map_suite_services_edition_faq_zooming_panning_moving
Map Suite Services Edition FAQ Zooming Panning Moving
How do I center my map using Decimal Degrees when I map is projected?
Sample:Center Map Based On Lat/Long
Sample:Centering and Rotating
How do I zoom to the full extent based on a collection of layers?
Sample:Zoom to Full extent
Today we have the first project in the Map Suite WPF Desktop version. This is a simple project that shows how to set the current extent based on a collection of layers. You can use this technique for the common task of having the map set to the full extent. Instead of having to manually set the full extent, you can pass all the layers you want the full extent to be based on. This project will be followed by many other WPF projects due to the increasing popularity of that Map Suite version.
How do I add additional, more granular, ZoomLevels to the twenty predefined ZoomLevels?
Sample:Zoom Levels Partitioning
Map Suite API conveniently offers 20 predefined zoom levels to set the different styles. With those 20 predefined zoom levels, at any change of extent, the map will snap to the nearest zoom level. While this is appropriate in most cases, you may want a more granular control on the zoom levels. This project shows how to set intermediate zoom levels between the existing predefined ones for more granularity. Since the zoom levels are based on scales, you can still use the predefined zoom levels to set the styles and have the additional custom zoom levels for more refined control on zoom level snapping. In this project, we have the WorldMapKit WMS as a layer and a regular point based shapefile. You can see how the intermediate custom zoom levels have the effect of stretching the WMS image to better fit. This is a Desktop project and you will need the full or evaluation references to MapSuiteCore.dll, DesktopEdition.dll and WorldMapKitWms.dll.
How do I zoom in and center the map based on where the user clicked?
Sample:Zoom In To Point
This project is for DesktopEdition users. As for the project TrackZoomInWithoutShiftKey, we show how to create a new class from InteractiveOverlay. InteractiveOverlay is a powerful way to interact with the map but it currently lacks documentation. While this project does not substitute a good documentation, it shows some techniques for using that class. You can take a look at the overriding method MouseDownCore to see how in a few lines of code, you can allow the users to have the map zoomed in and centered to the location the map was clicked on. In the next major public release of Desktop Map Suite, we will present a more complete documentation on InteractiveOverlay.
How do I highlight and zoom in to a specific feature?
Sample:Zoom In To Feature
How can I create custom zoom levels?
Sample:Custom Zoom Levels
How do I get the current ZoomLevel when the scale changes?
Sample:GetZoomLevel
How do I load an image layer when I don't have a world file but know the extent?
Sample:Raster Layer with extent
How do I get and set the map scale?
Sample:Map Scales
How do I restrict extent for panning and restrict extent for zooming out?
Sample:Restricting Extent
map_suite_services_edition_faq_zooming_panning_moving.txt · Last modified: 2015/09/16 06:27 by admin
