Have questions? Call us toll-free at 1-866-847-7510 (outside North America, call 1-785-727-4133)
Map Suite Services Edition All Samples
From ThinkGeo Wiki
Jump to: navigation, search
Contents
GPS to Google Map(Desktop)
Screenshot Sample Product Description
Map Suite Services Edition Sample GPS to GoogleMap Desktop.jpg C# Download
Need it in another language?
Desktop
Applies To: Desktop
Services
Wpf
Today we have the Desktop version of the Web project “GPS to Google”. In this project, we show how to display on Google Map point data coming from some GPS reading in Geodetic (Longitude/Latitude). It also shows how to set the extent of the map so that it is centered on the GPS point.
Download Video Walkthrough
Great Circle with Google Map
Map Suite Services Edition Sample Great Circle With GoogleMap.jpg C# Download
Web
Applies To: Desktop
Web
Silverlight
Services
Wpf
Mini map with Google Map
Map Suite Services Edition Sample Mini map with Google Map.jpg C# Download
Desktop
Applies To: Desktop
Web
Silverlight
Services
Wpf
Shapefile to Google Map
Map Suite Services Edition Sample Shapefile To GoogleMap.jpg C# Download
Desktop
Applies To: Desktop
Web
Silverlight
Services
Wpf
Decimal Degrees Formatting
Map Suite Services Edition Sample Decimal Degrees Formatting.jpg C# Download
Services
Applies To: Desktop
Web
Silverlight
Services
Wpf
Label to Show Location
Map Suite Services Edition Sample Label to Show Location.jpg C# Download
Services
Applies To: Desktop
Web
Silverlight
Services
Wpf
Labeling Based On Columns
Map Suite Services Edition Sample Labeling Based On Columns.JPG C# Download
Services
Applies To: Desktop
Web
Silverlight
Services
Wpf
Labeling based on size
Map Suite Services Edition Sample Labeling based on size.jpg C# Download
Desktop
Applies To: Desktop
Web
Silverlight
Services
Wpf
Multi Column Labeling
Map Suite Services Edition Sample Multi Column Labeling.jpg C# Download
Services
Applies To: Desktop
Web
Silverlight
Services
Wpf
Multiple Labels
Picture Map Suite Samples Multiple Labels.png C# Download
Desktop
Applies To: Desktop
Web
Silverlight
Services
Wpf
This sample shows how you can display multiple labels for a given point or feature. You can do this by setting a single TextStyle or multiple TextStyles. If you use a single TextStyle, you can simply use a pattern like "[ColumnName1][ColumnName2]..." and when Map Suite displays the text it will combine the values of the columns in your pattern. If you use a different styling method, you will need to manually control the offset of each piece of text to avoid overlapping.
For more information you can see the discussion forum post below: http://gis.thinkgeo.com/Support/DiscussionForums/tabid/143/aff/21/aft/6955/afv/topic/Default.aspx
MultiLine Labeling
Map Suite Wpf Desktop Sample MultiLine Labeling.jpg C# Download
Desktop
Applies To: Desktop
Web
Silverlight
Services
Wpf
Build Custom Shapefile Indexes
Map Suite Services Edition Sample Build Custom Shapefile Indexs.jpg C# Download
Services
Applies To: Desktop
Web
Silverlight
Services
Wpf
Compass
Map Suite Services Edition Sample Compas.JPG C# Download
Services
Applies To: Desktop
Web
Silverlight
Services
Wpf
Create GRID
Map Suite Desktop Edition Sample Create GRID.jpg C# Download
Desktop
Applies To: Desktop
Web
Silverlight
Services
Wpf
Edit Attribute Of Shapefile
Map Suite Wpf Desktop Edition Sample Edit Attribute Of Shapefile.jpg C# Download
Wpf
Applies To: Desktop
Web
Silverlight
Services
Wpf
Edit Geometry Of Shapefile
Map Suite Desktop Edition Sample Edit Geometry Of Shapefile.jpg C# Download
Desktop
Applies To: Desktop
Web
Silverlight
Services
Wpf
Get Data From Server With WCF
RequireDataFromServerUsingWcf.PNG C# Download
Silverlight
Applies To: Desktop
Web
Silverlight
Services
Wpf
Graphic Logo Adornment Layer
Map Suite Services Edition Sample Graphic Logo Adornment Layer.png C# Download
Desktop
Applies To: Desktop
Services
Wpf
Heat Map
Map Suite Services Edition Sample Heat Map.jpg C# Download
Desktop
Applies To: Desktop
Web
Silverlight
Services
Wpf
Heat Map with earthquakes
Map Suite Services Edition Sample Heat Map with earthquakes.jpg C# Download
Desktop
Applies To: Desktop
Web
Silverlight
Services
Wpf
Highlight at Mouse Hover
Map Suite WPF Desktop Edition Sample Highlight At Mouse Hover.jpg C# Download
WPF
Applies To: Desktop
Services
Wpf
Image Stream Loading
Map Suite Services Edition Sample Image Stream Loading.jpg C# Download
Desktop
Applies To: Desktop
Web
Silverlight
Services
Wpf
Isolines
Map Suite Services Edition Sample Isolines.jpg C# WPF Download
C# WinForms Download
Services
Applies To: Desktop
Web
Silverlight
Services
Wpf
To bring this all together, check out our Download instructional video that will walk you through the process of setting up and working with isolines in Map Suite.
KML Extension
Map Suite Services Edition Sample KML Extension.jpg C# Download
Desktop
Applies To: Desktop
Services
Wpf
Latitude Longitude Graticule
Map Suite Services Edition Sample Latitude Longitude Graticule.jpg C# Download
Desktop
Applies To: Desktop
Web
Silverlight
Services
Wpf
In this project, we create a Graticule Adorment Layer that shows Meridians and Parallels displaying through the map. Meridians are lines of longitude and they have a North South orientation. Parallels are lines of latitude and they have an East West orientation. Showing graticule for latitude and longitude is a standard way in cartography to give spatial references to the users. You will find two zip files. One is for the Desktop Edition “LatLongGraticule” and it shows nicely the effect of the meridians and parallels as you pan and zoom in and out. You will also see, as additional spatial references to the users, the latitude and longitude location at the mouse pointer in labels at the mouse move event. You will see that information in the decimal degrees format and in the Degrees Minutes Seconds format.
MapShapes
Map Suite Services Edition Sample Map Shapes.JPG C# Download
Services
Applies To: Desktop
Web
Silverlight
Services
Wpf
To fill this gap, we are presenting a project for a simple MapShapeLayer. This is a simple version of a more powerful one that we will include as part of the core framework in the near future. What really struck us when we were creating this new Layer was just how easy it was to do! It is a testament to our 3.0 framework and we decided to include the section below on how we implemented it. Notes from the developer:
Mini Map Adornment Layer
Map Suite Services Edition Sample Mini Map With Adornment Layer.JPG C# Download
Services
Applies To: Desktop
Web
Silverlight
Services
Wpf
Multi Geo Raster Layer
No screenshot.jpg C# Download
Services
Applies To: Desktop
Web
Silverlight
Services
Wpf
Multi Index
Map Suite Services Edition Sample Multi Index.jpg C# Download
Services
Applies To: Desktop
Web
Silverlight
Services
Wpf
Native TAB File Suppport
TabFileSupport.jpg C# Download
Desktop
Applies To: Desktop
Web
Silverlight
Services
Wpf
North Arrow
Map Suite Services Edition Sample North Arrow.JPG C# Download
Services
Applies To: Destop
Web
Silverlight
Services
Wpf
Rotating the map:
Displaying the North Arrow:
Numbered Grid
Map Suite Services Edition Sample Numbered Grid.jpg C# Download
Desktop
Applies To: Desktop
Web
Silverlight
Services
Wpf
Oledb Point FeatureSource
Map Suite Services Edition Sample Oledb Point FeatureSource.JPG C# Download
Services
Applies To: Desktop
Web
Silverlight
Services
Wpf
In this project, we create the class OledbPointFeatureSource inheriting from FeatureSource and OledbPointFeatureLayer inheriting from FeatureSource.
Scale Bar
Map Suite Services Edition Sample Scale Bar.jpg C# Download
Services
Applies To: Desktop
Web
Silverlight
Services
Wpf
Desktop
Applies To: Desktop
Web
Silverlight
Services
Wpf
Styles with InMemoryFeatureLayer
Map Suite Services Edition Sample Styles with InMemoryFeatureLayer.png C# Download
Services
Applies To: Desktop
Web
Silverlight
Services
Wpf
Swince Flu
Map Suite Services Edition Sample Swine Flu.jpg C# Download
Services
Applies To: Desktop
Web
Silverlight
Services
Wpf
On the web site http://www.mapcruzin.com/free-download-h1n1-swine-flu-arcgis-shapefile.htm, it is possible to download point based shapefiles of swine flu occurrences in the world. While this information is valuable, it is a little difficult to display it at world level. At high zoom levels, all the points are on top of each other making the map very difficult to read and get overall information of the swine flu situation at the world level as you can see in the image with the map of the upper left.
Watermark Adornment Layer
Map Suite Services Edition Sample Watermark Adornment Layer.JPG C# Download
Services
Applies To: Desktop
Web
Silverlight
Services
Wpf
Zedgraph
Map Suite Services Edition Sample Zedgraph.jpg C# Download
Services
Applies To: Desktop
Web
Silverlight
Services
Wpf
In our “How Do I” apps, there is sample app that shows how to add graphs to the map using the ZedGraph library. In this project, using the same data, the US cities, we elaborate a little bit on the pie chart. You will see how to add some gradient colors to the chart, how to label the different pie slices, how to add a title etc. Zedgraph is a truly massive library for graphics and Pie chart is only one type of chart among many others. As you can add pie charts to your map, you can also add bar charts, trend charts etc. I suggest you check out this site for more info on ZedGraph
http://zedgraph.org/wiki/index.php?title=Main_Page
With Map Suite, you have the whole ZedGraph API available with an easy interface to add the graphs to the map. For this project, in addition to the MapSuiteCore.dll, you will also need the ZedGraph.dll and ZedGraphStyleExtension.dll references. We will have several projects showing how to integrate other types of charts to your map.
TinyGeo File Format Sample and Converter
Map Suite Services Edition Sample TinyGeo Displayer and Converter.jpg C# Download
Services
Applies To: Desktop
Web
Silverlight
Services
Wpf
This project provides a sample of how to use the new TinyGeo file format as well as provides an easy to use converter tool for shapefiles. The goal of the TinyGeo file format was to provide our customers with a highly compressed, read only, secure, and easily distributable data file that they could use to disseminate spatial data to their customers.
Note:This is a new beta feature of Map Suite 6.0 and only works with Map Suite developer build 5.5.36.0 or later.
Serialize To Xml
Map Suite Services Edition Sample Serialize To Xml Sample.jpg C# Download
Services
Applies To: Desktop
Web
Silverlight
Services
Wpf
This sample shows you how to serialize objects in Map Suite to XML and then deserialze them back to objects. This is usefully in many GIS mapping application to save the state of styles, layers, projections or just about anything. The XML is readable and well formatted, great for working with in you GIS application.
Code Generator
Map Suite Services Edition Sample Code Generator Sample.jpg C# Download
Services
Applies To: Desktop
Web
Silverlight
Services
Wpf
This sample shows you how to generate source code calls from Map Suite objects. Imagine that you have a Layer that has been styled a particular way and uses a certain projection. Once the object is created you can pass it to the code generator and it will create source code to re-create the model passed in. This is very helpful especially in GIS applications where users define things through a custom UI but then want to leverage that in code.
Current Extent to Bitmap
Map Suite Services Edition Sample Current Extent To Bitmap.jpg C# Download
Services
Applies To: Desktop
Web
Silverlight
Services
Wpf
Custom Scale Bar
Map Suite Services Edition Sample Custom Scale Bar.jpg C# Download
Web
Applies To: Desktop
Web
Silverlight
Services
Wpf
Draw Custom Exception
Map Suite Services Edition Sample Draw Custom Exception.png C# Download
Desktop
Applies To: Desktop
Web
Silverlight
Services
Wpf
MDI Form
Map Suite Services Edition Sample MDI Form.jpg C# Download
Desktop
Applies To: Desktop
Web
Silverlight
Services
Wpf
Raster Layer to Bitmap
Map Suite Services Edition Sample Raster Layer to Bitmap.jpg C# Download
Services
Applies To: Desktop
Web
Silverlight
Services
Wpf
Show A Legend
ShowALegend.jpg C# Download
Services
Applies To: Desktop
Web
Silverlight
Services
Wpf
In today’s project we learn how to display a simple legend using the new and improved LegendAdornmentLayer. The improved LegendAdornmentLayer is new to the MapSuite 5.0 release and provides an easy to use api for creating legend adornments. The LegendAdornmentLayer is part of MapSuite.Core which gives all MapSuite products access to this powerful new feature.
Use Map with MVC Framework
Map Suite Services Edition Sample Use Map with MVC Framework.png C# Download
Web
Applies To: Desktop
Web
Silverlight
Services
Wpf
This project demonstrates how to create a web-based map using Microsoft ASP.NET MVC 1.0 and Map Suite Web Edition. To meet the requirements of MVC, we inherit the interface IMapInitializer in the controller, which has a function InitializeMap that is overridden in the controller. We then implement the class "MapInitializerHelper" to initialize the map instance.
Large Scale Map Printing
Map Suite Wpf Desktop Edition Sample Large Scale Map Printing.jpg C# Download
Wpf
Applies To: Desktop
Wpf
Web*
Silverlight*
Services*
*With some limitations. See description for details.
This WPF project is the second in our series of samples on printing. The first introductory sample served as a presentation of the different printing concepts such as page layout, the map element, legends, titles, data grids, logos and the user's interaction with them. Using all of the printing tools we introduced in the first sample, here we will demonstrate a real-world print scenario at a large scale with data for parcels at a county level. By reading the descriptive comments within the sample code itself, you will better understand how to handle your printing needs and follow cartographic standards for map presentation.
Print Preview
Map Suite Services Edition Sample Print Preview.jpg C# WPF Download
Services
Applies To: Desktop
Wpf
Web*
Silverlight*
Services*
To help you understand the sample, as well as Map Suite's new printing system upon which it is based, check out our Download instructional video that will introduce you to all of these concepts and walk you through the sample solution.
Custom Parameters Projection
Map Suite Wpf Desktop Edition Sample Custom Paramters Projection.jpg C# Download
Wpf
Applies To: Desktop
Web
Silverlight
Services
Wpf
Custom Rotation Projection
Map Suite Wpf Desktop Edition Sample Custom Rotation Projection.jpg C# Download
Wpf
Applies To: Desktop
Web
Silverlight
Services
Wpf
Datum Transformation
Map Suite Services Edition Sample Datum Transformation.jpg C# Download
Services
Applies To: Desktop
Web
Silverlight
Services
Wpf
Map Suite Services Edition Sample Distance Query On Projected Layers.png C# Download
Desktop
Applies To: Desktop
Web
Silverlight
Services
Wpf
Geodetic to State Plane
Map Suite Services Edition Sample Geodetic to State Plane.jpg C# Download
Services
Applies To: Desktop
Web
Silverlight
Services
Wpf
Geodetic to UTM on the fly
Map Suite Services Edition Sample Geodetic to UTM on the fly.jpg C# Download
Services
Applies To: Desktop
Web
Silverlight
Services
Wpf
Google Map to Geodetic
Map Suite Wpf Desktop Edition Sample GoogleMapToGeodetic.jpg C# Download
Wpf
Applies To: Desktop
Web
Silverlight
Services
Wpf
http://en.wikipedia.org/wiki/World_file#Definition. You can also use this technique for any other background maps such as Bing Map, Open Street Map using Spherical Mercator. Warning: It is possible to use a world file with parameters for a Geodetic system from an image originally in Spherical Mercator due to some similar projection characteristics. Applying the same operation for other projections such as Lambert or UTM will not work.
Graticule with Projection
Map Suite Wpf Desktop Edition Sample Graticule with Google Projection.jpg C# Download
Wpf
Applies To: Desktop
Web
Silverlight
Services
Wpf
Map Suite Services Edition Sample Great Circle On Pacific Rim.jpg C# Download
Services
Applies To: Desktop
Web
Silverlight
Services
Wpf
Local Datum UTM
Map Suite Wpf Desktop Edition Sample Local Datum UTM.jpg C# Download
Wpf
Applies To: Desktop
Web
Silverlight
Services
Wpf
http://www.cage.curtin.edu.au/~will/datum.html http://www.usq.edu.au/course/material/SVY3107/lectures/Breeze/SVY2106amgmgafund/index.html
Measurements Decimal Degrees
Map Suite Services Edition Sample Measurements Decimal Degrees.jpg C# Download
Services
Applies To: Desktop
Web
Silverlight
Services
Wpf
Pacific Rim
Picture Map Suite Samples Pacific Rim.JPG C# Download
Services
Applies To: Desktop
Web
Silverlight
Services
Wpf
This project shows how to display the Pacific Rim and Asia if you pan to the west, so that the world "wraps around," as it does with Google Maps.
Many of our Map Suite sample applications include an example of the world being displayed using a world ShapeFile. The ShapeFile is in Decimal Degrees and it displays the world according to longitude and latitude value ranges. These ranges are from -180 to 180 for longitude and 90 to -90 for latitude. In our various examples that use this ShapeFile, you see the Western Hemisphere on the left and the Eastern Hemisphere on the right. Now, a common request that we receive is to display the Pacific Rim and Asia if you pan to the west, so that the world "wraps around," as it does with Google Maps. This can be accomplished in Map Suite 3.x by using a custom projection that offsets all of the points by 360 for the x (longitude) values. (180 + 180 = 360). ...
Polygon across Meridian
Map Suite Services Edition Sample Polygon across Meridian.jpg C# Download
Services
Applies To: Desktop
Web
Silverlight
Services
Wpf
Projection by Analyzing Prj File
ProjectionReadingPrjFile.jpg C# Download
Web
Applies To: Desktop
Web
Silverlight
Services
Wpf
Projection Distance LineStyle
Map Suite Services Edition Sample Projection Distance LineStyle.jpg C# Download
Web
Applies To: Desktop
Web
Silverlight
Services
Wpf
This Web project is similar to the project “Distance Line Style”. Here we show how to use a projection of choice different from the projection used on the map. For example, you may have your map using Google map as a background. Google map uses Spherical Mercator projection which is not ideal for distance measurements, that is why using a more appropriate projection for distance measurement such as State Plane will give more accurate results. The CustomDistanceLineStyle inheriting from LIneStyle has the logic built in to have the distance calculated based on a projection of choice instead of the projection of the map.As for the previous project “Distance Line Style”, you can see how the DrawCore function is overridden for the a specific need of style: displaying the distance label on each line segment making up a LineShape. In addition to the overriding of the DrawCore function, you will find useful some geometry functions such as GetPointOnLine to find the midpoint of a line segment and GetAngleFromTwoVertices to incline correctly the labels according to the orientation of each line segment. You will notice that the CustomDistanceLineStyle works for features made of LineShape and you will have to slightly modify to have it working with MultilineShape.
Projection Distortion
Map Suite Services Edition Sample Projection Distortion.jpg C# Download
Services
Applies To: Desktop
Web
Silverlight
Services
Wpf
Projection in Feet
Services
Applies To: Desktop
Web
Silverlight
Services
Wpf
Routing with Projections
Map Suite Services Edition Sample Routing With Projection.jpg C# Download
Services
Applies To: Desktop
Web
Silverlight
Services
Wpf
Save To Projection
Map Suite Services Edition Sample Save To Projection.jpg C# Download
Services
Applies To: Desktop
Web
Silverlight
Services
Wpf
Map Suite Desktop Edition Sample Spherical Mercator Projection Adjustment.jpg C# Download
Services
Applies To: Desktop
Web
Silverlight
Services
Wpf
Street Intersection
Map Suite Services Edition Sample Street Intersection.jpg C# Download
Services
Applies To: Desktop
Web
Silverlight
Services
Wpf
Map Suite Services Edition Sample World Coordinate With Rotation.png C# Download
Services
Applies To: Desktop
Web
Silverlight
Services
Wpf
World Coordinates
Map Suite Services Edition Sample World Coordinates.jpg C# Download
Services
Applies To: Desktop
Web
Silverlight
Services
Wpf
Wrap Dateline Mode With Projection
Map Suite Wpf Desktop Edition Sample Wrap Date Line Mode with Projection.jpg C# Download
Wpf
Applies To: Desktop
Web
Silverlight
Services
Wpf
Clipping
Map Suite Services Edition Sample Clipping.jpg C# Download
Services
Applies To: Desktop
Web
Silverlight
Services
Wpf
This project along with "Spatial Join", "Dissolve" and "Dissolve with Statistics" show another type of geoprocessing technique that can be applied to a layer. Clipping a layer can be handy in situation where the layer has a geographic extent larger than necessary and you just need a portion of it based on some defined area. For example, you might have the world layer of evergreen but you are working at the national level for Brazil and you don’t need the rest of the world. Clipping the layer will reduce it to the geographic area you are only interested in.
With "Clipping", you will see how to combine the GetIntersection geometric function with other functions for creating and editing a layer into a coherent one step operation. Notice that this project only deals with clipping polygon based layer. It is also possible to clip line and point based layers. That will be the subject of future projects.
Clipping On Line Layer
Screenshot Sample Product Description
Map Suite Wpf Desktop Edition Sample Clipping On Line Layer.jpg C# Download
Need it in another language?
Wpf
Applies To: Desktop
Web
Silverlight
Services
Wpf
This Wpf project completes the series of projects dedicated to the clipping geoprocessing. We already saw how to perform clipping on a polygon based layer in "Clipping" and on a point layer in "Clipping On Point Layer". Here we show how to perform the clipping geopressing on a line based layer. As for the same operation on a polygon based layer, the key geometric function is GetIntersection. We will also appreciate the operation of creating a layer from scratch as in addition to the geometric operation itself, geoprocessing also involves creating a result layer from the original layers, the clipping layer and the clipped layer. You will need to get in the Dev Daily Build the latest MapSuiteCore.dll and WpfDesktopEdition.dll as references as the GetIntersection API for line based shapes was added only recentely.
Map Suite Services Edition Sample Clipping On Point Layer.jpg C# Download
Services
Applies To: Desktop
Web
Silverlight
Services
Wpf
After the project "Clipping" where we saw how to clip a polygon layer based on a polygon, in this project we see how to clip a point based layer. Clipping a point based layer is quite a simpler task than clipping a polygon based layer as no geometric functions are necessary such as GetIntersection (overlap) besides the spatial query. It is also a much faster task to run.
Convex Hull
Map Suite Services Edition Sample Convex Hull.png C# Download
Services
Applies To: Desktop
Web
Silverlight
Services
Wpf
Correcting Nodes
Map Suite Services Edition Sample Correcting Nodes.jpg C# Download
Services
Applies To: Desktop
Web
Silverlight
Services
Wpf
As for the projects "Spatial Join" and "Dissolve", in this project we see how to edit FeatureLayers. In this case, we show some techniques to clean up a line based layer. You may be in a situation where you have to do that on a layer representing a network. Due to a poor digitizing, the end nodes of the lines don’t touch each other showing disconnected when in fact they should be connected. In this project, we show the technique to correct the location of the end vertices (nodes) so that they connect to each other. Keep in mind that the logic for correcting nodes shown here, is very simple and does not take into account various parameters such as tolerance, line order, multi line intersection etc. This logic works in the case of having an ordered sequential network as it is often digitized. The full logic taking into account all the different scenarios is vastly more complicated. We plan to offer this full logic in the future as an API within our core product.
Create Inner Ring
Map Suite Services Edition Sample Create InnerRing.jpg C# Download
Desktop
Applies To: Desktop
Web
Silverlight
Services
Wpf
Create Polygon Programatically
Map Suite Services Edition Sample Create Polygon Programatically.jpg C# Download
Services
Applies To: Desktop
Web
Silverlight
Services
Wpf
Dissolve on Shapefile
Map Suite Services Edition Sample Dissolve on Shapefile.JPG C# Download
Services
Applies To: Desktop
Web
Silverlight
Services
Wpf
This project will soon be followed by another project on how to apply statistics when dissolving a shapefile. Also, there will be another related project on how to do Dissolve on a generic FeatureSource.
Map Suite Services Edition Sample Dissolve with Statistics.jpg C# Download
Services
Applies To: Desktop
Web
Silverlight
Services
Wpf
In the project "Dissolve", we saw the geometric aspect of the Dissolve operation with the Union function etc. In this project, we going a little further and we apply statistics on the layer while dissolving. For each column of the layer being dissolved, we can apply various statistics such as sum, average, count etc. For example if you are dissolving the states of the US based on what region they belong to, you may want to get the sum of the population of each state within the same region and save that to the output dissolved layer.
Desktop
Applies To: Desktop
Web
Silverlight
Services
Wpf
Draw a Pie shape
Map Suite Services Edition Sample Draw a Pie shape.png C# Download
Services
Applies To: Desktop
Web
Silverlight
Services
Wpf
For more information, please see the discussion forum post below: http://gis.thinkgeo.com/Support/DiscussionForums/tabid/143/aff/21/aft/6963/afv/topic/Default.aspx
Dynamic Segmentation
Map Suite Services Edition Sample Dynamic Segmentation.JPG C# Download
Services
Applies To: Desktop
Web
Silverlight
Services
Wpf
FeatureIdsToExclude
Map Suite Services Edition Sample FeatureIdsToExclude.jpg C# Download
Desktop
Applies To: Desktop
Web
Silverlight
Services
Wpf
Get Feature Clicked On With Projection
Map Suite Services Edition Sample Get Feature Clicked On With Projection.jpg C# Download
Services
Applies To: Desktop
Web
Silverlight
Services
Wpf
This WPF project shows a technique for finding the feature of a point, line or polygon-based layer that the user clicked on. As with the earlier sample entitled "Get Feature Clicked On", in order to give the user the expected behavior, a buffer in screen coordinates needs to be set so that the selected feature is chosen within a constant distance in screen coordinates from where the user clicked on, regardless of the zoom level. In addition, this sample also addresses a limitation of the earlier sample by showing the contrast between using the functions GetFeaturesNearestTo and GetFeaturesWithinDistanceOf.
While the function GetFeaturesNearestTo as used in "Get Feature Clicked On" works quickly and is adequate in most cases, it is not guaranteed to get the closest feature. In contrast, with the new function GetFeaturesWithinDistanceOf, you can loop through the features within a specified tolerance and get their exact distance. While this approach requires some more code, it is guaranteed to get the closest feature in every case.
Identify Point with Icon
Map Suite Services Edition Sample Identify Point with Icon.jpg C# Download
Services
Applies To: Desktop
Web
Silverlight
Services
Wpf
Inner Ring Containment
Map Suite Services Edition Sample Inner Ring Containment.jpg C# Download
Services
Applies To: Desktop
Web
Silverlight
Services
Wpf
Intersect Line
Map Suite Services Edition Sample Intersect Line.jpg C# Download
Desktop
Applies To: Desktop
Web
Silverlight
Services
Wpf
Intersecting Multi Polygon
Map Suite Services Edition Sample Intersecting MultiPolygon.jpg C# Download
Services
Applies To: Desktop
Web
Silverlight
Services
Wpf
Intersecting Two Layers
Map Suite Services Edition Sample Intersecting Two Layers.jpg C# Download
Services
Applies To: Desktop
Web
Silverlight
Services
Wpf
In the project "Clipping", we saw how to clip a layer with another to have a resulting layer of the desired geographical extent. In the project "Intersecting two layers", we see the technique of intersecting two layers which goes a few steps further compared to simply clipping a layer.
Merge Line Layers
Map Suite Services Edition Sample Merge Line Layers.JPG C# Download
Services
Applies To: Desktop
Web
Silverlight
Services
Wpf
Merge Point Layers
Map Suite Services Edition Sample Merge Point Layers.jpg C# Download
Services
Applies To: Desktop
Web
Silverlight
Services
Wpf
This project is similar to a previous project related to geoprocessing for merging polygon layers "Merging Layers", but applied to point layers.
An alternative approach to merging is to use a multi index and treating all the various files as one layer. You can see this Discussion Forum post for more info on that: http://gis.thinkgeo.com/Support/DiscussionForums/tabid/143/aff/21/aft/5921/afv/topic/Default.aspx Next we will show how to do the same thing for line layers.
Merging Layers
Map Suite Services Edition Sample Merging Layers.jpg C# Download
Services
Applies To: Desktop
Web
Silverlight
Services
Wpf
If you have many files of the same type and representing the same type of features, Map Suite offers an API for building a multi index and treating all the various files as one layer. You can see this Discussion Forum post for more info on that: http://gis.thinkgeo.com/Support/DiscussionForums/tabid/143/aff/21/aft/5921/afv/topic/Default.aspx
Multi Ring Buffering
Map Suite Services Edition Sample Multi Ring Buffering.jpg C# Download
Services
Applies To: Desktop
Web
Silverlight
Services
Wpf
Negative Buffering
Map Suite Services Edition Sample Negative Buffering.jpg C# Download
Services
Applies To: Desktop
Web
Silverlight
Services
Wpf
Offset Point at Right Angle
Map Suite Services Edition Sample Offset Point at Right Angle.jpg C# Download
Services
Applies To: Desktop
Web
Silverlight
Services
Wpf
Polygon Shapes To Multipolygon Shapes
Map Suite Wpf Desktop Edtion Sample Polygon Shapes To Multipolygon Shapes.jpg C# Download
Wpf
Applies To: Desktop
Web
Silverlight
Services
Wpf
Register Shape
Map Suite Services Edition Sample Register Shape.jpg C# Download
Services
Applies To: Desktop
Web
Silverlight
Services
Wpf
Remove LineShape
Map Suite Services Edition Sample Remove LineShape.jpg C# Download
Services
Applies To: Desktop
Web
Silverlight
Services
Wpf
Spatial Join
Map Suite Services Edition Sample Spatial Join1.jpg C# Download
Services
Applies To: Desktop
Web
Silverlight
Services
Wpf
Split Polygon
Map Suite Services Edition Sample Split Polygon.jpg C# Download
Services
Applies To: Desktop
Web
Silverlight
Services
Wpf
Split Polygon Based On Grid
Map Suite Services Edition Sample Split Polygon Based On Grid.png C# Download
Services
Applies To: Desktop
Web
Silverlight
Services
Wpf
This utility was designed to grid high point-count polygons to aid in faster rendering. It is one of the utilities used in the Performance Guide section of the wiki and is also featured in a Download performance learning video.
From the Performance Guide:
Sweep Angle
Map Suite Services Edition Sample Sweep Angle.jpg C# Download
Services
Applies To: Desktop
Web
Silverlight
Services
Wpf
Sweep Angle Desktop
Map Suite Services Edition Sample Sweep Angle Desktop.jpg C# Download
Desktop
Applies To: Desktop
Web
Silverlight
Services
Wpf
The purpose of today’s project is to show how to make a desktop project from a Servicess one. Many of the projects published in the Code Community are in the Servicess edition because the only reference for Map Suite required for running them is MapSuiteCore.dll. That dll comes in any of the Map Suite products. We are taking the example of the "Sweep Angle" Servicess project to show how to adapt it to a Desktop project. With the understanding of some basic concepts such as Overlay, you will be able to easily convert a Servicess project to a Desktop one. So, for this project, you will need the references for both MapSuiteCore.dll and DesktopEdition.dll. Next, we will see how to convert a Servicess project to a Web one.
Adjusted Scaling Image Style
Map Suite Services Edition Sample Adjusted Scaling Image Style.jpg C# Download
Services
Applies To:
Desktop
Web
Silverlight
Services
Wpf
Animated Gif
Map Suite Services Edition Sample Animated Gif.jpg VB Download
Desktop
Applies To: Desktop
Services
Wpf
In today’s project, we learn how to extend InMemoryFeatureLayer to have the ability to display animated gif for each layer in the Desktop edition. You will notice that for now, we are limited to have one animated gif per InMemoryFeatureLayer but in the future, we will show the technique to have a different animated gif for each feature of the InMemoryFeatureLayer.
Cached Value Style
No screenshot.jpg C# Download
Services
Applies To: Desktop
Web
Silverlight
Services
Wpf
ClusterPointStyle
Map Suite Services Edition Sample Cluster Point Style.jpg C# Download
Services
Applies To: Desktop
Web
Silverlight
Services
Wpf
Decimal Degrees Formatting
Map Suite Services Edition Sample Decimal Degrees Formatting.jpg C# Download
Services
Applies To: Desktop
Web
Silverlight
Services
Wpf
Default ValueStyle
Map Suite Wpf Edition Sample Default ValueStyle.jpg C# Download
Wpf
Applies To: Desktop
Web
Silverlight
Services
Wpf
Displaying One-Way Streets
Map Suite Services Edition Sample Display One Way Streets.jpg C# Download
Services
Applies To: Desktop
Web
Silverlight
Services
Wpf
Distance Line Style
Map Suite Services Edition Sample Distance Line Style.jpg C# Download
Web
Applies To: Desktop
Web
Silverlight
Services
Wpf
Doughnut Point Style
Map Suite Services Edition Sample Doughnut Point Style.JPG C# Download
Services
Applies To: Desktop
Web
Silverlight
Services
Wpf
EditOverlay Styles
Map Suite Services Edition Sample EditOverlay Styles.jpg C# Download
Web
Applies To: Desktop
Web
Silverlight
Services
Wpf
Feature Centric Style
Map Suite Services Edition Sample Feature Centric Style.JPG C# Download
Services
Applies To: Desktop
Web
Silverlight
Services
Wpf
Flashing Point Style
Map Suite Services Edition Sample Flashing Point Style.jpg C# Download
Services
Applies To: Desktop
Web
Silverlight
Services
Wpf
Hybrid TextStyle
Map Suite Services Edition Sample Hybrid TextStyle.jpg C# Download
Services
Applies To: Desktop
Web
Silverlight
Services
Wpf
This project is a follow up to the Discussion Forum post
http://gis.thinkgeo.com/Support/DiscussionForums/tabid/143/aff/21/aft/6652/afv/topic/Default.aspx Rotating the feature text (similar to wordwrap).
Image Style
Map Suite Services Edition Sample Image Style.png C# Download
Services
Applies To: Desktop
Web
Silverlight
Services
Wpf
Isolines
Map Suite Services Edition Sample Isolines.jpg C# WPF Download
C# WinForms Download
Services
Applies To: Desktop
Web
Silverlight
Services
Wpf
To bring this all together, check out our Download instructional video that will walk you through the process of setting up and working with isolines in Map Suite.
Line Style With Increment
Map Suite Desktop Edition Sample Line Style With Increment.jpg C# Download
Desktop
Applies To: Desktop
Web
Silverlight
Services
Wpf
Multiple Dot Density Styles
Map Suite Wpf Desktop Edition Sample Multiple Dot Density Styles.jpg C# Download
Wpf
Applies To: Desktop
Web
Silverlight
Services
MultiLine Labeling
Map Suite Wpf Desktop Sample MultiLine Labeling.jpg C# Download
Desktop
Applies To: Desktop
Web
Silverlight
Services
Wpf
Web
Applies To: Desktop
Web
Silverlight
Services
Wpf
Rotate Icon
Map Suite Services Edition Sample Rotate Icon.jpg C# Download
Services
Applies To: Desktop
Web
Silverlight
Services
Wpf
Routing Styles
Map Suite Services Edition Sample Routing Styles.jpg C# Download
Services
Applies To: Desktop
Web
Silverlight
Services
Wpf
Scaling Image Style
Map Suite Services Edition Sample Scaling Image Style.JPG C# Download
Services
Applies To: Desktop
Web
Silverlight
Services
Wpf
Scaling TextStyle
Map Suite Services Edition Sample Scaling TextStyle.jpg C# Download
Services
Applies To: Desktop
Web
Silverlight
Services
Wpf
Scaling TextStyle for Polygon
Map Suite Services Edition Sample Scaling TextStyle for Polygon.jpg C# Download
Services
Applies To: Desktop
Web
Silverlight
Services
Wpf
In the project "Scaling TextStyle", we learned how to create a custom TextStyle to have the font size proportional to the scale while zooming in and out the map when labeling point based features. In the project "Scaling Image Style", we learned basically the same thing but applied to an icon or an image. In today's project, we also learn how to create a scaling textStyle but for polygon features. Notice in the overridden DrawCore function how we calculate the font size based on the current and how we make sure no label overlapping exists by using the function CheckOverlapping of the base class before drawing the label for each part of the polygon.
Side View Icon
Map Suite Services Edition Sample Side View Icon.jpg C# Download
Desktop
Applies To: Desktop
Web
Silverlight
Services
Wpf
This is a Desktop project.
Sized Point Style
Map Suite Services Edition Sample Sized Point Style.JPG C# Download
Services
Applies To: Desktop
Web
Silverlight
Services
Wpf
Smooth Transparent Route
Map Suite Services Edition Sample Smooth Transparent Route.jpg C# Download
Desktop
Applies To: Desktop
Web
Silverlight
Services
Wpf
Start End LineStyle
Map Suite Services Edition Sample Start End Line Style.jpg C# Download
Services
Applies To: Desktop
Web
Silverlight
Services
Wpf
TextStyle for Multi Line
Map Suite Services Edition Sample TextStyle for MultiLine.jpg C# Download
Services
Applies To: Desktop
Web
Silverlight
Services
Wpf
Time Based Point Style
Map Suite Services Edition Sample Time Based PointStyle.JPG C# Download
Services
Applies To: Desktop
Web
Silverlight
Services
Wpf
Time Line
Map Suite Services Edition Sample Time Line.jpg C# Download
Services
Applies To: Desktop
Web
Silverlight
Services
Wpf
ValueStyle with Countries
Map Suite Services Edition Sample ValueStyle with Countries.jpg C# Download
Services
Applies To: Desktop
Web
Silverlight
Services
Wpf
Weather Line Style
Map Suite Wpf Desktop Edition Sample Weather Line Style.jpg C# Download
Wpf
Applies To: Desktop
Web
Silverlight
Services
Wpf
WordWrapped TextStyle
Map Suite Services Edition Sample WordWrapped TextStyle.jpg C# Download
Services
Applies To: Desktop
Web
Silverlight
Services
Wpf
You can find the discussion forum post on that topic at: http://gis.thinkgeo.com/Support/DiscussionForums/tabid/143/aff/21/aft/6421/afv/topic/Default.aspx
World Sized Image Style
Map Suite Services Edition Sample World Sized Image Style.jpg C# Download
Services
Applies To: Desktop
Web
Silverlight
Services
Wpf
World Sized Text Style
Map Suite Services Edition Sample World Sized TextStyle.jpg C# Download
Services
Applies To: Desktop
Web
Silverlight
Services
Wpf
Bread Crumb Trail
Map Suite Services Edition Sample Bread Crumb Trail.jpg C# Download
Desktop
Applies To: Desktop
Web
Silverlight
Services
Wpf
Centering and Rotating
Map Suite Services Edition Sample Centering and Rotating.jpg C# Download
Services
Applies To: Desktop
Web
Silverlight
Services
Wpf
Centering Map with Tolerance
Map Suite Services Edition Sample Centering Map with Tolerance.jpg C# Download
Desktop
Applies To: Desktop
Web
Silverlight
Services
Wpf
Map Suite Services Edition Sample Centering On Moving Vehicle.jpg C# Download
Services
Applies To: Desktop
Web
Silverlight
Services
Wpf
Chemical Plume
Map Suite Services Edition Sample Chemical Plume.jpg C# Download
Services
Applies To: Desktop
Web
Silverlight
Services
Wpf
With Map Suite, you can easily build those zones, display them and do spatial analysis. You will notice an interesting feature of this project is that it combines WorldMapKit wms for street map background display and the actual vector street data for analysis. For this project, you will need the very latest evaluation or full edition of MapSuiteCore.dll and WorldMapKit Wms.dll for displaying the background street map.
Detect GPS
Map Suite Services Edition Sample Detect GPS.jpg C# Download
Desktop
Applies To: Desktop
Web
Silverlight
Services
Wpf
Filter Radar Image
Map Suite Services Edition Sample Filter Radar Image.JPG C# Download
Services
Applies To: Desktop
Web
Silverlight
Services
Wpf
Moving Vehicle with Label
Map Suite Services Edition Sample Moving Vehicle with Label.png C# Download
Desktop
Applies To: Desktop
Web
Silverlight
Services
Wpf
Rotated Image Style
Map Suite Services Edition Sample Rotated Image Style.JPG C# Download
Services
Applies To: Desktop
Web
Silverlight
Services
Wpf
Snap GPS to Street
Map Suite Services Edition Sample Snap GPS to Street.jpg C# Download
Services
Applies To: Desktop
Web
Silverlight
Services
Wpf
Traveling Salesman Problem
Map Suite Services Edition Sample Traveling Salesman Problem.jpg C# Download
Desktop
Applies To: Desktop
Web
Silverlight
Services
Wpf
Vehicle Direction
Map Suite Services Edition Sample Vehicle Direction.JPG C# Download
Desktop
Applies To: Desktop
Web
Silverlight
Services
Wpf
Center Map Based On Lat/Long
Map Suite Services Edition Sample Center Map Based On LatLong.jpg C# Download
Web
Applies To: Desktop
Web
Silverlight
Services
Wpf
Services
Applies To: Desktop
Web
Silverlight
Services
Wpf
Desktop
Applies To: Desktop
Web
Silverlight
Services
Wpf
Services
Applies To: Desktop
Web
Silverlight
Services
Wpf
Custom Zoom Levels
Screenshot Sample Product Description
Services
Applies To: Desktop
Web
Silverlight
Services
Wpf
GetZoomLevel
Map Suite Services Edition Sample Get ZoomLevel.jpg C# Download
Need it in another language?
Desktop
Applies To: Desktop
Web
Silverlight
Services
Wpf
Map Scales
Map Suite Services Edition Sample Map Scales.jpg C# Download
Desktop
Applies To: Desktop
Web
Silverlight
Services
Wpf
Raster Layer with extent
Picture Map Suite Samples Raster Layer With Extent.jpg C# Download
Desktop
Applies To: Desktop
Web
Silverlight
Services
Wpf
Restricting Extent
Map Suite Desktop Edtion Sample Restricting Extent.jpg C# Download
Desktop
Applies To: Desktop
Web
Silverlight
Services
Wpf
Zoom In To Feature
Map Suite Services Edition Sample Zoom In To Feature.jpg C# Download
Web
Applies To: Desktop
Web
Silverlight
Services
Wpf
Zoom In To Point
Map Suite Services Edition Sample Zoom In To Point.jpg C# Download
Desktop
Applies To: Desktop
Web
Silverlight
Services
Wpf
Desktop
Applies To: Desktop
Web
Silverlight
Services
Wpf
Zoom to Full extent
Map Suite Services Edition Sample Zoom To FullExtent WPF.jpg C# Download
Wpf
Applies To: Desktop
Web
Silverlight
Services
Wpf
Zoom to Full extent
Map Suite Services Edition Sample Zoom To FullExtent Service.jpg C# Download
Services
Applies To: Desktop
Web
Silverlight
Services
Wpf
Personal tools
Variants
Actions
Products
Data
Add Ons
Navigation
Toolbox
Learn More About Map Suite, Download a Free Trial, or Buy Now
GIS Developer Components for .NET
Map Suite Extensions & Add-Ons
Map Data Sets & Icons
Try Map Suite Free
Map Suite Online Store
sales@thinkgeo.com
1-866-847-7510 (Toll-Free)
1-785-727-4133 (Outside North America)
ThinkGeo LLC
2801 Network Blvd. Suite 215
Frisco, TX 75034
Map Suite Support Center
