map_suite_mvc_edition_background_maps_google_bing_etc._samples
Map Suite MVC Edition Background Maps (Google, Bing, etc.) Samples
ArcGISServerRestOverlay
In this web-based project, we'll demonstrate the new ArcGISServerRestOverlay released with Map Suite 5.0 WebEdition. This overlay gives developers a simple and powerful tool to access their maps that reside on ArcGIS Server. This new overlay utilizes the ArcGIS Server REST API. You can also check out the sample video to see the ArcGISServerRestOverlay in action.
Custom Map with Google Labels
screenshot
Applies To: MVC \ Web
GPS to Google Map(Web)
Applies To: MVC \ Web \ Silverlight
Great Circle with Google Map
Applies To: MVC\Desktop \ Web \ Silverlight \ Services \ Wpf
Mini map with Google Map
Applies To: MVC \ Desktop \ Web \ Silverlight \ Services \ Wpf
OpenStreetMap
Applies To: MVC \ Desktop \ Web \ Silverlight \ Wpf
Shapefile to Google Map
map_suite_mvc_edition_background_maps_google_bing_etc._samples.1441523970.txt.gz · Last modified: 2015/09/06 07:19 by admin
