map_suite_services_edition_faq_projection
Map Suite Services Edition FAQ Projection
How do I display world coordinate on a map?
Sample:World Coordinates
The purpose of this project is to complete the section “Screen & World Coordinates” of the “How Do I?” sample apps. You will learn how to display world coordinates at the mouse event. Notice that the Layer is in Mercator projection and we use a projection conversion to display Longitude and Latitude in addition to the world coordinates values in meters from the Mercator projection. Also, we are reusing the DecimalDegrees static class we used in a previous project for formatting decimal degrees.
How do I display proper world coordinates when a map is being rotated?
Sample:World Coordinate with Rotation
How can I change the datum while keeping the projection the same?
Sample:Datum Transformation
How do I get the intersecting point of two streets?
Sample:Street Intersection
How do I know which state plane projection to use based on a decimal degree point?
Sample:Geodetic to State Plane
How do I automatically project my decimal degree data to UTM?
Sample:Geodetic to UTM on the fly
The appropriate EPSG number for our example can be found at: http://spatialreference.org/
How do I convert shape file data from one projection to another?
Sample:Save To Projection
How do I route in one projection and display the route information in another projection?
Sample:Routing with Projections
How do I show a great circle line across the pacific rim?
Sample:Great Circle on Pacific Rim
How can I visualize the distortion of a projection will cause on my data?
Sample:Projection Distortion
How do I display a polygon across the Meridian?
Sample:Polygon across Meridian
Following a request from the Discussion Forum on how to handle cases where the shape straddles the 180 degree meridian on a Decimal Degree map, we created this project. The solution is to split the shape into two main parts to be displayed on the two ends of the map. In this case, we use the case of a Polygon but this could easily be adapted for any other shapes such as lines.
How can I get an accurate measurement between two points in decimal degrees?
Sample:Measurements Decimal Degrees
This project is in response to a Discussion Forum post that has generated plenty of debate on the meaning of measuring area for shapes in decimal degrees. In this project, you will see how to get area and length measurements according to the projection used from a shape in decimal degrees. For more information on why different measurements can be obtained from the same shapes, please read the Discussion Forum “GetArea on Buffered shape not working as expected” http://gis.thinkgeo.com/Support/DiscussionForums/tabid/143/aff/21/aft/6565/afv/topic/Default.aspx
How do you display the Pacific Rim area?
Sample:Pacific Rim
This project shows how to display the Pacific Rim and Asia if you pan to the west, so that the world “wraps around,” as it does with Google Maps. Many of our Map Suite sample applications include an example of the world being displayed using a world ShapeFile. The ShapeFile is in Decimal Degrees and it displays the world according to longitude and latitude value ranges. These ranges are from -180 to 180 for longitude and 90 to -90 for latitude. In our various examples that use this ShapeFile, you see the Western Hemisphere on the left and the Eastern Hemisphere on the right. Now, a common request that we receive is to display the Pacific Rim and Asia if you pan to the west, so that the world “wraps around,” as it does with Google Maps. This can be accomplished in Map Suite 3.x by using a custom projection that offsets all of the points by 360 for the x (longitude) values. (180 + 180 = 360). You will see how to create OffsetProjection class inheriting from Projection. Notice the code in the overrided method GetexternalProjection. It simply loops thru all the points making each feature and offset the X value by 360.
How to use custom parameters projection?
Sample:Custom Parameters Projection
How to use custom rotation projection?
Sample:Custom Rotation Projection
How to use local datum UTM?
Sample:Local Datum UTM
The purpose of this Wpf sample is to get familiar with the concept of datum and datum shift in UTM and Geographic coordinates. Using local data, you might be required to apply datum transformation to your data to go from an old datum to a more recent datum. Here we are taking the example of Australia which went to change its datum (from AGD84 to GDA94) for its mapping purposes. We show how to apply the datum transformation in both the longitude/latitude coordinate system and in the local UTM systems (AMG based on AGD84 and MGA based on GD94). See the code and read with attention the comments in the MouseMove event where all the projection logic is taken place. Notice that the correction is about 200 meters. Once you understand for the case of Australia, you will be able to apply the same principles for your own datums in UTM. For further reading: http://www.cage.curtin.edu.au/~will/datum.html http://www.usq.edu.au/course/material/SVY3107/lectures/Breeze/SVY2106amgmgafund/index.html
How to google Map to Geodetic?
Sample:Google Map to Geodetic
In today’s Wpf project, we are showing a trick for getting the current extent of the map with Google Map as an image and displaying it on a map in decimal degrees unit. You may be in a situation where you want the details and accuracy of Google Map, especially the satellite view but want to have it displayed on your map in decimal degrees. In this sample, you will see how to get the Google Map image and create the accompanying world file for decimal degrees. Notice that we are realizing an affine transformation on the image to go to Geodetic as illustrated in the case 3 http://en.wikipedia.org/wiki/World_file#Definition. You can also use this technique for any other background maps such as Bing Map, Open Street Map using Spherical Mercator. Warning: It is possible to use a world file with parameters for a Geodetic system from an image originally in Spherical Mercator due to some similar projection characteristics. Applying the same operation for other projections such as Lambert or UTM will not work.
How to wrap dateline with projection?
Sample:Wrap Dateline Mode With Projection
How to use Spherical Mercator Projection Adjustment?
Sample:Spherical Mercator Projection Adjustment
The purpose of this sample is to address a projection issue that you may encounter when converting your data from your local projection to Google Map. It has been reported by Map Suite users that in some cases reprojecting their data to Google Map or other base maps using Spherical Mercator (Bing Map, Open Street Map etc) is inaccurate with the data being shifted a few hundreds of meters. This problem has been identified as being caused by an unnecessary grid shift when going from ellipsoid datum to spherical datum. Among other projections, the British National Grid (BNG) and the German Gauss-Kruger system have that problem when going to Spherical Mercator. This sample uses the example of BNG to demonstrate the problem and how to fix it. The Map Suite development team will offer a permanent solution to this projection issue but in the meantime, as a rule of thumb, if your data shows some inaccuracies when going to Spherical Mercator, use the method you find this sample. This is a Desktop app but the concept shown applies to all editions of Map Suite.
map_suite_services_edition_faq_projection.txt · Last modified: 2015/09/16 06:25 by admin
