map_suite_geocoder_dependencies_guide
Map Suite Geocoder Dependencies Guide
• Map Suite Core Required Libraries
NTS Topology
DllsGeoAPI.dll
NetTopologySuite.dll
MergeModuleN/A
LocationProject Bin Directory
Version1.1.0.0 1.7.3.31740
LicensingLGPL 2.0 License LGPL 2.1 License
WebSiteSource WebSite
Sql CLR Type Topology
x64
DllsMicrosoft.SqlServer.Types.dll
SqlServerSpatial110.dll(X64)
MergeModuleMicrosoftSqlServerSpatial.msm
LocationProject Bin Directory SqlServerSpatial110.dll should be deployed accordingly under different circumstances.
Case 1: On an X86 system.The X86 version of SqlServerSpatial110.dll (under SqlServerTypes_X86 folder) needs to be copied to “c:\Windows\System32” folder.
Case 2: Running under X64 mode on an X64 system,The X64 version of SqlServerSpatial110.dll (under SqlServerTypes_X64 folder) needs to be copied to “c:\Windows\System32”
Case 3: Running under X86 mode on an X64 system.The X86 version of SqlServerSpatial110.dll (under SqlServerTypes_X86 folder) needs to be copied to “c:\Windows\SysWOW64” folder.
Version110
WebSiteMicrosoft® System CLR Types for Microsoft® SQL Server® 2012 from Source WebSite
x86
SqlServerSpatial110.dll(X86)
Version110
MSVCR100
x64
Dllsmsvcp100d.dll
msvcr100d.dll
msvcp100.dll
msvcr100.dll
MergeModuleMicrosoft_VC100_DebugCRT_x64.msm
Microsoft_VC100_CRT_x64.msm
LocationSystemRoot.
Version100
WebSiteMicrosoft's redistribution package from Source WebSite (X64).
x86
Dllsmsvcp100.dll
msvcr100.dll
msvcp100d.dll
msvcr100d.dll
MergeModuleMicrosoft_VC100_CRT_x86.msm
Microsoft_VC100_DebugCRT_x86.msm
LocationSystemRoot.
Version100
WebSiteMicrosoft's redistribution package from Source WebSite (X86).
• Satellite Assemblies
GeoRaster Projection
Dllsproj.dll
gdal19.dll
MergeModuleMapSuiteGeoRasterProjection.msm
LocationSystemRoot\Map Suite 9.0\GeoRasterProjectionX64
SystemRoot\Map Suite 9.0\GeoRasterProjectionX86
Version4.8
1.9
Source WebSite
MrSid/JP2
x64
Dllslti_dsdk_9.1.dll
lti_dsdk_cdll_9.1.dll
lti_lidar_dsdk_1.1.dll
tbb.dll
MergeModuleMapSuiteMrSid.msm
LocationSystemRoot\Map Suite 9.0\GeoRasterX64
Version9.1.0.4045
x86
tbb.dll
LocationSystemRoot\Map Suite 9.0\GeoRasterX86
Version9.1.0.4045
Ecw
x64
DllsNCSEcw.dll
MergeModuleMapSuiteEcw.msm
Version5.2.1.265
x86
DllsNCSEcw.dll
Version5.2.1.265
proj 4
x64
Dlls proj4X64.dll
MergeModuleMapSuiteProj4.msm
MapSuitePrjHelper.msm
LocationSystemRoot\Map Suite 9.0\Proj4X64
Version4.8
x86
Dlls proj4X86.dll
LocationSystemRoot\Map Suite 9.0\Proj4X86
Version4.8
GeoTiff Library
x64
DllsGeoTiffX64.dll
MergeModuleMapSuiteGeoTiff.msm
LocationSystemRoot\Map Suite 9.0\GeoTiffX64
Versionlibgeotiff-1.2.5.0
tiff-4.0.2
x86
DllsGeoTiffX86.dll
LocationSystemRoot\Map Suite 9.0\GeoTiffX86
tiff-4.0.2
LibTiff.net Library
Source code referenceManagedGeoTiffRasterSource
Versionlibtiff.net_src-2.3.626.0
• Extensions
FleeStyleExtension
DllsCiloci.Flee.dll
MergeModuleN/A
Version0.9.26.0
LicensingCiloci.Flee License
PdfExtension
Dllspdfsharp.dll
MergeModuleN/A
Version1.32.2608.0
PostgreExtension
DllsMono.Security.dll
Npgsql.dll
MergeModuleN/A
Version2.0.0.0
2.0.11.93
ZedGraphStyleExtension
DllsZedGraph.dll
MergeModuleN/A
Version5.1.5.28844
Feature Data Objects(FDO)
DllsFDO.dll
FDOCommon.dll
FDOGeometry.dll (55 more dlls……)
MergeModuleMapSuiteFdoExtension.msm
LocationSystemRoot\
Version3.7.0.0
FileGeoDatabase
DllsEsri.FileGDBAPI.dll
FileGDBAPI.dll
FileGDBAPID.dll
FileGdbApiWrapperX64.dll
msvcp100d.dll
msvcr100d.dll
msvcp100.dll
msvcr100.dll
MergeModuleMicrosoft_VC100_CRT_x64.msm
MapSuiteFileGeoDatabaseX64.msm
MapSuiteFileGeoDatabaseX86.msm
LocationSystemRoot\Map Suite 9.0\FileGeoDatabaseX64
or SystemRoot\Map Suite 9.0\FileGeoDatabaseX86
Version1.2.0.136
Wiki Samples
Oracle Extension
x64
Dllsoci.dll
Oracle.DataAccess.dll
OracleApiWrapperX64.dll
orannzsbb11.dll
oraocci11.dll
oraociei11.dll
OraOps11w.dll
MergeModuleMapSuiteOracleDependenciesX64.msm
LocationSystemRoot\Map Suite 9.0\OracleX64
Version11.2.0.3.20
x86
Dllsoci.dll
OracleApiWrapperX86.dll
orannzsbb11.dll
oraocci11.dll
oraociei11.dll
OraOps11w.dll
MergeModuleMapSuiteOracleDependenciesX86.msm
LocationSystemRoot\Map Suite 9.0\OracleX86
Version11.2.0.3.20
Map Suite Cad
x64
DllsCadDumperX64.dll
RasterProcessor_4.00_10.tx
RecomputeDimBlock_4.00_10.tx
sisl.dll
TD_3DSolidHistory_4.00_10.tx
TD_Alloc_4.00_10.dll
TD_Ave_4.00_10.tx
TD_Br_4.00_10.dll
TD_DbRoot_4.00_10.dll
TD_Db_4.00_10.dll
TD_DynBlocks_4.00_10.tx
TD_Ge_4.00_10.dll
TD_Gi_4.00_10.dll
TD_Gs_4.00_10.dll
TD_Root_4.00_10.dll
TD_SpatialIndex_4.00_10.dll
TD_SwigCore_4.00_10.dll
TD_SwigCoreMgd.dll
TD_SwigDb_4.00_10.dll
TD_SwigDbMgd.dll
MergeModuleMapSuiteCadX64.msm
LocationSystemRoot\Map Suite 9.0\CadX64
Version4.0.0.0
x86
DllsCadDumperX86.dll
sisl.dll
TD_Ave_4.00_10.tx
TD_Br_4.00_10.dll
TD_Db_4.00_10.dll
TD_Ge_4.00_10.dll
TD_Gi_4.00_10.dll
TD_Gs_4.00_10.dll
TD_Root_4.00_10.dll
TD_SwigCoreMgd.dll
TD_SwigDbMgd.dll
MergeModuleMapSuiteCadX86.msm
LocationSystemRoot\Map Suite 9.0\CadX86
Version4.0.0.0
S57 Extension
x64
Dllsgdal110.dll
geos.dll
geos_c.dll
s57attributes.csv
s57expectedinput.csv
S57GdalWrapperX64.dll
s57objectclasses.csv
MergeModuleMapSuiteS57.msm
LocationSystemRoot\Map Suite 9.0\S57GdalWrapperX64
Version1.10.0.0
x86
Dllsgdal110.dll
geos.dll
geos_c.dll
s57attributes.csv
S57GdalWrapperX86.dll
LocationSystemRoot\Map Suite 9.0\S57GdalWrapperX86
Version1.10.0.0
Other Dependencies
Dependencies for Previous Versions
Merge Modules
map_suite_geocoder_dependencies_guide.txt · Last modified: 2017/03/17 05:14 by tgwikiupdate
