map_suite_web_for_webforms_features_bug_fixes_change_log
Map Suite Web For WebForms Features & Bug Fixes Change Log
Version 10.6.0
Release date: 11/28/2019
ThinkGeo.MapSuite.WebForms Namespace:
ThinkGeo.MapSuite Namespace:
  • Enhanced to support reprojection for Wmts.
  • Enhanced to support high resolution screen for ThinkGeoCloudRasterMapsLayer.
  • Enhanced to support high resolution screen for GoogleMapsLayer.
  • Fixed a bug that GoogleMapsLayer renders incorrect tiles when map extent is out of max extent of Google.
  • Fixed a bug that WmtsLayer can't serialize.
  • Fixed a bug that the projection don't works when FeatureSource is editing and IsTransactionLive of ShapeFileFeatureLayer is true.
  • Fixed a bug that Fdo doesn't work on the x64 target platform.
  • Fixed a bug that FikeGeoDatabase doesn't work on the x64 target platform.
  • Changed DrawingPointStyleEventArgs to DrawingDirectionPointEventArgs.
  • Added DirectionPointStyle property for LineStyline.
  • Enhanced to support ZoomLevel20 for ThinkGeoCloudMapsZoomLevelSet.
  • Improved render performance for OpenStreetMap.
  • Fixed a bug that the PDF and the Printer get different result with the Map if polygon contains inner rings.
  • Enhanced to support GeoLinearGradientBrush for Printer.
  • Enhanced to support GeoLinearGradientBrush in PDF.
  • Fixed a bug that the Direction convert to incorrect Angle in GeoLinearGradientBrush.
  • Fixed a bug. When parsing tile format tiff image, throws “Array index is out of range” exception.
  • Fixed a bug that cache expired don't works again because we need compare the UTC dateTime.
  • Enhanced to support rotation text for Cad.
  • Fixed a bug that raster layer is unmatched with vector layer when printing.
  • Fixed a bug that the projection '90091' srid can't be found from Esri projectin list.
  • Fixed a bug that GeoTiff will jump when reprojection.
  • Improved S57 index building performance.
  • Fixed a bug. When Setting the IsActive of specified zoomlevel to false, map still draw the shape follow the style of other zoomlevel.
  • Fixed a bug that QueryTool doesn't work.
  • Fixed a bug that the label is rendered at incorrect position under different DPI.
  • Improved render performance for NauticalChartsFeatureLayer.
  • Fixed a bug that RotationAngle of PointStyle doesn't work when printing map.
  • Fixed a bug resouce files of LegendAdornmentLayer can't be found.
  • Fixed a bug that zooming to deeper than level 20 OpenStreetMapsLayer throws a exception.
Version 10.5.0
Release date: 04/01/2019
  • Enhanced to rename ThinkGeoCloudMapsOverlay to ThinkGeoCloudRasterMapsOverlay and ThinkGeoCloudMapsMapType to ThinkGeoCloudRasterMapsMapType
  • Fixed a bug that default projection of XYZ layer is incorrect, now it's “EPSG:900913”
  • Added support of Skia as the drawing engine to improve the performance.
  • Added support of semantic cartography schema – StyleJSON to design the map.
  • Added support of vector tile based *.MbTiles format.
  • Added support of ThinkGeoCloudRasterMapsLayer
  • Added support of high resolution for PlatformGeoCanvas, it mainly works for iOS edition
  • Enhanced to support parse special node in capability XML contains two spaces for WMTSLayer, generally Oracle export this type XML
  • Enhanced to support “ScaleFactor” property, it shows the high resolution value, it mainly works for iOS edition
  • Enhanced to support drawing halo pen dasharray on SkiaGeoCanvas
  • Enhanced to support both meter and decimal degree for NauticalCharts
  • Enhanced to support use ThinkGeoCloudRasterMapsLayer in iOS and Android edition
  • Fixed a bug that print google map to pdf tile unmatch
  • Fixed a bug that BuildingAreaStyle don't works follow design
  • Fixed a bug that OSM Buildings Url need get updated
  • Fixed a bug that some geotiff files looks jump when pan on map after set projection
  • Fixed a bug that text style don't works for wrapping lines in certain scenario
  • Fixed a bug that wrong boundary limit for Proj4Projection in certain scenario
  • Fixed a bug that the width or height value maybe equal zero when calling ToScreenCoordinate for GeoTiff
  • Fixed a bug that projection cannot handle parameter correct in certain scenario
  • Fixed a bug that PlatformGeocanvas throw format exception in certain scenario
  • Fixed a bug that GetDrawingExtent function loss precision in certain scenario
  • Fixed a bug that MapType is invalid when initializing ThinkGeoCloudRasterMapsLayer
  • Fixed bugs that some geotiff files cannot load correct
Version 10.4.0
Release date: 12/10/2018
  • Added new class ThinkGeoCloudMapsOverlay to support new ThinkGeo Cloud Map
  • Enhanced to use more accurate exception information
  • Fixed a bug the ThinkGeoCloudMapsOverlay throw transition effect issue in certain scenario
  • Added new overloading method for DrawText in GeoCanvas class
  • Enhanced to get better performance for data drawing when shape file contains many inner rings in polygon
  • Enhanced to support Esri srid input for Proj4Projection
  • Enhanced to support Esri coordinate system when create table for FileGeoDatabase
  • Enhanced to use more accurate exception information and exception type
  • Fixed a bug map throw null reference exception in certain scenario
  • Fixed a bug the Sqlite R Tree calculate different result in Windows and Linux
  • Fixed a bug some special invalid saturation and luminance values for GeoColor can pass our validation
  • Fixed a bug vector data won't render all shapes if the width is too big
  • Fixed a bug XyzFileBitmapTileCache lose cache ID in certain scenario
  • Fixed a bug GettingTileCache event won't be fired in correct step
  • Fixed a bug the overlays don't match when print to PDF
  • Fixed a bug white line shows for WMTSlayer
  • Fixed a bug exception is thrown when met invalid tile in WMTSlayer
  • Fixed a bug failed to load dll in FileGeoDatabase for asp.net scenario
  • Fixed a bug ECW render distorted image in special zoomlevel
  • Fixed a bug GeoTiff image jump in certain scenario
Version 10.3.0
Release date: 7/26/2018
  • Fixed a bug that “GenerateCacheImages” doesn't work in certain scenario
Version 10.2.0
Release date: 10/27/2017
  • Fixed a bug where some tiles missed in some deep zoom level
Version 10.1.0
Release date: 06/21/2017
  • Fixed bug map will be cleared unexpectly when using MultiMap in one page
Version 10.0.0
Release date: 02/16/2017
Map Suite 10.0 New Features:
  • Create new product center that is available to run on multi-platforms including Windows, Linux and macOS.
  • Support ECW files on Linux.
  • Support MrSid and JPEG2000 files on Linux.
  • Fixed bug that LayerSwitcher doesn't work.
  • Fixed a bug that the popup close button is unable to click if AdornmentOverlay is added.
  • Added style sheets support.
Version 9.0.0.0
Release date: 06/24/2015
ThinkGeo.MapSuite.WebEdition Namespace:
  • Added Serializable and obfuscation attribute to support GeoSerializer in WebEdition.
  • Fixed a bug where the map doesn't show up after return back from another page.
  • Fixed a bug where the created application runs into exception in Visual Studio 2013.
  • Added new properties MaxExtent, TileFullExtent and TileOrigin to WmtsOverlay.
  • Fixed a bug where the map will zoom in one more level after restoring current extent.
  • Fixed a bug where Opacity property doesn't work for GoogleMapsOverlay.
  • Fixed a bug where the map doesn't show up if the map application is put in a sub directory.
  • Fixed a bug where some configurations of OpenStreetMapsOverlay doesn't applyoption(like isBaseLayer) setting doesn't apply to OSM layer.
  • Fixed a bug where it's unable to add a column by callingx InMemoryMarkerOverlay.Columns.Add().
  • Fixed a bug where the MagneticDeclinationAdornmentLayer runs into memory issue.
  • Added Leader Lines.
Version 8.0.0.160
Release date: 11/17/2014
  • Fixed a bug where the map doesn't show up when depolying website as a sub-application on IIS with case sensitive configuration.
  • Fixed a bug where the map will zoom out 1 more zoom level after restoring the current extent from a previous extent
  • Fixed a bug that the map is not correctly displayed when showing the full map of BingMap.
  • Fixed a bug where options, like isBaseLayer, is not applied to OSM layer correctly.
Version 8.0.0.0
Release date: 06/06/2014
  • Fixed a bug where the marker can not be clicked on a highlightoverlay.
  • Added support to allow users to change the MaxExtent of map control.
  • Fix a bug where the MaxExtent is not generated into JSON string when creating a customized map.
  • Fixed a bug where the custom cursor doesn't work.
  • Fixed a bug where it's unable to active the editing mode after doing a postback save or edit on Ipad.
  • Fixed a bug where the session id will make the map run into error with different parameters.
  • Fixed the bug where the IE10 issue happens under .NET 4.0 or 2.0 with ImageButton controls.
  • Fixed a bug where the new tiles will be generated cross dateline if applying wrapdataline.
  • Upgraded Openlayers used in WebEdition from 2.11 to 2.13.1.
Version 7.0.0.0
Release date: 06/03/2013
  • Added WMTS layer/overlay
  • Added a Regex validate on Map.ToJson
  • Added CustomOverlays Move methods
  • Added the RequiredColumnNames in MarkerStyle
  • Fixed a bug that the Google Street View doesn't show again if hide it using Client JavaScript
  • Fixed a bug that the Map control doesn't work with Telerik RedAjaxManager
  • Fixed a bug that Context Menu is not shown up at the right position when the div has the style “position:absolute”
  • Fixed a bug that it would cause the bad performance of MsSql2008FeatureLayer
  • Fixed a bug that the BingMapsOverlay doesn't display after switch between more than 2 bingMapOverlays via OverlaySwitcher in webKit browser
  • Fixed a bug that “Panning the map”&“Zoom to a scale” doesn't work with server API
  • Fixed a bug that the ArcGISRestOverlay does not utilize specified parameters
  • Fixed the issue that the map control doesn't work with Telerik RadAjaxManager control
  • Improved to use GUID as the Session Id instead of PageName and ClientId
  • Modified the Content-Type of ThinkGeo * .axd files to “application/x-javascript”
Version 6.0.0.0
Release date: 05/14/2012
  • Fixed an issue while a cached overlay does not line up properly after panning or zooming in/out.
  • Added the Culture Info support to ManagedProj4Projection.ConvertProj4ToPrj() method.
  • Fixed an issue where AdornmentOverlay doesn't work well if map is not placed at left-upper corner.
  • Fixed an issue where CloudPopup cannot be corrected closed when there are more than one map controls on the page.
  • Fixed an issue where an exception is thrown if ID Value is not passed through OpenStreetMapOverlay's constructor.
  • Fixed an issue where the map disappears when resizing the Safari browser.
  • Added the Opacity support to Popup.
  • Fixed an issue where PanZoom's GlobeButton cannot be disabled.
  • Fixed an issue where pointstyle is improperly displayed when exporting to pdf.
  • Fixed an issue where BingMapsOverlay cannot be set as ActiveBaseOverlay.
  • Fixed an issue where map is jumpy while Panning on the boundary of a Restricted Extent.
  • Added the support of Map Quest on Client Side.
  • Fixed an issue where the context menu disappears after a flash at high zoom levels.
  • Fixed an issue where Context Menu is not showed up at the position where mouse clicked.
  • Fixed an issue where an exception is thrown in OnClientDoubleClick event.
  • Added Google Map's StreetView to GoogleMapOverlay
  • Added Bing Maps Logo and data provider attribution to BingMapsOverlay
  • Fixed an issue where the tiles of LayerOverlay shift while using ServerCache.
  • Fixed an issue where a popup is prompted up while loading the GoogleMaps.
  • Fixed an issue where current extent get lost after postback.
  • Fixed an issue where the client layer.redraw(true) doesn't work for InMemoryMarkerOverlay and FeatureSourceMarkerOverlay.
  • Fixed an issue where changing the PanZoomBar visibility on mobile browsers take no effect.
  • Fixed an issue where cache tiles shift after loading.
  • Added Google Map's TrafficView to GoogleMapOverlay
  • Fixed an issue where BingMaps in Chrome or Safari, turns to white after switching between different overlays.
  • Added New Web Request Events and Methods
Version 5.5.0.49
Release date: 12/31/2011
  • Fixed an issue where the OpenStreetMapOverlay constructor doesn't hold the passed parameters.
  • Fixed an issue that the cache doesn't work properly.
  • Fixed an issue where a popup is added multiple times.
  • Fixed an issue where Server.Transfer redirects to the wrong page.
  • Fixed an issue where an overlay in meter based projection with cache enabled doesn't match other overlays.
Version 5.5.0.0
Release date: 11/14/2011
  • Fixed an issue where it throws the JS exception “html:invalid operation” if the map is in Updatepanel
  • Fixed an issue where the EditOverlay runs into error when deserializing its features.
  • Fixed an issue where hover popup doesn't work properly in IE9.
  • Fixed an issue where PopUpDelay doesn't work for ClusterMarkerStyle.
  • Enhanced BingMapsOverlay making it support Enterprise Key.
  • Fixed an issue where the layers on the Overlay switcher are disordered.
  • Fixed an issue where Properties Window and Map Control keep Flashing or Continuously updating in Design Time.
  • Enhanced the LayerOverlay so the TiledWmsLayer requests images simataneously.
  • Fixed an issue where drawing a Label on a Marker increases image size.
  • Fixed the way that the “Number of Points must be 0 or > 3” exception is handled.
  • Added the IsoLine Support.
Version 5.0.0.55
Release date: 7/7/2011
  • Fixed a bug where the fontstyle didn't support two different styles together
  • Fixed a bug where ServerCache created multiple folder for single zoomlevel
  • Fixed a bug Where Visual Studio 2010 became unresponsive after debugging several times
  • Fixed a bug where the GeometryCollection can't be displayed correctly with Projection
  • Fixed a bug where the image size setting had no effect
Version 5.0.0.0
Release date: 5/16/2011
  • Fixed a JScript runtime error on AutoRefresh.
  • Fixed a bug where the sequence in the overlay switcher doesn't match the sequence of the overlays.
  • Fixed a bug in the Marker Roatation sample.
  • Fixed a bug that a JavaScript error in Geo_Resource.axd when using Google Overlay.
  • Fixed a bug where the ContextMenu doesn't display within the Master Page or User Control.
  • Fixed a bug where overlays disappeared when panning, zooming under a different projection.
  • Fixed a bug when assigning rotation angles to markers.
  • Fixed a bug where an error is thrown from Map click/double-click and Highlight Overlay click event while the map is loading.
  • Fixed a bug where a JavaScript error was thrown when one of multiple maps were hidden.
  • Upgraded to OpenLayers2.10
  • Added support iOS touch events including pinch zooming, drag panning etc.
  • Obsoleted ClientZoomLevelScales property and SyncZoomLevelScales method, but added ZoomLevelSet property instead.
  • Added a way to turn off WMS Background Layer on the server side.
  • Upgraded the Google API to support versions V2 and V3.
  • Added a new item called DegreesMinutesSecondsLatitudeLongitude to the ThinkGeo.MapSuite.WebEdition.MouseCoordinateType enumeration.
  • Removed the Obsolete APIs.
Version 4.5.0.0
Release date: 11/01/2010
  • Fixed the bug that ViewState is so large because of Map.MapTools
  • Removed some Features of OpenLayers 2.8 Deprecated compared to 2.7
  • Fixed the Memory leak when refreshing the markers again and again
  • Fixed the bug it will be displacement when using VirtualEarthOverlay
  • Fixed the bug that the marker in InMemoryMarkerOverlay and FeatureSourceMarkerOverlay are cut off
  • Added the backGroundColor for Marker Text
  • Fixed the bug that the text for marker is cut off
  • Fixed the bug that assigning rotation angle to markers
  • Fixed the bug that VS2010 WebEdition project is unable to work normally.
  • Added ClusterMarkerStyle to cluster the markers and improve the MarkerOverlay performance.
  • Improved the bad performance when MarkerOverlay works with huge markers
  • Map crash after long idle time
  • Added ClusterPointStyle
Version 4.0.40.0
Release date: 6/15/2010
  • Updated assembly version to 4.0.0.0; included strong-named and weak-named assemblies. Please see the latest post in the Developer Blog for full details.
  • Fixed issue with the ScaleTo API in BaseShape when called by a Rectangle Shape.
  • Fixed issue where an exception would be thrown when calling BuildIndex in a Turkish enviroment.
  • Fixed issue when using the UpdateColumnName API in DBF module.
  • Fixed issue involving use of Chinese fonts
  • Fixed a rounding bug in the GetPointOnALine API of LineShape.
  • Some minor API changes. See the API change log for complete details.
Version 4.0.0.17
Release date: 5/21/2010
  • Fixed issue where DrawingArea property was no longer present in PdfGeoCanvas.
Version 4.0.0
Release date: 5/1/2010
ThinkGeo.MapSuite.Web Namespace:
  • Many core enhancements and additions as itemized here.
  • Added Visual Studio 2010 “How Do I?” sample application solution.
  • Added animated panning.
  • Added measurement tools.
  • Added Clustering Marker Strategy.
  • Added method where markers are rendered on GetBitmap.
  • Added the ability to change the title of the OverlaySwitcher panel.
  • Added new events for draggable markers, such as BeforeDrag, Dragging, and EndDrag
  • Added new key modifier options for TrackZoom, such as Shift, Ctrl, etc.
  • Added ContextMenu that can be wrapped at the edges of the map.
  • Added Pan behavior on the HighlightOverlay.
  • Added auto refresh for WMSOverlay.
  • Added Serializable attribution to SimpleMarkerOverlay.
  • Added WrapdateLine for LayerOverlay and WmsOverlay.
  • Added CallBackResult to support asynchronous refresh.
  • Added support for ContextMenus with sub-levels.
  • Added OSMOverlay to support an Open Street Map server.
  • Added ArcGISRestServerOverlay to support ArcGIS Rest Server.
  • Added a property that specifies if the embedded resources can be copied to the website in runtime.
  • Added controller about how to specify if the web.config can be integrated in runtime.
  • Exposed more client functionality accessible via JavaScript.
  • Removed the exception when using the DefaultOverlay and CustomOverlay together.
  • Fixed issue with deploying the map to IIS 7.5 when using DefaultPool.
  • Fixed issue with rendering BaseOverlayTitle and OverlaySwitcher Tile in runtime.
  • Fixed issue where Virtual Earth maps go blank when you resize the map.
  • Fixed block of OnClientEditEnd event when the shape is not changed.
  • Fixed the IE7 “Operation Aborted” error with Virtual Full PostBack
  • Fixed the memory leak when refreshing markers repeatedly.
  • Fixed issue where Virtual Earth Bird's Eye imagery does not show.
  • Several API additions, plus one breaking change. See the API change log for complete details.
  • Updated the API documentation.
  • Added additional helper methods to the GeoCollection class.
  • Added better support for labeling with Asian characters.
  • Added support for Google Static Maps API v2.
  • Added simple support for Yahoo Maps.
  • Added support for heat map layers.
  • Added support for 100% managed proj Projection Library.
  • Added direct support for Map Shapes.
  • Added API to modify the column name in ShapeFileFeatureSource and ShapeFileFeatureLayer.
  • Added new API BuildIndex for MultipleShapeFileFeatureLayer
  • Included GraticuleLineLayer support and a sample application for it.
  • Enhanced the MultiShapeFileFeaturesLayer class to allow you to use files in multiple folders.
  • Enhanced the distance measuring method to use the Haversine formula.
  • Improved GeoCache performance.
  • Updated the PostgreSQL Assembly versions.
  • Exposed the DBaseFile class library.
  • Exposed the disk-based RTree Spatial Index.
  • Split up the Map Suite MergeModule into smaller and more manageable pieces.
  • Fixed issue where GetCenterPoint using NTS would return an invalid value when the polygon's width and height is 0.
  • Fixed issue regarding GetBoundingBox of GroupLayer.
  • Fixed issue where GetAllColumns also returns the Geometries column.
  • Many API additions. See the API change log for complete details.
Version 3.1.299
Release date: 11/16/2009
  • Fixed issue where Web Edition did not work under IIS 7.0's Integrated Mode.
  • Fixed issue with a client exception in Firefox involving session_georesource.axd.
  • Fixed issue with JavaScript that would occur when changing the drawing mode in Firefox.
  • Some minor API additions. See the API change log for complete details.
  • Fixed issue where SaveToProjection is incorrect for some data.
  • Fixed issue with the DecimalDegreesHelper API GetDecimalDegreeFromDegreesMinutesSeconds.
  • Fixed caculation issue in DecimalDegreeHelper.GetDistanceFromDecimalDegrees when passing particular data.
  • Fixed issue where an exception is thrown for TAB files when the column name starts with an underscore(_).
Version 3.1.273
Release date: 10/22/2009
  • Upgraded to OpenLayers 2.8.
  • Fixed event conflict when using DraggableMarker and MapClick event.
  • Fixed issue regarding event that needed to be reaised in MasterPage.
  • Fixed issues where the map would turn blank after a postback in Firefox.
  • Fixed issue with Tracking/Editing shapes in Internet Explorer 8.
  • Added Haversine formula to calculate distance.
  • Added DrawException method to draw exceptions rather than throwing them in the Overlay and Layer.
  • Added IndexedInMemoryFeatureLayer Class.
  • Added ReadOnly logic to ClearCache and DeleteTile methods.
  • Added the schema supported in PostgreFeatureSource.
  • Added API overloads for GetFeaturesByColumnValue method.
  • Added API to detect the feature type in FeatureSource.
  • Added API BuildIndex in InMemoryFeatureLayer.
  • Enhanced the Sql2008FeatureSource, PostgreFeatureSource and OracleFeatureSource by adding one event ExecutingSqlStatement.
  • Extended the KeyColor from one color to an array of colors or a range of colors.
  • Fixed a memory leak when calling OpenAllLayers multiple times.
  • Fixed issue where ApplyUntilZoomLevel doesn't work right when using CustomZoomLevel.
  • Fixed OutofMemory exception issue in WFSFeatureSource.
  • Fixed issue where SaveToProjection in ShapeFileFeatureSource would throw an out of memory exception.
  • Fixed issue with the Stream_Loading event in ShapeFileFeatureSource.
  • Fixed issue with obfuscation in autobuild.
  • Fixed issue where the WMS cannot work properly when the network is unavailable.
  • Fixed issue where GetRandomColor always get the same color.
  • Fixed issue where CloneDeep of InMemoryFeatureSource does not work.
  • Fixed issue where InmemoryFeatureSource cannot be serialized correctly.
  • Fixed issue where you could not parse the parent layer in a WMS server.
  • Fixed issue where an OutOfMemory error occurs while drawing.
  • Fixed issue with support for Geography type data in MsSqlFeatureSource.
  • Fixed issue with the GetFeaturesInsideBoundingBox method of MultipleShapeFileFeatureSource.
  • Fixed issue where GetCenterPoint using NTS will return an invalid value when the polygon's width and height is 0.
  • Fixed issue regarding thrown exception ORA-00936: Missing Expression.
  • Fixed issue where GetPointOnALine returns the wrong value.
  • Fixed issue where GdiPlusRasterLayer has a black line in tile mode.
  • Fixed issue with the GetFeatureById API in WfsFeatureLayer.
  • Fixed very low performance issue with GetColumnsCore.
  • Fixed issue with missing tag information in InMemoryFeatureLayer.
  • Fixed non-serializable issue for WFSFeatureLayer.
  • Fixed issue where an exception was thrown when building an index for an empty shape file.
  • A number of API changes. See the API change log for complete details.
Version 3.1.182
Release date: 7/23/2009
  • Added client cache on the client side for improved loading performance.
  • Added a property to disable multithreading in LayerOverlay to make debugging easier.
  • Fixed issue with the FeatureSourceMarkerOverlay.
  • Fixed issue where a sub-class of Map would not work correctly.
  • Fixed issue where the FDO Extension would throw an exception when multi-threading.
  • Added some APIs for ScaleBar in order to implement the same functionality as in ScaleLine.
  • Fixed issue with setting a different DPI for canvas.
  • Fixed issue where the Matrix system did not consider the MapUnit.
  • Fixed issue where the OverrideMode did not work correctly for the ShapeFileFeatureLayer.SaveToProjection API.
  • Fixed issue where an exception would be thrown when using a MaskBrush for the ScaleBar.
  • Fixed issue where bool field cannot be updated in the DBF.
  • Fixed the Out of Memory Exception thrown when calling the ShapeFileFeatureLayer.SaveToProjection API on very large shape file data.
Version 3.1.124
Release date: 5/26/2009
  • Added MarkerDragged event on the server side.
  • Added support for ASP.NET MVC.
  • Added a search engine to the “How Do I?” sample apps browser.
  • Added JavaScript library cache support.
  • Added simple styles for EditionOverlay support.
  • Added WFS support.
  • Enhanced track shape functionality.
  • Enhanced cache pre-generation extension.
  • Optimized client printing.
  • Optimized multi-language support.
  • Bugs fixed:
  • * Fixed match issue when using a Virtual Earth overlay.
  • * Fixed issue involving draggable markers.
  • * Fixed issue with session saving support in SQLServer.
  • * Fixed issue when working with Callback.
  • Added an API to CheckForUnSupportedShapeTypes(string shapeFilePath).
  • Added support for a Polygon record that contains 0 parts.
  • Added an overload for BuildIndexFile.
  • Added ExecuteQuery support for Postgre.
  • Added property to show whether the assembly is the Full Version or Evaluation Version.
  • Added an overload to CreateShapeFile so that user can choose whether they want to override.
  • Added polygon simplification to AreaShapes.
  • Added line simplification to LineShapes.
  • Added obsolete to the AllowSpline property in text style.
  • Added GetFirstGeometryType in Postgre, Oracle and SQL layers.
  • Added “Simplify” sample application.
  • Added an overload to GetFeaturesNeareastTo with a distance limitation.
  • Added documentation for DashPattern.
  • Added ToGdiPlusColor method in GeoColor.
  • Added a way to build a spatial index based on another projection, not using a feature list.
  • Added DPI support for the GeoCanvas.
  • Improved the TIFF quality for GeoTiffRasterLayer.
  • Changed the logic of GetZoomLevelForDrawing by considering the IsActive.
  • Changed the proj4.GetEpsgParameters(srid) method from instant to static.
  • Changed the Layer.IsVisible to virtual.
  • Checked the IdFieldColumn for all spatial databases like Postgre, Sql2008 and Oracle.
  • Fixed issue when modifying the inner logical of DbfColumn constructor.
  • Fixed issue where GeoTiff was not supported.
  • Fixed issue where the parameter name is wrong for the postgreFeatureLayer's constructor.
  • Fixed issue where TextStyle.Format did not work.
  • Fixed issue involving uppercase conversion when executing SQL in shape file feature source.
  • Fixed issue with GetFeaturesForDrawing logic.
  • Fixed issue with TextStyle.DrawCore DPI.
  • Fixed issue where RasterLayer does not work when the DPI is not 96.
  • Fixed issue where a Postgre Layer will throw “Object reference not set to an instance of an object” exception.
  • Fixed issue involving the first Rotation when setting Rotation projection.
  • Fixed issue where PointStyle.DrawSample() did not work.
  • Fixed issue where the drawing order is not correct when adding multiple types of features to one feature layer.
  • Fixed issue in GetFeaturesByColumnValue.
  • Fixed issue where custom column did not work for the spatial query methods.
  • Fixed issue where the gdiPlusGeoCanvas.DrawCircle() result is not correct.
  • Fixed issue where ExecuteQuery did not work properly.
  • Improved some exception descriptions.
  • Fixed issue where featureLayer.Columns exists, but the featureSource.Columns property does not.
  • Fixed issue with GroupLayer display order.
  • Fixed issue where GetRandomGeoColor was missing.
  • Fixed issue involving sorting classBreaks internally.
  • Fixed issue involving support for all other types like (PolyM) for ShapeFile Layer.
  • Fixed issue involving exposure of static API from ShapeFileFeatureSource to ShapeFileFeatureLayer.
  • Fixed issue where the Transparency property does not work in RasterLayer.
  • Fixed issue where DotDensityStyle was not drawing after CloneDeep.
  • Fixed issue in Map Suite Explorer.
  • Fixed issue where creating a shapeFileLayer by streamloading event would throw an exception in layer.close().
  • Fixed issue involving consideration of the DoNotDraw property or FeaturesToExclude.
  • Fixed issue where TestLayerStyle.DrawSample did not work properly with the haloPen.
  • Fixed issue where GetBoundingBoxOfItems did not work properly.
  • Fixed issue involving label drawing even if the line was visible on the screen.
  • Fixed issue where the CustomFieldFetch event did not work in a ShapeFileFeatureLayer.
  • Fixed issue where GeoPen does not act on symbol Diamond, Diamond2, Star or Star1.
  • Fixed issue where some shape files cannot build an index.
  • Fixed issue where GeoPen and GeoBrush constructors did not work.
Version 3.1.16
Release date: 2/6/2009
  • Added new feature: Draggable markers.
  • Resolved issue with zooming out after doing a postback.
  • * Draggable markers: * *
The code to implement a draggable marker is quite simple. An example:
  SimpleMarkerOverlay markerOverlay = new SimpleMarkerOverlay("MarkerOverlay");
  markerOverlay.DragMode = MarkerDragMode.Drag;
  markerOverlay.Markers.Add(new Marker(0, 0, new WebImage(21, 25, -10.5f, -25f)));
  Map1.CustomOverlays.Add(markerOverlay);
  • Added an API(ZoomToOffsetPoint) in ExtentHelper.
  • Added Overloads GetFeaturesInsideBoundingBoxCore and GetFeaturesOutsideBoundingBoxCore.
  • Added a more descriptive message for a ShapeFile validation.
  • Added SaveToProjection in ShapeFileFeatureSource and ShapeFileFeatureLayer.
  • Added a protected virtual property for the cached featureSourceColumns.
  • Added an API in the FeatureSource to refresh the cached columns.
  • Added the API CheckForUnSupportedShapeTypes(string shapeFilePath).
  • Changed the logic to use the InMemoryFeatureSource and InMemoryFeatureLayer.
  • Resolved an issue with style.DrawSample.
  • Resolved System.AccessViolationException when the map is redrawn.
  • A number of API additions. See the API change log for complete details.
Version 3.1.0
Release date: 1/22/2008
ThinkGeo.MapSuite.WebEdition Namespace:
  • Add X64 OS support.
  • Added support for session serialization.
  • Added support for a client zoomlevels setting mechanism.
  • Added support for changing a shape's style when editing.
  • Improved shape edit settings.
  • Improved APIs. See the API change log for complete details.
  • Bugs fixed:
  • Display error when using different regions.
  • Can't use the pageLoad default client function on an .aspx page.
  • Exception description resource error.
  • Fixed a memory leak when navigating a map at the client side.
  • Synchronized non-baseOverlay visibility between client and server side.
  • Double-click event won't trigger when the MouseMapTool is enabled.
  • Added a parameter check to the Projection class.
  • Added a CustomZoomLevels collection to the ZoomLevelSet to allow for custom zoom levels.
  • Added a more descriptive exception message if a PolygonShape or MultiPolygonShape does not pass the validation test.
  • Added HasProjectionText and ProjectionText properties to RasterSource and RasterLayer.
  • Added validation checks on each member of the QueryTools to ensure that the Layer has been opened.
  • Added a new API for getting features based on the value in a column.
  • Added another parameter to BeginDrawing in GeoCanvas.
  • Added ExecuteSqlQuery and CanExecuteSqlQuery methods to QueryTools and FeatureSource.
  • Added two overloads for the method LineShape.GetLineOnLine.
  • Added encoding tests.
  • Added MrSid support in 64-bit environments.
  • Created JPEG2000RasterLayer/JPEG2000RasterSource to make it easier to load JPEG2000 images.
  • Provided an API in ShapeFileFeatureSource and ShapeFileLayer.
  • Updated the documentation for class name changes and for classes that did not previously have documentation.
  • Changed PathFileName to PathFilename.
  • Changed the ReadMe to Readme.
  • Changed the MapSuiteCore class to take advantage of re-projecting an array of points.
  • Changed the internalFeatures from a Dictionary to a GeoCollection.
  • Modified ShapeFileFeatureSource.ExecuteSqlQuery() to throw exception if filename is longer than 8 characters.
  • Enhanced the Projection classes and members.
  • Improved performance in GdiPlusRasterLayer.
  • Improved the Union Sample logic.
  • Improved the exception description for Layer.QueryTools/Layer.EditTools.
  • Improved the documentation for EditTools.Union.
  • Improved speed of spatial queries with a polygon-based layer when using a MultiPolygonShape as the target shape.
  • Improved speed of the Proj4Projection class by removing the locking code.
  • When building an index, all features are now loaded into memory.
  • Fixed missing overload for static method CreateSimpleAreaStyle.
  • Fixed ZoomIn bug.
  • Fixed the PointStyle, AreaStyle and LineStyle DrawSample methods so that they return the sample in the middle of the image.
  • Fixed an outstanding issue with style.DrawSample.
  • Reviewed all of the the Try…Catch code.
  • Resolved issue where the static function BuildRecordIdColumn required a spatial index on the Layer first.
  • Resolved issue where a System.AccessViolationException would be thrown when redrawing the map.
  • Resolved issue with WMS when using a Web Proxy.
  • Resolved issue where dragging two raster layers to Explorer throws an exception.
  • Resolved issue when a Layer's zoom level did not work under a projection other than WGS 84.
  • Resolved issue with ScalebarAdornmentLayer.
  • Resolved issue with RectangleShape.ExpandToInclude.
  • Resolved issue where WmsService would not work with HTTPS/SSL.
  • Resolved issue where mapEngine.OpenAllLayers() would not open an AdornmentLayer.
  • Resolved issue where the Geographic.Unit and DistanceUnit in BaseShape.Buffer() were reversed.
  • Resolved issue with BuildIndex where getting all features would not work.
  • Resolved issue where QueryTools.GetFeaturesContaining would not work when features are in the transaction buffer.
  • Reintroduced the AreaShape.GetCrossings method (which was previously present in Map Suite 2.0).
  • Reintroduced support for raster files (ECW, MrSid, BMP, etc.) in Map Suite Explorer.
  • Removed the obsolete target framework for .NET 2.0.
  • A number of API additions and changes. See the API change log for complete details.
map_suite_web_for_webforms_features_bug_fixes_change_log.txt · Last modified: 2019/12/06 01:55 by tgwikiupdate
