map_suite_web_for_webforms
Map Suite Web for WebForms
Map Suite Web for WebForms is a .NET native GIS control that allows software developers to create interactive online mapping applications with ease. Packed with powerful AJAX interactivity, a simple API that makes coding easy, and royalty-free distribution, Map Suite Web For Webformsenables you to bring your Internet GIS application to market in record time.
Map Suite Web for WebForms Quickstart On Windows
Map Suite Web for WebForms Quickstart On Linux
Run GitHub Sample on Windows (2'30”)
Map Suite Web for WebForms Hello World
Hello World on Windows (3'09“)
Product Guides
Helps you get you up to speed with integrating the Map Suite Web For Webformsmap control into your your GIS software.
Introduces the dependencies Map Suite Web For Webformsneeds with their features, versions and source websites.
Walks you through deploying your project using the map control into a windows azure cloud service and register the map control.
Show Map Suite features doverage of different product and different platfoms
Code Samples
In addition to the samples below, we have dozens of interactive Map Suite Web for WebForms sample applications available here.
All Samples
All samples about Map Suite Map Suite Web for WebForms.
Project Templates
These projects show various study cases based on Map Suite Web for WebForms.
Background Maps
InteractiveOverlays
Labeling
Layers & FeatureSources
Miscellaneous
Printing
Projection
Spatial Functions
Styles
Vehicle Tracking
Zooming Panning Moving
Package
Standard
Compare with Barebone
Barebone
Compare with Standard
API Documentation
  • ThinkGeo.MapSuite.WebForms
    The Map Suite Web For WebForms API documentation covers the ThinkGeo.MapSuite.WebForms namespace which resides in the ThinkGeo.MapSuite.WebFroms.dll assembly. It contains all of the Map Suite Web For WebForms specific classes such as the map control itself, Overlays, and supported map classes.
Change Logs
  • API Change Log
Videos
Map Suite Web for WebForms Sample App Walkthrough Video Series
Step through the Map Suite Web for WebForms sample applications and see how they're put together. We'll demonstrate how to use each app, then take you through every part of the source code and show you how it works.
Introduction to the Web Edition
Introduction to the Map Suite Web for WebForms
Creating Custom Styles
Exploring Layers
Exploring Layers
FDO, OGR and GDAL Extension
Printing System Introduction
Tile Cache Generator
Topology Validation
Topology Validation
Screenshots
The Map Suite Web for WebForms screenshots gallery section displays a wide range of screenshots covering various GIS features of the Map Suite Web for WebForms map control.
No extra coding necessary
Includes panning, zooming, scale bar, mini map & more
No extra coding necessary Includes panning, zooming, scale bar, mini map & more
Track multiple markers
Load meta data from XML
Show details in a popup
Track multiple markers Load meta data from XML Show details in a popup
Automatically track multiple vehicle locations
Track weather features
Automatically track multiple vehicle locations Track weather features
Uses ZedGraph classes
Design your own tooltips with custom HTML
Include images
Design your own tooltips with custom HTML Include images
Draw track shapes
Edit and rotate shapes
Save shapes to the server
Draw track shapes Edit and rotate shapes Save shapes to the server
Plots points on your map
Point density represents numeric data
Puts you in control
Useful for points & labels
Render features specifically based on a theme
Colorize map features
Project your spatial data
Real-time rotation
Connect points using the Great Circle model
Show accurate distances
Connect points using the Great Circle model Show accurate distances
Draw an image at a point
Use an online mapping service for your background
Google, Yahoo, or WMS (third party licensing may apply)
Use an online mapping service for your background Google, Yahoo, or WMS (third party licensing may apply)
Frequently Asked Questions (Coming Soon)
  • General Questions
Help & Support Guides
  • Support Options
  • Support Ticket Guide
  • Discussion Forum Guide
  • NuGet Guide
  • Release Cycle Guide
map_suite_web_for_webforms.1490246636.txt.gz · Last modified: 2017/03/23 05:23 by tgwikiupdate
