map_suite_geocoder_installation_guide
Map Suite Geocoder Installation Guide
System Requirements
  • Microsoft Windows 7 or newer, or Microsoft Windows Server 2012 or newer
  • Visual Studio or Visual Studio Express, 2010 or newer
  • C#, Visual Basic .NET, and other .NET-compatible languages are supported for development
  • For Map Suite MVC Edition:
    • ASP.NET MVC 3, ASP.NET MVC 4, ASP.NET MVC 5
    • Traditional ASPX or Razor ViewEngine
Environment Preparation
Install .NET Framework 4.0
Map Suite requires the Microsoft .NET Framework 4.0 or newer.
If you are using Visual Studio 2010, make sure to install Visual Studio 2010 Service Pack 1.
Install Visual Studio 2010 Tools
Map Suite Product Additional Tools Needed
Map Suite MVC Edition ASP.NET MVC 4 for Visual Studio 2010 SP1
Map Suite Silverlight Edition Silverlight 4 Tools for Visual Studio 2010, or
Silverlight 5 Tools for Visual Studio 2010 SP1
Install ThinkGeo Product Center
All of the Map Suite GIS developer controls are delivered through the ThinkGeo Product Center, a Windows application that serves as the central point for you to install, evaluate, purchase and activate Map Suite products. To begin using any Map Suite edition, such as MVC or WPF Desktop, you must first install Product Center.
1. Download the ThinkGeo Product Center.
2. Once the download is complete, double-click the .msi file to begin installation.
3. The installer window will appear. Click the “Next” button to proceed with the next step.
4. You will now be asked to accept the ThinkGeo software license agreement. Once you have read the license in its entirety, check the box at the bottom of the window and click “Next”.
5. On this step, choose the installation directory for the Product Center. Then, click “Next”.
6. Product Center is now ready to be installed. To proceed, click the “Install” button. At this point, you may be asked to enter credentials for an administrator account on Windows Vista / Server 2008 or higher. Make sure you say “Yes” to the User Account Control prompts, or the installation will not be able to continue.
7. The installation process will begin. It may take a few minutes for the Product Center to install and decompress all of its files. A blue bar will indicate its progress until this is complete. When the installation finishes successfully, you will be shown the following screen.
8. Click the “Finish” button to exit the installer. If the “Launch Product Center” checkbox is selected, the Product Center will open when the installer exits.
Begin Your Development
map_suite_geocoder_installation_guide.txt · Last modified: 2017/03/17 05:15 by tgwikiupdate
