map_suite_services_edition
Map Suite Services Edition
The page was created before Map Suite 10. Map Suite 10.0 organized many classes into new namespaces and assemblies as well as had a few minor breaks in compatibility. The majority of previously built code should work without modification assuming the new namespaces are added. For guidance on upgrading your existing code check out this(http://wiki.thinkgeo.com/wiki/map_suite_10_upgrade_guide).
Map Suite Services Edition (formerly known as Map Suite Engine) is a complete GIS development framework for creating Web services, Windows services and console applications. Native to the Microsoft .NET Framework, Map Suite Services Edition offers a next-generation GIS software development experience.
Product Guides
Helps you get you up to speed with integrating the Map Suite Services Edition map control into your GIS software.
Introduces the dependencies Map Suite Services Edition needs with their features, versions and source websites.
API Documentation
  • ThinkGeo.MapSuite.Core
    The Core API documentation covers the ThinkGeo.MapSuite.Core namespace which resides in the MapSuiteCore.dll assembly. It contains all of the core GIS classes that are shared between the different Map Suite edition map controls and servers. It includes such classes as Style, FeatureSource, Layer, Projection etc. This is where the bulk of the classes are for most of the Map Suite products.
Code Samples
All Samples
All samples about Map Suite Services Edition.
Project Templates
These projects show various study cases based on Service Edition.
Background Maps
Labeling
Layers & FeatureSources
Miscellaneous
Printing
Projection
These samples feature various usages of projection.
Spatial Functions
Styles
Vehicle Tracking
These samples show various features related to vehicle and asset tracking.
Zooming Panning Moving
Videos
Step through the Services Edition sample applications and see how they're put together. We'll demonstrate how to use each app, then take you through every part of the source code and show you how it works.
Creating Custom Styles
Exploring Layers
Exploring Layers
FDO, OGR and GDAL Extension
Printing System Introduction
Tile Cache Generator
Topology Validation
Topology Validation
Screenshots
The Services Edition screenshots gallery section showcases a wide range of screenshots covering various GIS features of the Services Edition map control.
Uses ZedGraph classes
Plots points on your map
Point density represents numeric data
Connect points using the Great Circle model
Show accurate distances
Connect points using the Great Circle model Show accurate distances
Puts you in control
Render features specifically based on a theme
Colorize map features
Useful for points & labels
Real-time rotation
Draw an image at a point
Project your spatial data
Change Logs
  • API Change Log
    This change log details the API changes made to the product for each major release cycle.
Frequently Asked Questions
  • All Questions
    All the frequently asked questions about Map Suite Services Edition.
  • General Questions
  • Background Maps
    These frequently asked questions cover showing how to incorporate 3rd part background map with your application.
  • Labeling
    These frequently asked questions cover various aspects of labeling features.
  • Layers & FeatureSources
    These frequently asked questions cover custom layers and feature sources from which you can get inspired to integrate your own data.
  • Miscellaneous
    These frequently asked questions cover various of other technical features of the products that are not included in other categories.
  • Projection
    These frequently asked questions cover various aspects of projection such as how to re-project your data.
  • Spatial Functions
    These frequently asked questions cover various spatial functions such as union, buffer, merging data etc.
  • Styles
    These frequently asked questions cover displaying your GIS data using various styles. Some examples of styles would include using class breaks, clustering points, heat maps, etc.
  • Vehicle Tracking
    These frequently asked questions cover various features related to vehicle and asset tracking.
  • Zooming Panning Moving
    These frequently asked questions cover various ways to move the map.
Help & Support Guides
  • Support Options
  • Support Ticket Guide
  • Discussion Forum Guide
  • NuGet Guide
  • Release Cycle Guide
map_suite_services_edition.1489549263.txt.gz · Last modified: 2017/03/15 03:41 by tgwikiupdate
