map_suite_routing
Map Suite Routing
Let your mapping applications start taking you places! Map Suite Routing is an extension for Map Suite Desktop, Web, Services or Silverlight Edition that calculates routes and driving directions. This native .NET component gives your Map Suite applications the power to find the shortest path from A to B, deliver turn-by-turn directions, avoid specified areas, and much more.
Product Guides
This guide helps you get you up to speed with integrating the Routing map control into your GIS software.
This guide walks you through installing the map control on your system and creating a simple GIS application.
This guide walks you through deploying your GIS software using the map control into a production environment.
This guide introduces the dependencies Map Suite Routing needs with their features, versions and source websites.
API Documentation
  • ThinkGeo.MapSuite.Routing
    The MapSuiteGeocoder Edition API documentation covers the ThinkGeo.MapSuite.MapSuiteGeocoder namespace which resides in the MapSuiteGeocoder.dll assembly. It contains all of the MapSuiteGeocoder Edition specific classes such as the map control itself, Overlays, and supported map classes.
Code Samples
In addition to the samples below, we have dozens of interactive Routing Edition sample applications available here.
We have provided several .Net code samples in C# & VB.NET to help you get going quickly. We have categorized them to allow you to quickly find what you are looking for. Each code sample includes an overview, complete code online to review and the ability to download the sample to run it yourself.
All Samples
All samples about Map Suite Routing.
Project Templates
These projects show various study cases based on Routing.
Layers & FeatureSources
Miscellaneous
Styles
Videos
Routing Edition Sample App Walkthrough Video Series
Step through the Routing Edition sample applications and see how they're put together. We'll demonstrate how to use each app, then take you through every part of the source code and show you how it works.
Screenshot
Introduction to the Routing Edition
Screenshots
The Routing Extension screenshots gallery section showcases a wide range of screenshots covering various GIS features.
Screenshot
Shortest length or fastest time Just a few lines of code
Screenshot
Road type Road length Start/end point
Screenshot
Draw your own areas Routes adjust automatically
Screenshot
Turn-by-turn By intersection
Screenshot
Add a stop with a single click Unlimited stops
Screenshot
Intelligently find the most efficient route around point-based roadblocks
Screenshot
Based on average speed and drive time
Screenshot
Generate an optimal route for visiting a set of locations
Screenshot
Easy to see and learn Source code available for every sample
Change Logs
  • API Change Log
Frequently Asked Questions
  • All Questions
    All the frequently asked questions about Map Suite Routing.
  • General Questions
    These frequently asked questions cover GIS and map control topics that are not categorized in other areas.
  • Layers & FeatureSources
    These frequently asked questions cover.
  • Styles
Help & Support Guides
  • Support Options
  • Support Ticket Guide
  • Discussion Forum Guide
  • NuGet Guide
  • Release Cycle Guide
map_suite_routing.1442282252.txt.gz · Last modified: 2015/09/15 01:57 by admin
