<!– Class –> This class is a concrete class inherits from NativeImageTileCache. In this class, the tiles will be saved in disk and can be viewed very conveniently.
*System.Object ThinkGeo.MapSuite.Core.TileCache *ThinkGeo.MapSuite.Core.NativeImageTileCache ThinkGeo.MapSuite.Core.FileNativeImageTileCache
![]() | This is the default constructor. | ||
![]() | String, String, TileImageFormat, TileMatrix | This is the constructor with all the parameters needed passed in. |
![]() | TileCache | This method will clear all the tiles in the tileCache. | |
![]() | Tile | TileCache | This method will delete the target tile passed in. |
![]() | RectangleShape | TileCache | This method will delete the tiles within the passed in worldExtent. |
![]() | Object | Object | |
![]() | Object | ||
![]() | RectangleShape | NativeImageTileCache | This method returns the NativeImageTile corresponding to the tile bounding box passed in. |
![]() | Int64, Int64 | NativeImageTileCache | This method returns the NativeImageTile corresponding to passed in row and column. |
![]() | RectangleShape | NativeImageTileCache | This method returns all the NativeImageTiles within the passed in world extent. |
![]() | Object | ||
![]() | Tile | TileCache | This method will save the target tile passed in. |
![]() | Bitmap, RectangleShape, Boolean | TileCache | |
![]() | Bitmap, RectangleShape | TileCache | This method will save the bitmap with its extent attached into tiles. |
![]() | Object |
![]() | TileCache(overriden) | This method will clear all the tiles in the tileCache. | |
![]() | Tile | TileCache(overriden) | This method will delete the target tile passed in. |
![]() | Object | ||
![]() | Int64, Int64 | NativeImageTileCache(overriden) | This method returns the NativeImageTile corresponding to passed in row and column. |
![]() | Object | ||
![]() | Tile | TileCache(overriden) | This method will save the target tile passed in, you could override this API to create your own logic. |
![]() | String | Gets or sets the cache direcory. | |
![]() | String | TileCache | Gets or sets the id of the TileCache. |
![]() | TileImageFormat | TileCache | Gets or sets the tile image format. |
![]() | Int16 | TileCache | Gets or sets the Jpeg quality , this property only take effects when setting the ImageFormat to Jpeg. |
![]() | Bitmap | TileCache | This property returns back a preset image showing the Tile is loading. |
![]() | Bitmap | TileCache | This property returns back a preset image showing the tile data is missing. |
![]() | TileAccessMode | TileCache | Gets or sets the Mode for the TileCache access the tiles. The Default value is ReadAddDelete |
![]() | TileMatrix | TileCache | Gets or sets the TileMatrix which is used in caculation for tiles. |
If you use this constructor, you have to set the properties manually.
Name | Type | Description |
cacheDirectory | String<!– System.String –> | This parameter specifies the cache directory of the tile cache. |
cacheId | String<!– System.String –> | This parameter specifies the cache id of the tile cache. |
imageFormat | TileImageFormat<!– ThinkGeo.MapSuite.Core.TileImageFormat –> | This parameter specifies the image format of the tile cahce. |
tileMatrix | TileMatrix<!– ThinkGeo.MapSuite.Core.TileMatrix –> | This parameter specifies the tile matrix of the tile cache. |
This method will not take effect when the ReadOnly is set to true.
Return Type | Description |
Void<!– System.Void –> |
<!– ThinkGeo.MapSuite.Core.TileCache –> Go Back
tile | Tile<!– ThinkGeo.MapSuite.Core.Tile –> | The target tile to be deleted. |
worldExtent | RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | The target extent to delete all tiles within it. |
Int32<!– System.Int32 –> |
NativeImageTile<!– ThinkGeo.MapSuite.Core.NativeImageTile –> | Returns the NativeImageTile corresponding to the passed in boundingBox. |
tileBoundingBox | RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | The target boundingBox for the tile to fetch. |
<!– ThinkGeo.MapSuite.Core.NativeImageTileCache –> Go Back
NativeImageTile<!– ThinkGeo.MapSuite.Core.NativeImageTile –> | Returns the NativeImageTile corresponding to the passed in row and column. |
row | Int64<!– System.Int64 –> | The target row for the tile to fetch. |
column | Int64<!– System.Int64 –> | The target column for the tile to fetch. |
Collection<NativeImageTile><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.Core.NativeImageTile} –> | Returns a collection of NativeImageTiles within the passed in worldExtent. |
extent | RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | The target worldExtent will be used to fetch all the NativeImageTiles from. |
Type<!– System.Type –> |
tile | Tile<!– ThinkGeo.MapSuite.Core.Tile –> | The target tile to be saved. |
bitmap | Bitmap<!– System.Drawing.Bitmap –> | |
bitmapExtent | RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | |
saveContainedCellsOnly | Boolean<!– System.Boolean –> |
bitmap | Bitmap<!– System.Drawing.Bitmap –> | The target bitmap to be saved into tiles. |
bitmapExtent | RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | The target extent for the bitmap. |
<!– ThinkGeo.MapSuite.Core.TileCache(overriden) –> Go Back
<!– ThinkGeo.MapSuite.Core.NativeImageTileCache(overriden) –> Go Back
Return Type |
<!– ThinkGeo.MapSuite.Core.FileNativeImageTileCache –> Go Back
Return Type |
Return Type |
Return Type |
Int16<!– System.Int16 –> |
Return Type |
Return Type |
If you want it to take effect, you need set the ReadOnly property false.
Return Type |
TileAccessMode<!– ThinkGeo.MapSuite.Core.TileAccessMode –> |
Return Type |
