thinkgeo.mapsuite.core.cogocall
ThinkGeo.MapSuite.Core.CogoCall
<!– Class –> This is an abstract class which is the basis for each of the different types of COGO calls In the abstract class we define that a call need to be able to produce a line segment as well as produce its traverse and description string.
Protected MethodCogoCall
Public MethodGetCallLine PointShape, PointShape
Public MethodGetDescriptionString CogoDirectionType, AngleUnit This method is the concrete method which always calls the associated core method. This is used to give us, the framework designer, flexability when user override the core method.
Public MethodGetTraverseString CogoDirectionType, AngleUnit This method is the concrete method which always calls the associated core method. This is used to give us, the framework designer, flexability when user override the core method.
Public MethodGetType Object
Public MethodLoadFromTraverseString String, CogoDirectionType, AngleUnit This method is the concrete method which always calls the associated core method. This is used to give us, the framework designer, flexability when user override the core method.
Public MethodToString Object
Protected MethodGetCallLineCore PointShape, PointShape
Protected MethodGetDescriptionStringCore CogoDirectionType, AngleUnit This abstract method has to be overridden in sub classes. It is responsible for converting the call into a descriptive string which will display on the call grid
Protected MethodGetTraverseStringCore CogoDirectionType, AngleUnit This abstract method has to be overridden in sub classes. It is responsible for converting the call into a traverse string used to build up the traverse file for saving
Protected MethodLoadFromTraverseStringCore String, CogoDirectionType, AngleUnit This method will populate this class from a single line of a traverse string
Public PropertyIsPointOfBeginning Boolean This porperty denotes if this call is the point of begining. This is the point from which we will begin the polygon
CogoCall()
Name Type Description
Go Back
Return Type Description
Boolean<!– System.Boolean –>
GetCallLine(PointShape, PointShape)
LineShape<!– ThinkGeo.MapSuite.Core.LineShape –>
startPoint PointShape<!– ThinkGeo.MapSuite.Core.PointShape –>
backsightPoint PointShape<!– ThinkGeo.MapSuite.Core.PointShape –>
<!– ThinkGeo.MapSuite.Core.CogoCall –> Go Back
GetDescriptionString(CogoDirectionType, AngleUnit)
String<!– System.String –>
returningDirectionType CogoDirectionType<!– ThinkGeo.MapSuite.Core.CogoDirectionType –>
returningAngleUnit AngleUnit<!– ThinkGeo.MapSuite.Core.AngleUnit –>
Int32<!– System.Int32 –>
GetTraverseString(CogoDirectionType, AngleUnit)
Type<!– System.Type –>
LoadFromTraverseString(String, CogoDirectionType, AngleUnit)
Void<!– System.Void –>
traverseString String<!– System.String –>
directionType CogoDirectionType<!– ThinkGeo.MapSuite.Core.CogoDirectionType –>
angleUnit AngleUnit<!– ThinkGeo.MapSuite.Core.AngleUnit –>
GetCallLineCore(PointShape, PointShape)
GetDescriptionStringCore(CogoDirectionType, AngleUnit)
GetTraverseStringCore(CogoDirectionType, AngleUnit)
LoadFromTraverseStringCore(String, CogoDirectionType, AngleUnit)
IsPointOfBeginning
Return Type
thinkgeo.mapsuite.core.cogocall.1440040128.txt.gz · Last modified: 2015/09/17 08:57 (external edit)
