<!– Class –> Provides data for the VertexMoved. event.
*System.Object System.EventArgs *ThinkGeo.MapSuite.AndroidEdition.VertexMovedEditInteractiveOverlayEventArgs
VertexMovedEditInteractiveOverlayEventArgs | This is the default constructor of this parameter. | ||
VertexMovedEditInteractiveOverlayEventArgs | Feature, Vertex | This is the commonly used constructor. |
AffectedVertexFeature | Feature | This property gets or sets the Feature to be used to remove vertex. | |
MovedVertex | Vertex | This property gets or sets the vertex moved. |
| Feature<!– ThinkGeo.MapSuite.Core.Feature –> |
<!– ThinkGeo.MapSuite.AndroidEdition.VertexMovedEditInteractiveOverlayEventArgs –> Go Back
| Vertex<!– ThinkGeo.MapSuite.Core.Vertex –> |
