map_suite_server_geocoder
Map Suite Geocoding
Map Suite Geocoding is a native geocoding and reverse geocoding component for .NET that lets you convert a street address into a geographic location and vice-versa. It can also deliver additional details like county, FIPS codes, census tract and more. Plus, it ships with an optimized set of United States street data based on the latest TIGER® data from the U.S. Census Bureau.
Product Guides
This guide helps you get you up to speed with integrating the Map Suite Geocoding into your GIS software.
This guide walks you through installing the Map Suite Geocoding on your system and creating a simple GIS application.
This guide walks you through deploying your GIS software using the Map Suite Geocoding into a production environment.
This guide introduces the dependencies Map Suite Geocoding needs with their features, versions and source websites.
API Documentation
  • ThinkGeo.MapSuite.MapSuiteGeocoding
    The Map Suite Geocoding API documentation covers the ThinkGeo.MapSuite.MapSuiteGeocoding namespace which resides in the ThinkGeo.MapSuite.Geocoding.dll assembly. It contains all of the Map Suite Geocoding specific classes such as the map control itself, Overlays, and supported map classes.
Package
Description This is an extension for use in ThinkGeo's Map Suite product line, see below, as it cannot be used stand alone.
Supported Platforms: Windows, Linux, MacOS
Compatible Products
  • Map Suite Desktop for WPF
  • Map Suite Desktop for WinForms
  • Map Suite Web for WebForms
  • Map Suite Web for Mvc
  • Map Suite World Streets
Code Samples
All Samples
All samples about Map Suite Geocoding.
Project Templates
These projects show various study cases based on Map Suite Geocoding
Screenshots
Pinpoint an address on your map almost instantly
Bundled with U.S. street data
Pinpoint an address on your map almost instantly Bundled with U.S. street data
Convert lat/long coordinates to a street address
Get county, elevation & more
Convert lat/long coordinates to a street address Get county, elevation & more
Geocode an entire batch of addresses in one operation
High performance processing
Geocode an entire batch of addresses in one operation High performance processing
Improve geocoding performance by building indexes
1 click gives you greater speed
Improve geocoding performance by building indexes 1 click gives you greater speed
Match input to a specific county, street name, etc.
Customize by writing your own MatchingPlugins
Match input to a specific county, street name, etc. Customize by writing your own MatchingPlugins
Use inexact searches to suggest results
Overcome typos & input errors
Use inexact searches to suggest results Overcome typos & input errors
Includes sample applications with full source code
Copy & paste into your apps
Includes sample applications with full source code Copy & paste into your apps
Change Logs
  • API Change Log
Frequently Asked Questions
  • General Questions
    These frequently asked questions cover GIS and Map Suite Geocoding topics that are not categorized in other areas.
Help & Support Guides
  • Support Options
  • Support Ticket Guide
  • Discussion Forum Guide
  • NuGet Guide
  • Release Cycle Guide
map_suite_server_geocoder.1489644091.txt.gz · Last modified: 2017/03/16 06:01 by kevinlaw
