thinkgeo.mapsuite.androidedition.overlay
ThinkGeo.MapSuite.AndroidEdition.Overlay
This class is the base class of all overlays in this overlay system.
Overlay()
Refresh(IEnumerable<RectangleShape>)
Refresh(TimeSpan)
  • bufferTime
    • Type:TimeSpan
Refresh(TimeSpan,RequestDrawingBufferTimeType)
  • bufferTime
    • Type:TimeSpan
Refresh(TimeSpan,BufferTimeType)
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
Refresh(RectangleShape,TimeSpan,BufferTimeType)
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
Refresh(IEnumerable<RectangleShape>,TimeSpan,BufferTimeType)
  • bufferTime
    • Type:TimeSpan
GetBoundingBox()
This method gets a bounding box of the Overlay.
This method is the concrete wrapper for the abstract method GetBoundingBoxCore. This method returns the bounding box of the Overlay. As this is a concrete public method that wraps a Core method, we reserve the right to add events and other logic to pre- or post-process data returned by the Core version of the method. In this way, we leave our framework open on our end, but also allow you the developer to extend our logic to suit your needs. If you have questions about this, please contact our support team as we would be happy to work with you on extending our framework.
  • Description:A RectangleShape indicating the bounding box of this overlay.
Initialize(MapArguments)
This method initializes overlay object.
This is a wrapper method for the virtual method InitializeCore.
  • mapArguments
    • Description:This parameter maintains current map information for calculating mechanism.
Refresh()
This method refreshes all the content in the OverlayCanvas. For example, LayerOverlay with multiple tiles; when the style of one layer is changed, call Refresh to refresh all the tiles to accept new styles.
Refresh(RectangleShape)
Draw(MapArguments,OverlayRefreshType)
This method draws the overlay with the provided extent in world coordinate.
  • mapArguments
  • refreshType
    • Description:This parameter indicates whether the elements of this overlay needs to be refreshed. For example, TileOverlay is formed by tiles. When panning the map around, the existing tile doesn't need to be redraw, the only thing we need to do is modifying the position of these tiles. On another hand, when click to change the style of the overlay, we need to redraw the tile images to change the appearance. So we need refresh mode.
PostTransform(TransformArguments,MapArguments)
This method will simulate the PostTransform interaction.
  • transformInfo
    • Description:This parameter maintains the transfrom information for calculating transform.
  • mapArguments
Close()
This method will simulate the Close interaction.
Open()
This method will simulate the Open interaction.
Dispose()
This method dispose unmanaged resource used in this class.
GetBoundingBoxCore()
  • Description:This method returns the bounding box of the Overlay.
RefreshCore()
RefreshCore(RectangleShape)
DrawCore(MapArguments,OverlayRefreshType)
  • mapArguments
  • refreshType
PostTransformCore(TransformArguments,MapArguments)
This protected virtual method is the Core method of PostTransform API.
  • transformInfo
  • mapArguments
CloseCore()
This protected virtual method is the Core method of Close API.
OpenCore()
This protected virtual method is the Core method of Open API.
InitializeCore(MapArguments)
When implementing this method, consider initializing the overlay canvas such as setting its z-index, setting current map reference to the CurrentMap property.
  • exception
    • Type:Exception
  • ex
    • Type:Exception
OnDrawingException(DrawingExceptionOverlayEventArgs)
This method raises before the overlay is drawing exception.
OnDrawnException(DrawnExceptionOverlayEventArgs)
This method raises after the overlay is drawn exception.
Dispose(Boolean)
Releases unmanaged and - optionally - managed resources.
  • disposing
    • Description:true to release both managed and unmanaged resources; false to release only unmanaged resources.
AutoRefreshInterval
  • Type:TimeSpan
Gets or sets the name of this overaly.
DrawingExceptionMode
This property gets and sets the DrawingExceptionMode used when an exception occurs during drawing.
IsEmpty
This property gets if this overlay is empty or not.
This property enhances the performance of the overlay while drawing. If is true, we will skip drawing this overlay and continue drawing the next overlay.
IsVisible
Gets or sets if this overlay is visible.
Attribution
Gets or sets the attribution for this overlay.
OverlayView
DrawingQuality
Gets or sets the drawingQuality for this overlay.
Opacity
Gets or sets the opacity for this overlay.
MapArguments
Gets or sets the mapArguments for this overlay.
CanRefreshRegion
DrawingException Occurs before exception is drawing on map.
Event Arguments:DrawingExceptionOverlayEventArgs
DrawnException Occurs after exception is drawn on map.
Event Arguments:DrawnExceptionOverlayEventArgs
thinkgeo.mapsuite.androidedition.overlay.1442831492.txt.gz · Last modified: 2015/09/21 10:31 by admin
