!– ThinkGeo.MapSuite.Core.PointType –>
RequiredColumnNames
Return Type
RotationAngle
This property controls the rotation of the bitmap, character or symbol, depending on the PointType.
Return Type
Single<!– System.Single –>
SymbolPen
This pen is used to draw the outline of the Symbol. By default the pen draws a transparent (invisible) color, which just leaves you with a fill.
Return Type
GeoPen<!– ThinkGeo.MapSuite.Core.GeoPen –>
SymbolSize
The allows you to make the symbol larger and smaller.
Return Type
SymbolSolidBrush
This brush is used to draw the interior of the symbol. It is only used if the PointType is Symbol. If you need a brush other than the SolidBrush, you should look in the advanced property of the class.
Return Type
SymbolType
You can choose between a number of predefined symbols. The symbols are simple geometric objects that are typically used for abstract representations on a map. If there is a specific symbol you need that is not part of our symbol collection, you can submit it to us and we will consider adding it.
Return Type
PointSymbolType<!– ThinkGeo.MapSuite.Core.PointSymbolType –>
XOffsetInPixel
This property allows you to specify an X offset. When combined with a Y offset, it is useful to allow you to achieve effects such as drop shadows, etc. There also may be times when you need to modify the location of feature data so as to better align it with raster satellite data.
Return Type
YOffsetInPixel
This property allows you to specify a Y offset. When combined with an X offset, it is useful to allow you to achieve effects such as drop shadows, etc. There also may be times when you need to modify the location of feature data so as to better align it with raster satellite data.
Return Type
FiltersCore
Return Type
thinkgeo.mapsuite.core.fontpointstyle.txt · Last modified: 2017/03/16 21:59 (external edit)
