map_suite_geocoder_features_bug_fixes_change_log
Map Suite Geocoder Features & Bug Fixes Change Log
Version 9.0.0.0
Release date: 06/24/2015
ThinkGeo.MapSuite.MapSuiteGeocoder Namespace:
  • Remove the duplicate matched results.
  • Fixed a bug where some incorrect records are included in the query result under fuzzy mode.
Version 8.0.0.160
Release date: 11/17/2014
  • Improved the GeoCoder matched results that removing the duplicated records.
  • Fixed a bug where some of the matched results are not correct with fuzzy mode.
  • Upgraded the Proj4 library to version 4.8.
Version 8.0.0.0
Release date: 06/06/2014
  • Fix the bug where plenty of addresses can't be located under fuzzy mode with geocoder 2012 data.
  • Fix the bug where it runs into the exception “Unable to read beyond the end of the stream”.
Version 7.0.0.0
Release date: 06/03/2013
  • Fixed the bug where some ZipCode are missed from the Index data
  • Improved the performance a lot of Geocoder and Reverse GeoCoder by supporting MultiThread
  • Improved upgrade the Geocoder Index Data to Tiger 2012
Version 6.0.0.0
Release date: 05/14/2012
  • Fixed an issue where an exception is thrown when geocoding addresses containing specific characters such as '–' or '.'.
  • Fixed an issue where addresses are not correct matched if using Abbreviations for Spanish-Language.
  • Fixed an issue where no matching address returned when Passing in Address, City & State separately.
  • Fixed an issue where the result of Formalize is incorrect when input text contains “.”
Version 5.5.0.49
Release date: 12/31/2011
No new Features / Bug Fixes in this version.
Version 5.5.0.0
Release date: 11/14/2011
  • Added State FIPS into match result for ZipDbfMatchingPlugin.
  • Fixed an issue where an exception is thrown when geocoding underClosestStreetNumber match mode.
Version 5.0.0.0
Release date: 5/16/2011
  • Fixed the issue that only Right Zip Code geocoding is supported, now it supports both sides.
  • Added the support for street aliases geocoding.
  • Added ability to filter the result list according to input state name.
  • Removed the LINQ related classes to make it easier to use under other platforms.
  • Added a cache to the binary search to increase lookup speeds.
  • Added ability to filter the result list according to input city name.
  • Added Name property in GeocoderMatchResult.
Version 4.0.40.0
Release date: 6/15/2010
  • Updated assembly version to 4.0.0.0; included strong-named and weak-named assemblies. Please see the latest post in the Developer Blog for full details.
Version 4.0.0
Release date: 5/1/2010
  • Added the IPMatchingPlugin.
  • Added a new property to get the closest street number for the StreetMatchingPlugin.
  • Several API additions. See the API change log for complete details.
  • Updated the API documentation.
Version 3.1.299.77
Release date: 2/0/2010
  • Concluded public beta and moved to final release.
  • Removed the Formalizer classes; moved the valid code to various plugins' classes.
  • Adjusted the class structure for all plugins.
  • Added complete set of VB sample applications.
  • Added new Silverlight sample applications with both C# and VB source code.
  • Added four new plugins to this release: CensusTractDbfPlugin, CensusBlockDbfPlugin, CensusBlockGroupPlugin and PostCodeDbfPlugin.
  • Added new sample applications to demonstrate the new plugins, available in desktop, Web, and Silverlight versions.
  • Instituted comprehensive API checking and comparison processes for improved future transparency.
  • Updated the API documentation in accordance with new API changes.
map_suite_geocoder_features_bug_fixes_change_log.txt · Last modified: 2015/09/08 08:17 by admin
