Let your mapping applications start taking you places! Map Suite Routing is an extension for Map Suite Desktop, Web, Services or Silverlight Edition that calculates routes and driving directions. This native .NET component gives your Map Suite applications the power to find the shortest path from A to B, deliver turn-by-turn directions, avoid specified areas, and much more.
The MapSuiteGeocoder Edition API documentation covers the ThinkGeo.MapSuite.MapSuiteGeocoder namespace which resides in the MapSuiteGeocoder.dll assembly. It contains all of the MapSuiteGeocoder Edition specific classes such as the map control itself, Overlays, and supported map classes.
In addition to the samples below, we have dozens of interactive Routing Edition sample applications available here.
We have provided several .Net code samples in C# & VB.NET to help you get going quickly. We have categorized them to allow you to quickly find what you are looking for. Each code sample includes an overview, complete code online to review and the ability to download the sample to run it yourself.
All Samples
All samples about Map Suite Routing.
Project Templates
These projects show various study cases based on Routing.
Layers & FeatureSources
Miscellaneous
Styles
Step through the Routing Edition sample applications and see how they're put together. We'll demonstrate how to use each app, then take you through every part of the source code and show you how it works.
The Routing Extension screenshots gallery section showcases a wide range of screenshots covering various GIS features.
All the frequently asked questions about Map Suite Routing.
These frequently asked questions cover GIS and map control topics that are not categorized in other areas.
These frequently asked questions cover.
